Like Tree1Likes
Old 08-18-2014, 03:40 AM   #1681
niznai's Avatar
The track width is going to change either way but imperceptibly so. Don't sweat it.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-18-2014, 03:47 AM   #1682
Salkin's Avatar
As new in TC, I have a question.
If you need more top speed on the strait, how do you know whether to go up a tooth or more in gearing or to increase some of the timing options in the speedo?
My son runs a 418 in kit setup, FDR gearing in the 8 region (according to table in manual to the 6.5T LRP X20 motor fitted), LRP Flow speedo in default settings.
Well, how do you know how to gain more top speed, play with gearing, speedo timing settings or both?
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
Old 08-18-2014, 04:42 AM   #1683
Electr0n's Avatar
Originally Posted by CraigMBA View Post
Change the outdrives to pn 84294. No more problems. Use a dab of grease where the metal to metal contacts.
You could use Tamiya 51443, Never had problems in Stock with them on 417, 417X and TB EVO 5 MS. Replaced them every 4 - 5 races.
Andre
Electr0n is offline   Reply With Quote
Old 08-18-2014, 04:49 AM   #1684
Salkin's Avatar
Andre
Well, I actually have a pair of those. Thought they would be minced by the dogbones driving modified.
Maybe I could give them a try.
Old 08-18-2014, 04:53 AM   #1685
Salkin's Avatar
Only catch is that they the plastic cups are actually not much cheaper than the steel ones, but the plastic cups will probably not wear the pins on the dogbones, saving the shaft.
Old 08-18-2014, 04:55 AM   #1686
Electr0n's Avatar
Don't forget the alu parts ! Tamiya 9804389
Andre
M-03, M-05, TB 03 (R+), TB-04 Pro (R), TT-02 S, TRF 417X, TRF 417V5, TRF 418, TRF 419, All TB EVO Chassis, TRF 414 and .....
Old 08-18-2014, 05:05 AM   #1687
Salkin's Avatar
Andre
Ahh, OK, I need those also. Thanks!
Old 08-18-2014, 07:56 AM   #1688
CraigMBA's Avatar
Trader Rating: 22 (100%+)
The plastic ones fail spectacularly if you make incidental contact.
Steel only please.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-18-2014, 08:17 AM   #1689
Electr0n's Avatar
Never had one failing in 3 years of driving 417 and 417X, despite having 4 broken C-hubs during Indoor race with 10T sensorless Carson motor.
Andre
Old 08-18-2014, 08:27 AM   #1690
CraigMBA's Avatar
I broke one in about twenty laps. Never broke a C hub.
Old 08-18-2014, 08:45 AM   #1691
Electr0n's Avatar
Stock (17.5T / 13.5T) or Modified ?
Old 08-18-2014, 09:12 AM   #1692
CraigMBA's Avatar
13.5. Brushed against a slow moving car who turned into me. Didn't even stop. Car looked fine, but had a massive pull to the right. Pulled off and found it.
Old 08-18-2014, 10:14 AM   #1693
niznai's Avatar
All of the above plus timing on the motor. And a better motor. And a better battery (some will argue there's some black magic that gives some .0000001 sec a lap or some such). And so on.
Anyway. All that motor timing will help but at the expense of torque (i.e. acceleration) for a given gearing. So will do gearing changes. But you already knew that. The advantage with dynamic timing is that you can decide by using the speedo settings when it kicks in. That way, you can have little timing applied at low revs to use the potential of the torque and once the revs build up you can have more timing added on.
Either way, watch motor temperatures.
Some motors can be geared to high heaven, others not so much. Hacker motors of the past had such huge torque, you'd run out of room to move the motor before you reached their peak.
What to change depends in principle on the track.
But.
Ideally, you should find the motor timing where it's at its best efficiency (not highest torque or RPM), find the optimal gear ratio for that (i.e. so it gives strong acceleration) and then add ESC timing and adjust when/how (delay/ramp) that kicks in.
Team Greasy Weasel
Old 08-18-2014, 10:58 AM   #1694
Salkin's Avatar
Anyway. All that motor timing will help but t the expense of torque (i.e. acceleration) for a given gearing. So will do gearing changes. But you already knew that. The advantage with dynamic timing is that you can decide by useing the speedo settings when it kicks in. That way, you can have little timing applied at low revs to use the potential of the torque and once the revs build up you can have more timing added on.
But.
Thanks for the tips, I will work ahead in that order, motor timing, gearing and then finetune with esc settings.
Old 08-18-2014, 11:00 AM   #1695
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
That gear is too short
Unless you are running on a tiny indoor track
8:1 is about right for a 4-5t motor
Gear up, try around 6.5 to 7:1 for a 150' straight
Leave timing at default on motor, use Flow timing to fine tune how hard you want it to hit
temp at 4m
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
