Old 09-04-2014, 05:41 AM   #1756
The setup sheet is an oddity. No one measures that way except for kiyo (trf mechanic) apparently. We discussed this including me asking Jilles Groskamp direct on his FB page.
Oh, and it's 3.5mm difference between under arm and centre of pin
cplus is online now   Reply With Quote
Old 09-04-2014, 05:54 AM   #1757
PDR
PDR's Avatar
Trader Rating: 30 (100%+)
Am I the only one that finds the way droop is measured to be confusing?
Not just the direct measurement (under arm/hinge pin), but unless I'm mistaken, it's the limiting of the upward travel that affects handling.
However, the independent measure of (effectively) chassis to arm position is only one of three variables that affect the movement of the chassis. Tyre diameter and ride height also play a part. For example, setting the droop (as per sheet) along with ride height can be impacted by tyre diameter, yet this is rarely recorded.
What's more important? "Droop over ride height" or the three independent measures?
Am I over-thinking this?
Phil.
Looking for chassis | Multiple Kids
2011 Slowest Winner - 21.5 Muchmore Masters & NSW State Titles Demo Class
https://www.facebook.com/phatdadracing/
Making an A Main at a Scotty Ernst event. Awesome. Scotty calling you first in A1. Priceless
PDR is offline   Reply With Quote
Old 09-04-2014, 07:28 AM   #1758
sosidge's Avatar
Since a rubber tyre is basically consistent in it's diameter, it doesn't matter. Foam tyre racers would always measure the droop over ride height rather than stick with a single droop setting.
Old 09-04-2014, 01:53 PM   #1759
Salkin's Avatar
Thanks for your replies.
Just to be sure, if I want the 5mm droop specified in the 418 setup sheet I linked to, I measure 1.5mm from bottom of chassis to under the arm?
Do you guys normally measure droop from bottom of chassis to under the arm? Seems like the easiest way to do it.
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 09-04-2014, 02:04 PM   #1760
sosidge's Avatar
No.
As I said earlier, if it is a measurement of 5mm it is sure to have been measured from under the arm anyway.
1.5mm is a crazy setting and probably isn't even possible.
Old 09-04-2014, 02:25 PM   #1761
PDR
PDR's Avatar
Any given tyre is going to be consistent, but different brand tyres have diameters that can be quite different. I've seen up to 1.5mm difference across Muchmore, Ride, Sorex, LRP and Sweep. The local tracks have different surfaces which favour different tyres.
Changing tyres would affect ride height, which if then adjusted, alters the droop over ride height and thus weight transfer. Could be anywhere from 0.5mm to 0.75mm or possibly more.
So, in my view, the information about tyre diameter is important in understanding the complete picture. Or, does some magic about axle height (ground to axle height - function of tyre diameter) cancel this out?
If I'm over thinking it, then that's cool
Old 09-04-2014, 02:55 PM   #1762
sosidge's Avatar
Of course the different diameter of some tyres requires adaptations to the droop setting - realising that is the distinction between a smart racer and the racer that thoughtlessly copies setups!
Old 09-05-2014, 01:30 AM   #1763
Salkin's Avatar
No.
After some more google work and watching some youtube videos with Jilles groskamp I now know that the 5mm droop is measured under the arm.
And yes, 1.5mm would be a crazy setting, not even possible on my 418.
Case solved....and closed
Old 09-05-2014, 04:50 AM   #1764
niznai's Avatar
Phil.
I think you are indeed confused.
By two things.
It is generally accepted that rubber tires are pretty much the same diameter (unless you're running some left field tires, I don't think there's more than .2mm difference between all tires sanctioned by various international bodies to which most of the clubs worldwide adhere).
Secondly, most of the time ride height is controlled and it seems to hover around 5mm.
That takes two variables out of the equation. Measuring droop over ride height becomes then the norm (or how far arms can travel downwards from chassis bottom).
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-05-2014, 05:11 AM   #1765
Rubber tyres are definitely not all the same diameter.
Hell, measure some RIDE Re vs Rex - quite a big difference (circa 2mm)
Old 09-07-2014, 10:01 PM   #1766
syndr0me's Avatar
Trader Rating: 32 (100%+)
Alright friends, summer is nearly over and so is my fling with the wonderful 418. It's a great car, but it's time to move on to something new. I'm selling my 418 with lots of nice little upgrades for a killer price.
Tamiya TRF 418 w/extras
See you guys in the 419 thread next year.
syndr0me is offline   Reply With Quote
Old 09-08-2014, 01:15 AM   #1767
Salkin's Avatar
So you don't have a car until December/January?
Old 09-08-2014, 07:37 AM   #1768
syndr0me's Avatar
Nah, got the Awesomatix for indoor season.
Old 09-09-2014, 03:23 AM   #1769
Simmi's Avatar
Has anyone tried the servo mount from the TB EVO 6 on your 418?
I will try it on Saturday on our home track.
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
Old 09-09-2014, 06:05 AM   #1770
Will that not just stick the servo more outwards effecting the balance in a more negative way?
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
