Like Tree1Likes
Old 09-18-2014, 03:17 AM   #1816
Salkin's Avatar
Simmi, is this not your setup sheet:
http://www.petitrc.com/reglages/tami...urg2014030809/
It also specifies a split XC block (for the front-rear).
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-18-2014, 03:23 AM   #1817
Salkin's Avatar
Originally Posted by cplus View Post
You own a 418 - what came with it?
Yes, a pair of XC split blocks comes with the 418 kit. Along with a pair of XA split blocks.
Old 09-18-2014, 04:47 AM   #1818
Simmi's Avatar
Im a Little confused because in the Manual the split Blocks is discribed as Ca and Cb mean C?
Can you simply swap the sides of the split block and get XA or A and XC or C?
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 09-18-2014, 05:03 AM   #1819
Salkin's Avatar
I can understand this The number you refer to are numbers I have only seen in the manual. They are also referred to as BA31 and BA32.
I'm not concerned with those numbers, and you can see in the manual, that they are depicted with the 1C 1XC marking.
And yes, you swap them to get either C or XC. That was what was confusing me.
I have now learned, that if the setup sheet, like Marc's, specifies separate B blocks for the front-rear, you take the "1B 1XB" blocks and place them so that the "1B" is closest to the center of the chassis.
In Marc's setup, he specifies separate XC blocks for the rear-front, you take the "1C 1XCB" blocks and place them so that the "1XC" is closest to the center of the chassis.
The B or the BX simply specifies in which direction the separate "B" blocks are required to be facing.
Old 09-18-2014, 11:41 AM   #1820
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Juat taking a glance at jilles setup from ets-luxembourg. Noticed he went back to old style droop measurement. Only thing i am still curious about is if he is running the new ball studs? And if he is does he include that +1 in his sheet or is it that amount of shims u run total
so if it says 2.5mm does that mean old ball stud with 2.5, new ball stud with 1.5 +1. Or new ball stud with 2.5 + 1 (3.5 in total).
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 09-18-2014, 12:30 PM   #1821
CraigMBA's Avatar
Trader Rating: 22 (100%+)
How do you guys mount the fan on the chassis? Servo tape? Shoe goo?
CraigMBA is offline   Reply With Quote
Old 09-18-2014, 01:41 PM   #1822
Simmi's Avatar
@Salkin
Thanks for the explanation, drove since two years 417-418 and have always fitted the blocks the wrong way, so that always other results came out
I must say that my swapped blocks were not as bad. Last time I drive in Front B-XB and in Rear A-D. Good Grip and fast time.
Now it's time to go out and Win with the new experience
Shame on me a bit
Done my Setup ...
Team Yokomo YZ2 CA
Old 09-18-2014, 02:28 PM   #1823
Salkin's Avatar
@Salkin
Shame on me a bit
Done my Setup ...
Looks nice
Old 09-18-2014, 02:29 PM   #1824
Salkin's Avatar
I use this:
http://www.lrp.cc/en/products/electr...10stk/details/
Old 09-18-2014, 03:43 PM   #1825
He told me on Facebook he always uses old style ball studs.
So you need to subtract 1mm from the numbers on his sheets if using the new ones.
cplus is offline   Reply With Quote
Old 09-18-2014, 07:26 PM   #1826
xrayaustin's Avatar
Thanks for that
Old 09-19-2014, 12:56 PM   #1827
syndr0me's Avatar
Trader Rating: 32 (100%+)
If anybody in the US is interested in trying the Samix CF chassis that's very lightly used (only on carpet) give me a shout via PM and let's make a deal. Chassis only, didn't get the motor mount.
syndr0me is offline   Reply With Quote
Old 09-19-2014, 01:18 PM   #1828
Trader Rating: 77 (100%+)
I love this car. First run yesterday. Out of in road for a while and when I was it was all AE. I got talked into trying Tamiya and the 418. Couldn't be happier.
TRF 418 - Team Powers 17.5, HobbyWing Stock Spec, Xpert servo
Xray T4 2016 - Trinity D4, HobbyWing Stock Spec, Ko Propo servo and radio
KustomRCGraphics.com (Best looking novice on the track)
goin2drt is offline   Reply With Quote
Old 09-20-2014, 04:33 AM   #1829
Default Setup question
Hi.
I noticed that sometimes the basic difference in setups are the shims under the ball studs under the camber links.
What effect does the following have in the handling of the car?
1. Front - increase no. of shims under the ball stud
2. Rear - increase no. of shims under the ball stud
3. Front - shorten the camber link length
4. Rear - shorten the camber link length
Thanks.
bosschick is offline   Reply With Quote
Old 09-20-2014, 06:50 AM   #1830
@ bosschick:
1. Increased shims --> lowered rollcenter on the front --> more steering, less rear grip, slightly more rollangle
2. lowered rollcenter rear --> more rear grip, less front grip(steering)
3 and 4:
Not that easy to answer: While pitching (braking or full acceleration) the rollcenter height of the respective axle moves up or down MORE if the camber link is shorter!
To break it down, as much as possible: With short links the car should understeer more on corner exit and oversteer more while braking!
But shorter links result also in more camber gain. In my opinion the upper effects are bigger (especially balance wise)
Worst87 is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
