Old 01-08-2015, 01:19 PM   #2011
Originally Posted by Gordie88 View Post
With 418 i am running 17.5 blink... the stock chassis is great... i just want more...
Ive maxed out my motors and driving.... want to see if a softer chassis will allow more corner speed before sliding...
Have you experimented with top deck screw removal yet?
cplus is offline   Reply With Quote
Old 01-08-2015, 05:51 PM   #2012
Ive decided to just do it! Gonna swap out to Carbon v2 Samix Chassis for the next race! I also have a 419 diff to try for the rear!
I dont like the idea for top deck.. With the stock 418 chassis i feel even with 2 screws out it made no difference.. also it didn't gain steering at the same time.
Gordie
Gordie88 is offline   Reply With Quote
Old 01-10-2015, 05:00 PM   #2013
Some quick pics of the rides here:
Tamiya TRF419
Gordie
Old 01-17-2015, 06:05 PM   #2014
Mitamiya's Avatar
Trader Rating: 14 (100%+)
Gordie, how is it going with Samix and 419 Diff?
MItamiya
Currently Racing
Offroad - Associated B5M Lite
Onroad - TRF 418 Samix VTA/TRF 419 USGT
Mitamiya is offline   Reply With Quote
Old 01-17-2015, 09:20 PM   #2015
I've been testing the TRF419 gear diff for 2 practice days and the geardiff works great.
Allthough i've used a thicker geardiff oil and being faster with thinner geardiff oil the geardiff is great, so far i have no leaks.
My TRF418 is still being the fastest car on the track of our club, beating a BD7 2014 version with 0.2s on the fastest lap
I run my car with the standard chassis, i did mount a one-way at front, this gives me lot's of steering and plenty grip at the rear.
addicted2blue is offline   Reply With Quote
Old 01-21-2015, 06:18 AM   #2016
Samix Chassis Carbon... Much more flex compared to Stock...
Since i am using the 418 for 17.5 I thought the stiff chassis would still have the edge over the Samix..
Well last weekend the car woke up even more then before! The samix chassis gained steering and rear end traction... Overall I believe it is much better.. I never changed setup all day, just had to get use to the bit more aggressive front end!!
The 419 DIFF... man is it ever smoooooth!!
Ive tried shimming and green slim... the bugger will not stop leaking!!
Gordie
Old 01-27-2015, 07:28 PM   #2017
Trader Rating: 77 (100%+)
I am trying for a 4.3 FDR to run 13.5. 96/41 wont work as the motor cant get close enough. I am running Panaracer spurs. Any other combos that will work? Will Kimbrough spurs fit without modification? Thanks for the help.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 01-27-2015, 08:57 PM   #2018
Trader Rating: 31 (100%+)
Spec R 102-105 is what I use on my 418 to get to 4.3. I only use 96t for 17.5.
ittjv is offline   Reply With Quote
Old 01-27-2015, 08:58 PM   #2019
The spur below allows you to run 17.5 & 13.5....no mods needed, no need to change spurs until they strip.
http://www.tqrcracing.com/shop/produ....asp?p_id=9306
EG Racing
ExpressMotorSports
PayPal, MC & VISA
farmbridge2404 is offline   Reply With Quote
Old 01-27-2015, 09:00 PM   #2020
Thanks. Awesome.
Old 02-01-2015, 09:07 AM   #2021
sohlman's Avatar
Trader Rating: 89 (100%+)
With high grip carpet, the 418 in 17.5 wasn't that bad with an aluminum chassis. Still nowhere near perfect, but very drivable.
Steve Sohl
sohlman is offline   Reply With Quote
Old 02-01-2015, 11:26 AM   #2022
Is that FDR not to low for this kind of track?
I've been testing with 17.5T blinky at my club (i guess your track has equal dimensions like our track) and i was running an FDR of 4.91 and the car was super fast on the straight and on the infield.
Only guys running a 10.5T blinky were faster on the straight but on the infield i was able to keep up with them.
Been running a speedpassion cirtix club stock ESC with a 17.5T V3 MMM with 20 of motor timing.
I could be wrong though.
Old 02-02-2015, 06:55 AM   #2023
sohlman's Avatar
Nope. 100x40 track, D4 with 50deg timing and the motor came off at 130F. Most 17.5s at Horsham start around 4 FDR and go from there. Super high grip too.
Steve Sohl
Old 02-09-2015, 07:28 AM   #2024
Mitamiya's Avatar
Just fitted the Samix V2 carbon and a 419 diff (Copy of Gordie) and will test the car later this week. The flex of the Samix chassis is crazy compared to the standard 418 chassis.
Gordie, how many of the top deck screws did you use on the Samix?
MItamiya
Currently Racing
Old 02-09-2015, 10:36 AM   #2025
I run with all top deck screws. The added flex MADE THE CAR COME ALIVE FRONT AND REAR!!
I will most likely take away some rear traction this weekend aswell....
and also play with shims to get the front end to not be so aggressive but keep the amount of steering i have...
Tried the new Dart and it is a bit better for me but i still think 17.5 T LTC is where it is....
Gordie
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
