Like Tree1Likes
Old 09-20-2014, 08:05 AM   #1831
niznai's Avatar
Originally Posted by bosschick View Post
Hi.
I noticed that sometimes the basic difference in setups are the shims under the ball studs under the camber links.
What effect does the following have in the handling of the car?
1. Front - increase no. of shims under the ball stud
2. Rear - increase no. of shims under the ball stud
3. Front - shorten the camber link length
4. Rear - shorten the camber link length
Thanks.
Without knowing the rest of the car and track conditions what we can tell you is just information in principle which is too vague. And you can find all about that in the Xray tuning manual or the XXX Main.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-20-2014, 04:09 PM   #1832
In addition to changing roll centre, changing the relative height of the ball studs (inner to outer, and also with respect to the arms) alters the change in camber from rest to compression. "Camber rise" is the common term here. A shorter upper link typically means more camber rise on compression. It does on our cars anyway.
Ideally, you want the camber when rolling to maintain the idea amount of contact patch for the type of corners you are dealing with. And that will change based on your driving style, the amount of grip available and the camber of the corner itself! The higher the contact patch (flatter tyre with respect to the track) the more grip *that* tyre can generate.
Still a vague answer, I know, sorry
Get the hudy set up book - it goes into heaps of detail. Also says when things should be changed.
The challenge is to get good enough to know something is occurring and when to change it!
cplus is offline   Reply With Quote
Old 09-20-2014, 05:38 PM   #1833
Thanks for the replies guys. I will try to get a copy of the X-ray or hudy manuals
bosschick is offline   Reply With Quote
Old 09-20-2014, 07:34 PM   #1834
b20btec's Avatar
Sign up at learnsetup.com or subscribe to his rctech thread, his name is martin crisp. All the info you'll ever need.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 09-20-2014, 08:09 PM   #1835
go here for the Hudy one. Free to download.
http://www.hudy.net/xhudy/products/proddwnld.php?prod_id=262&kategoria=0
Old 09-22-2014, 12:11 AM   #1836
Salkin's Avatar
If I could ask you to be honest, what car where you fastest with on small indoor carpet tracks, the 417v5 or the 418?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-24-2014, 07:50 AM   #1837
418 on carpet.. I had all 416-417......
Gordie
Gordie88 is offline   Reply With Quote
Old 09-24-2014, 10:13 AM   #1838
As above, the 418 has been very good for me at my carpet track, the v5 was good, especially with the Sepes conversion. But the 418 is quicker and more stable.
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 09-25-2014, 12:05 AM   #1839
Salkin's Avatar
Thanks for your replies, I will work some more on the 418.
Old 09-26-2014, 12:52 PM   #1840
SOLD
Kyosho Inferno MP9 TKI4
TLR 22 3.0
Apex RC Proshop
inpuressa is offline   Reply With Quote
Old 09-29-2014, 05:10 PM   #1841
Trader Rating: 77 (100%+)
Guys I need some help.
My steering will not return to center. When I set up the steering if I turn it right or left it will not return to center and is about 1.5 degrees off. It happened after a small bump to the boards.
I thought maybe it was the servo. So I tried a new and different one, no luck.
I thought then maybe it was the servo saver spring. So I screwed on a servo horn direct, no luck.
Everything looks straight, nothing bent. The steering has no binding when completely disconnected from the servo.
I am at a loss, anyone with some ideas?
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 09-29-2014, 06:11 PM   #1842
For those visual folks. I set it up perfect +1 degree toe out and then when I turn left it returns right back to that spot. However when I turn to the right it comes back short or -1 degree toe in.
Old 09-29-2014, 06:51 PM   #1843
b20btec's Avatar
[QUOTE=goin2drt;13564529]Guys I need some help.
I am at a loss, anyone with some ideas?[/QUOTE
Same problem. Tried everything possible to correct this and just end of living with it, besides this and my issue with killshot motor mounting spacing its a good car.
Soap
Old 09-29-2014, 07:16 PM   #1844
While waiting I replaced the uprights, replaced c-hubs, inspected DCJ's for straightness and inspected the bearings. Still does it.
Old 09-29-2014, 07:17 PM   #1845
[QUOTE=b20btec;13564745]
Problem is I can't drive well enough to deal with it. It veers on the straight because it doesn't return to center. That was my problem.
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
