Old 12-20-2013, 06:34 AM   #331
Dizope, if you still have your race berry conversion for the 417 and want to sell it. Email your price shipped to California. Aveytia@gmail.com. Thanks
Juan Aveytia is offline   Reply With Quote
Old 12-20-2013, 07:06 AM   #332
Got my 418 ready to build
Also got an interview with Marc Rheinard here with his hopes and aspirations for the 2014 championship and the TRF418
http://www.thercracer.com/2013/12/ra...-rheinard.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-20-2013, 07:53 AM   #333
Going to keep it. Thanks for asking.
Richard G.
Tamiya...
dizope is offline   Reply With Quote
Old 12-20-2013, 04:18 PM   #334
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by sosidge View Post
Anyone know if the Roche anti-roll bar mounts for the 417 will fit this car? Or any other alternative mounts that don't move around so easily?
I believe the arc ones are a direct fit. I would steer clear of the ones that brace the bulkhead
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 12-21-2013, 01:05 AM   #335
OnRDPassion's Avatar
Trader Rating: 54 (100%+)
Well I had my first practice day with the 418 on carpet today and wow the car was awesome! I had some engine troubles with getting the right gearing but once that was figured out it was all good. The only other thing that was weird is the front blades on the spool kept breaking but that was because of clipping a board or two. It was nice to run this car considering the last time I had run on carpet was two years ago and with a TC6 and this car was substantially better.
Tomorrow I will be going to the Tamiya America test track in California. Looking forward to seeing how the car performs out there as well.
Jay Williams
Xray RX8 2014
RC America - Protoform Racing - KO Propo USA - Kevco Racing / Picco EDO Modified - Byrons Fuels
OnRDPassion is offline   Reply With Quote
Old 12-21-2013, 03:55 AM   #336
halim6's Avatar
Send a message via MSN to halim6 Send a message via Yahoo to halim6
Hi,
Had the same problem with the front blades running on carpet, changed to gear diff filled with putty (Ride Hardness 45) and the blades are ok.
>> RIGHT TO RACE <<
** This is my HOBBY. It's all about having FUN, and it's my ultimate STRESS Reliever!! **
halim6 is offline   Reply With Quote
Old 12-21-2013, 05:05 PM   #337
CraigM's Avatar
Something to keep an eye on then. I only replaced one blade in the 4 days at AOC Yatabe and that was also after a crash & I ran the same blades for 2 meets since on asphalt.
If it becomes an issue the ARC R10 blades are a direct fit and they are almost impossible to remove once they are fitted to the driveshaft
Old 12-21-2013, 05:10 PM   #338
So today I went to the Tamiya test track and did a little R&D. It was tough day needless to say as the grip wasn't up to where it normally is and it was cold. I did however by the end of the day end up getting the car close to what I wanted.
Front:
6 Degree C-hubs
1mm under the steering ball studs for the ackerman
450 wt oil
Ride Red springs
0mm shims under the inner camber link
1mm shims under the outer camber link
5mm Ride height
5mm Droop +1 Degree toe
C in front
B in the rear
.5 mm shim under the blocks
Rear
450 wt oil
Ride Red springs
5mm Ride height
5mm droop
4mm shims under the outer camber links
2 degrees of camber
XC front separate
C in rear
.5mm shims under the blocks
I was running with a Mazda 6 light weight body. I tried using the LTC-R and did not like it at all.
Jay Williams
Xray RX8 2014
Old 12-21-2013, 08:02 PM   #339
Trader Rating: 1068 (100%+)
Anyone in the US looking to get a 418 soon? PM me
Less warning labels... more Darwin!
EZ Customs Paint / Xtreme RC
ON ROAD: XRAY T4 '15 USVTA/USGT X1 F1 , OFF ROAD RB6
and for those that don't know me.. I'm a sarcastic A DBL S
Dave Cates Founder of www.GO-RCing.org
bigwavedave33 is offline   Reply With Quote
Old 12-21-2013, 09:56 PM   #340
Jochim_18's Avatar
Originally Posted by bagged69chevy View Post
Craig, how did you make that access hole on the top of your ball cups? did you just grind each one by hand?
Nick you haven't noticed the my ball cups have holes mine it's been like that forever.. Easy way to put a hole on the ball cups is use body reamer...
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 12-21-2013, 11:16 PM   #341
Front:
6 Degree C-hubs
450 wt oil
Ride Red springs
5mm Ride height
C in front
B in the rear
Rear
450 wt oil
Ride Red springs
5mm Ride height
5mm droop
2 degrees of camber
XC front separate
C in rear
No kidding it was cold, I broke out my Sorex 20's today!
I was there with today my TRF418 briefly as well, had mine built according to kit. I'm not a very good driver or mechanic so I don't have anything to contribute but I have a quick question. The ride red are they #28103 tq only has one left in stock
torg is offline   Reply With Quote
Old 12-21-2013, 11:58 PM   #342
I couldn't find that item # on tq's website. I bought mine from speedtechhobbies.com. They were MR33 red which is the same as the Ride reds as well.
I didn't know anyone else was there running a 418. I bounced around 2:30 as I had more things to do later on. Next time come by and say hi!
Jay Williams
Xray RX8 2014
Old 12-22-2013, 12:01 AM   #343
CraigM's Avatar
Jay,
Did you run kit wheelbase? And what difference did you notice with the 6deg hubs - I keep meaning to try them?
Old 12-22-2013, 10:31 AM   #344
Originally Posted by CraigM View Post
Jay,
I was running 4mm of shims in front of the rear arms and then 2 mm behind the front arms. I liked the 6 degree hubs as it seemed to give the car more steering at off power corner entry. I definitely liked them better both on carpet and on asphalt.
Jay Williams
Xray RX8 2014
Old 12-22-2013, 10:50 AM   #345
Trader Rating: 18 (100%+)
Anyone here ever have trouble with customs when buying from HK? My 418 is still stuck in customs in Chicago. I have bought several things from HK in the past and its usually in and out of customs in less than a day. I REALLY hope they didn't lose my $500 package.
I'm trying to wait until after Christmas to call USPS or customs since I know they are overloaded right now with the holidays. I'm hoping my package is taking a long time because they are backed up and not because they lost it.
TamiyaMatt84 is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
