Tamiya TRF418
#496
#499
i.e RideRed = 301gmf/mm Tamiya Red = ???
#501
Hey guys!
What low profile servo do you recommend?
For 4pks R radio.
want to go with futaba,but i was wondering what are tamiya using in the official 418 promo pictures?
For 4pks R radio.
#502
You might be waiting for a while... Tamiya never publish spring rates for their springs. They are only ever published by people who have actually tested the springs themselves.
#507
Yep, I know. Hopefully I will get some numbers this weekend. They seem to feel very much like the ride springs although I'm sure they are not them.
#509
Quick set up question's.
My current set up has 3mm spacers under the upper arm (rear) ball connectors but I'm currently running 1mm under the front connectors. On the rear I also have 3mm spacers under the ball connector on the hub. Is it better to have the 3mm spacers on both the front and rear or is it ok the way I have it set up?
Also does anyone have suggestions on how to tune the sway bars? I have the fronts pretty well tuned but on the rear when I lift up on the left arm I get about 1/4 inch play on the right arm but when I lift up on the right arm the left arm has over 1/2 inch of travel no matter what I try I can't seem to get rid of this excessive play on the left.
#510
Has anyone here got even left and right throw without messing with the end points? I can get full lock but i have my Steering balance at 70 % one side and 90 at the other..
Heh! I know just curious. It seems the Yellows are the same as HPI silvers
