Like Tree1Likes
Old 08-09-2015, 12:57 PM   #2086
acutts's Avatar
Originally Posted by Simmi View Post
Look in the manual and check your car.
Do not quite understand what you mean
Hi Simmi It is built according to manual but there seems to be so much free play in the drive shaft where the go into the hubs that the camber changes by hand. I have never seen this on any other car. Guy said I would need to shim it all out but am really surprised and was wondering if this was normal for others. Need to stop the drive shafts where they go through bearings from having so much free play? Does this explain better?
acutts is offline   Reply With Quote
Old 08-09-2015, 04:11 PM   #2087
You need 0,3mm of shim on the driveshaft.
0,1mm on the outside like the manual and 0,3mm inside.
If your car has taken a few hits the chubs can become super sloppy too. The tube spacer shouldn't be mega loose.
cplus is offline   Reply With Quote
Old 08-09-2015, 11:15 PM   #2088
acutts's Avatar
Thanks Cplus car not taken any real hits. I have the kit 0.1 outer spacer/ shim and the 1.5 in between the bearings so will try add the 2 x 0.3 spacers and see if that removes the movement. Any idea what Tamils part for the shims I need is or ca I just buy generics?
Old 08-10-2015, 01:09 AM   #2089
Tamiya 53587
Hint: check the manual, the part number is next to the 0,1mm ones as you can only buy them as a packet of 10 x 0,1/0,2/0,3mm
Old 08-10-2015, 06:26 AM   #2090
niznai's Avatar
What you have is typical Tamiya slop. First Tamiya car?
You need to shim a lot to get rid of it, but first make sure you have no play in the bearings. That's a quick and cheap fix for some of the play. The rest is not that straightforward.
Also, make sure the "camber" play is not in the camber links either. The kit ball cups are good, but the ball studs are not. You need to replace those with the hopup from Tamiya that have no play (fluorine coated). They're a tad larger in diameter and are a perfect fit to the cups.
There will also be play in the outer suspension hingepin.
Got the car s/h? Replace the front plastic bits (cheap), balljoints, bearings, and check again. If you can't live with the play left, start shimming.
Oh, and don't go by what the manual says. Every car is a bit different so you need to find what shim is right for your car, not what the manual thinks it should be. These cars are not manufactured to spacecraft tolerance.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-10-2015, 07:57 PM   #2091
I agree with above. I tend to be really anal with slop, trying to remove any trace (without binding of course) and that doesn't always mean same shims each side.
Howeve, interestingly, I chatted to Volker at AOC down here a few weeks back and he said he and Umino don't really care about slop - just make sure things are even and very loose! The amount of movement he had in his rear arms I found quite staggering!
Old 08-11-2015, 01:44 PM   #2092
acutts's Avatar
Started a rebuild today and can see that shimming is definitely needed at least 0.3 shims all round. Not sure whether to shim on the inside of the hub or on the outside under the pin is there any preference?
Old 08-11-2015, 01:59 PM   #2093
Inside.
Putting them outside is pushing your track width out (not by much, but it still is)
Old 08-11-2015, 11:56 PM   #2094
acutts's Avatar
Inside.
Cheers Cplus for the answer as always 👍
Another question kit is 0.05 outside shim so if I need total 0.3 shim would you put 0.3 inside only or leave 0.05 outside and put 0.25 inside or does it not really matter?
Thanks again
Old 08-12-2015, 12:13 AM   #2095
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Tamiya TRF418 w/ full samix conversion
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 08-12-2015, 04:08 AM   #2096
Thanks again
Standard outside is 0,1mm (plus a 0,5mm wheel spacer (blue))
Keep that, then shim inside until it has no slop, but still spins free.
Typically it is 0,3mm inside. But it might more, might be less. Will be around that mark though.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
Old 08-12-2015, 12:11 PM   #2097
Trader Rating: 28 (100%+)
Do any of you 418 owners have a factory main chassis deck you'd like to sell? Preferrably in new to very good condition. These seem very hard to come by. I'm in the Los Angeles area. Thanks.
greenpea76 is offline   Reply With Quote
Old 08-12-2015, 12:47 PM   #2098
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
I got one in very good shape as I went to a Samix conversion early on. Make me an offer...
Dan is offline   Reply With Quote
Old 08-13-2015, 11:48 AM   #2099
acutts's Avatar
Is it worth getting a 419 diff for my trf418? Or is there another manufacturer that makes one that would be better?
Old 09-14-2015, 06:17 AM   #2100
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Does the 418 come with the big bore shock as box stock ?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
