Old 12-29-2013, 02:48 PM   #391
sosidge's Avatar
Originally Posted by Qatmix View Post
I also found that the RW spurs don't fit they are a little too wide so I can't fit the e-clip on. How did you get yours to fit? Just add a load of shims to the outer bulkhead?
Shims for the time being, although Much-More make some 4mm ID spacers that I may well switch to.
Old 12-29-2013, 03:46 PM   #392
Originally Posted by addicted2blue View Post
I will mount the carbon (TRF416) or the steal weight battery holder from the TRF417 to prevent the battery from moving.
I took the carbon one off my 417 and it works perfectly. Only bummer was that I had already mounted my receiver and it was just a touch too far in towards the center so I had to pull it off the deck and re-do it.
Car is done and set up so hopefully tomorrow I can get down to the track to see how she runs.
Does anyone have an editable PDF set up sheet for the 418?
Cheers, Jeff
c2tcardin is offline   Reply With Quote
Old 12-29-2013, 04:10 PM   #393
narcotiks's Avatar
Originally Posted by Losiho View Post
I use the TRF servo horn in all my cars. Tight fit, precise, love it. Panaracer spurs are a drop in fit.
As for the battery mounts - I actually had to trim one of the mounts a little in order for my batteries to actually fit into the battery tray. I had excessive movement with the battery mounts in the V5, not with the 418.
i just flipped the front battery mount so it screws into the chassis in the alternate hole.
Only spurs that i know to fit ATM are Panaracer, the kit spur and Kawada super EX.
http://www.petitrc.com/reglages/tami...iyaTRF418.html
http://www.petitrc.com/reglages/tami...SetupSheet.pdf
narcotiks is offline   Reply With Quote
Old 12-29-2013, 04:14 PM   #394
Losiho's Avatar
When are you getting yours Yan ?
Losiho is offline   Reply With Quote
Old 12-30-2013, 01:57 AM   #395
CraigM's Avatar
Trader Rating: 34 (100%+)
Here is how Marc did the battery stop as described by Narcotiks
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-30-2013, 10:06 AM   #396
syndr0me's Avatar
Trader Rating: 32 (100%+)
Sweet pancakes look at that pit board!
syndr0me is offline   Reply With Quote
Old 12-30-2013, 05:31 PM   #397
My 418 first run~~~
asuradahk001 is offline   Reply With Quote
Old 12-30-2013, 05:50 PM   #398
sosidge's Avatar
Spent some more time on my steering linkage, managed to get full lock within 120% EPA by using the outer hole on the servo saver (like in the pictures above).
Old 12-30-2013, 09:59 PM   #399
veecee's Avatar
You can also easily get full lock with the longer Smokem steering arms. They are a straight fit on the 418.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 12-31-2013, 01:11 AM   #400
Mister-E's Avatar
The servo horn needs to be mounted one notch to the left when the servo is in neutral position! This is when looking from the front of the car.
Mister-E is offline   Reply With Quote
Old 12-31-2013, 05:46 AM   #401
hana166's Avatar
I had this problem in my car. Maybe this will help. I used the 3racing part as its 18mm. The Tamiya I think is 16mm.
http://www.rcmart.com/3racing-3racht...a-p-33453.html
hana166 is offline   Reply With Quote
Old 12-31-2013, 06:54 AM   #402
The Tamiya Aluminium horn is taller than the std servo saver (about 2mm) I also have the Tamiya Aluminium replacement front part of the servo saver (looks like that 3Racing one in the link) and it reaches full lock
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-31-2013, 12:22 PM   #403
SS LS1's Avatar
Trader Rating: 23 (100%+)
This is the 3 Racing std arm in light blue to match the Tamiya blue color.
http://www.rcmart.com/3racing-3racht...cPath=1099_808
This is the 3 Racing light blue horn that is a little longer to give you more steering throw.......
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 12-31-2013, 05:11 PM   #404
Got on the track today but couldn't get any clean track time as there was a family of 5 on the track with rental cars. Every lap one of them would either hit me or be in the way, I guess that's the way it goes sometimes and I'm happy to see the store getting the business. What I can say though is the car felt great! I was right there with my lap times on the 417 and this was with the kit set up (though I do run a front gear diff w/ 2.5million diff fluid). Also the track was in pretty bad shape as the people with the rental cars had managed to destroy the chicane as well as realigned several corners. I'm sure some practice on a clean track will bring my lap times down. If anyone has a set up sheet for a low grip carpet track please post, I'm looking for ways to increase grip coming out of 90 degree corners.
Cheers, Jeff
Old 12-31-2013, 07:12 PM   #405
JimmyMac's Avatar
You coming out tomorrow to race with us?
M.J. McIntyre
Yokomo YRX12
Yokomo YZ-2 DT/CA
JimmyMac is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
