Old 08-01-2014, 10:47 PM   #1501
xrayaustin's Avatar
Trader Rating: 12 (93%+)
Send a message via AIM to xrayaustin
Admist all this banter about durability. ..
i would like to give an update from nationals. I'm running my car in 17.5 and am still trying a lot of things after the second round. As of now I'm in 5th but should be 3rd (bad blowout in the second round). I have the entire samix conversion on and is much better even in stock for those of u wondering if it would work in stock. The car is very consistent across the 6 minutes. Trying to get the car to run faster upfront currently.
Hopefully after tomorrow I can report back and say that I'm in the top 3 where I feel like me and the car of capable of being. The car drives good and handles great. Will report back later and if I can get the car better I will post my setup if somebody wants it
Www.superiorhobbies.com
2010 cleveland indoor champs and 2011 snowbird nationals 17.5 stock A main winner
xrayaustin is offline   Reply With Quote
Old 08-02-2014, 07:19 AM   #1502
d16dcoe45's Avatar
Who carries the Samix conversion in the States?
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 08-02-2014, 07:38 AM   #1503
xrayaustin's Avatar
Probably nobody honestly. Superior ordered me one from rc mart. Other than that im not sure
Old 08-02-2014, 08:03 AM   #1504
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Good luck, please do.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 08-02-2014, 09:19 AM   #1505
niznai's Avatar
Originally Posted by redbones View Post
I read that YR and 3R uses cheap aluminum to make their parts? It'll work for most applications, but not for high stress areas.
Don't know how cheap it is, but Tamiya use a soft alloy too on all their parts. Xray is the only brand from what I have that used a harder alloy in the past. Currently it only uses it on driveshaft bones from what I can tell. And frankly, I don't think there's need for over engineering. If you can bend the alloy your driving needs improvement, not the material.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 08-02-2014, 01:32 PM   #1506
+1
inpuressa is offline   Reply With Quote
Old 08-02-2014, 06:25 PM   #1507
xrayaustin's Avatar
Well after qualifying at the nationals is over I qualified 4th. The car is still.driving well. Needs to just be a bit more free to be where I need to be to win. But for A1 new tires free my car up so hopefully make something happen. I geared up to and the car picked up pace. Will report back after mains. A win is probably not likely as scotty is pacing the field but top 3 is definently in reach and with triple A mains anything is possible
Old 08-02-2014, 07:02 PM   #1508
Good luck mate.
Make sure you record your setup and get it posted to petitrc
cplus is offline   Reply With Quote
Old 08-03-2014, 01:15 AM   #1509
Good luck
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 08-03-2014, 10:11 AM   #1510
acutts's Avatar
Finished building my car and after almost 6 years roughly away from the sport will be racing the car next Sunday for the first time.
It have a question regarding springs, I built the car with the stock springs but they feel really soft. I will be running a fast track and was wondering what a good front and rear spring would be. The 418 kit I have came with a few other tamiya spring options and when I bought it it came with RIDE black extra hard 0.333kgf/mm and purple hard 0.316kgf/mm springs. Anyone know what would be the best starting option?
acutts is offline   Reply With Quote
Old 08-03-2014, 10:15 AM   #1511
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
Asphalt or carpet?
I'm using the HPI silvers on asphalt with good results.
Dan is offline   Reply With Quote
Old 08-03-2014, 10:26 AM   #1512
acutts's Avatar
Originally Posted by Dan View Post
Asphalt or carpet?
Sorry outdoor asphalt
Old 08-03-2014, 12:38 PM   #1513
You can try get your hands on a hpi silver. The old silver colored and new black coated ones are not the same, even though the part#s are. Hard to find the old ones, and the pro setups that refer to it are those. As an alternative, you can get ride reds, as they can be better depending on your track conditions.
Old 08-03-2014, 01:55 PM   #1514
acutts's Avatar
No where can I find ride reds or hip silvers in stock sadly. Are Hara Reds the same??
Old 08-03-2014, 02:07 PM   #1515
Try schumacher greens...
They are the same as the HPI silvers.
miguelito75 is offline   Reply With Quote
Tags
417, 418, rm-01, tamiya, trf, yokomo bd7
SEO by vBSEO 3.5.0
