Old 08-28-2015, 11:31 AM   #1186
Mostly cost control haha
This car has cost me enough $$ so far!
:: Tamiya TA05 MS :: Tamiya TB04 Pro II/Exotek EXO6 :: Tamiya M05V2 :: Losi XX :: Tamiya TB01 :: Tamiya XV-01 Rally ::
ErikO is offline   Reply With Quote
Old 08-28-2015, 05:19 PM   #1187
Originally Posted by ErikO View Post
I'm going to run my tub chassis through the winter and upgrade in the spring. Looking forward to seeing the difference!
Exotek may not have it available by then
Juan Aveytia is offline   Reply With Quote
Old 08-28-2015, 09:46 PM   #1188
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Hey
Juan ,,Are you getting one as well?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 08-29-2015, 07:26 AM   #1189
vivo quevas's Avatar
Trader Rating: 18 (100%+)
Mike, when are you shipping the EXO 6 conversion kits out I'm so pumped to build my EXO 6 really like to race it next weekend since I'm in California usually 2 days shipping ship midweek would be good for me.
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 09-02-2015, 02:57 PM   #1190
Default No brakes
Has anyone had any issues with not having brakes on the TB04v2? I am running 73/52 ratio with a Reedy 17.5 and Hobbywing JustStock ESC on a Futaba 4PLS. Car handles great and good power from motor but I can't stop if I need to. Reset radio and esc but still no luck. Don't want to waste money getting another motor especially if I am missing something to check.
rajiex is offline   Reply With Quote
Old 09-02-2015, 04:05 PM   #1191
theproffesor's Avatar
Trader Rating: 56 (100%+)
Set your reverse to 100% even if you have esc set to forward brake only
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 09-02-2015, 06:27 PM   #1192
Trader Rating: 28 (100%+)
It's not your gearing. Sorry to tell you, but the brakes on the juststock speedos aren't up to par if you need a lot of braking. If you want good brakes, go to the higher end models or LRP. LRP had better brakes than anything I've used from HOBBYwing to Speed passion, Hacker, and Orion.
I run/race a TB03 and TB04R at Tamiya USA and have used all I've listed. I went back to the LRP.
I'm betting your esc is getting pretty warm if not hot, and your brakes will fade. Run a fan on the speedo if you can to see if it will make a difference, then decide on an esc from there. The fan might save you from spending money if the braking is adequate after adding a fan.
greenpea76 is offline   Reply With Quote
Old 09-03-2015, 03:45 AM   #1193
I was using a ORCA esc before I burned it out by shorting the battery. Even then it didnt have brakes.
Old 09-03-2015, 06:18 AM   #1194
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
It's not your gearing. Sorry to tell you, but the brakes on the juststock speedos aren't up to par if you need a lot of braking. If you want good brakes, go to the higher end models....
Agreed for the most part. My HW XTreme Stock and V2.1 both have more powerful brakes than the Justock, but the trick theproffesor said above to do works. I'm running a Justock in my TB04 for VTA. Not sure what firmware version mine is on, but I can check later this evening.
EDIT: I see now that the Proff already stated the Justock brake trick above... lol
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: Losi & XRay
Rodarbal is online now   Reply With Quote
Old 09-03-2015, 10:40 AM   #1195
MikeR's Avatar
Trader Rating: 15 (100%+)
Probably the radio then- check epa, the thumb wheel and other settings.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 09-03-2015, 10:47 AM   #1196
As stated on the Exotek site, their motor adapter allows for a 37t 48 pitch pinion, my question is can I run that big of a pinion with the stock 66t spur? I'm trying to achieve an fdr around 4.xx with the least amount of spending on new parts.
speed_dmon is offline   Reply With Quote
Old 09-03-2015, 11:13 AM   #1197
MikeR's Avatar
That is the EXO5 note, the EXO6 top plate sits higher so you have a better range for gearing options.
Old 09-03-2015, 11:53 AM   #1198
Mike thank you for the response, is the motor mount only meant for the converted chassis? I'm running a completely stock TB04R
Old 09-03-2015, 12:32 PM   #1199
OVA
OVA's Avatar
Hi Mike
Please check your Email or PM..Thanks
Old 09-03-2015, 02:41 PM   #1200
MikeR's Avatar
Originally Posted by OVA View Post
Hi Mike
