Old 04-23-2015, 11:02 AM   #1156
Trader Rating: 41 (100%+)
I suppose it depends on which motor you are using, because I've never experienced any difficulties adjusting timing on my ORCA motor on my TB04. I've also had a Team Powers, and others as well, but never really found it difficult or out of the ordinary to adjust timing...
As for changing out pinions, I've found it easiest to remove the 5 cap head screws that hold down the gear cover, and the pinion is easily accessible from there, only needing to loosen the motor. For gear mesh, I mesh the gears this same way without the cover as well.
markpoleon is offline   Reply With Quote
Old 04-23-2015, 11:54 AM   #1157
tobyzhang's Avatar
Originally Posted by Samich View Post
70T? What size pinion are you using? I'm currently running 72T with a 52T pinion using the exotek adapter. Even with 72T I find getting the motor close enough to mesh properly difficult.
I think it barely reaches. I bought it for him using 21.5 track star so tall gearing is a must.
tobyzhang is offline   Reply With Quote
Old 04-23-2015, 02:45 PM   #1158
I was referring to how much better it is to change timing on a TB04 when compared to a TB03.
torg is offline   Reply With Quote
Old 04-23-2015, 03:12 PM   #1159
Sorry Torg. My mistake. Comment retracted.
Old 05-05-2015, 04:06 PM   #1160
I did not find this picture posted in this thread yet. TB04R.
ic-racer is offline   Reply With Quote
Old 05-08-2015, 01:15 PM   #1161
TB04R, main changes seem to be the shocks from the TRF 419, front spool, sway bars and reinforced suspension components from the TRF 419. New carbon fiber damper stays also. I presume because the TRF 419 shocks are longer than the special short shocks that came with the TB04 Pro.
Old 06-03-2015, 09:56 PM   #1162
Rodarbal's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to Rodarbal
Bumping this thread...
Had my TB-04 standard kit (non-Pro) out for some Wednesday night asphalt racing this evening and I've gotta say that I'm pleasantly surprised by how well it did! When I got the kit I wasn't sure if I'd build it as a Tamiya shelfie or actually put it on the track. Out of the box it was too heavy for anything else other than VTA. But after a few beers I decided that's what I would build it as.
I decided to keep the front cantilever setup just to see how it would do. I used yellow (stiff) Ofna springs and 50wt AE oil up front, stock silver springs and 30wt AE oil rear. Spur: 72T, 64P. Pinion: 51T. Exotek motor spacer, Integy 7mm wheel hexes, HW Justock, Novak Ballistic 25.5, Futaba S9542, HPI VTA wheels/tires, 5mm ride height fr/rr, eyeballed droop (LOL) and my old 'cuda body from my Mi4LP. Everything else was stock Tamiya parts and setup, even the lousy dogbones.
I'm not gonna lie, I DNF'd the qual and DNS the Main due to a stripped spur (we have to run a tight ship before we lose sunlight), but would have qual'd second and was turning good laps all night. Sure, I'll make a few upgrades like CVDs and maybe dual Cardans for the front. I'm not going to try to turn it into a Pro2 or something it's not. It is a budget build after all. I'm having fun with this tub as is!
RJ Labrador
Off Road Big: Mugen, Mugen & Mugen
Off Road Little: Losi & XRay
Rodarbal is offline   Reply With Quote
Old 06-05-2015, 06:11 PM   #1163
Gravity Dodger's Avatar
TB-04 LaFerrari I just finished, body posts are waiting to be cut after fitting a new 458 body that's on order.
Gravity Dodger is offline   Reply With Quote
Old 06-05-2015, 06:40 PM   #1164
SagadSetup's Avatar
Originally Posted by Gravity Dodger View Post
TB-04 I just finished, body posts are waiting to be cut after fitting a 458 body.
Nice body but isn't that a LaFerrari?
Well here's mine currently. Almost all hopups installed but still haven't used it yet.
Contemplating wether I'm gonna sell or not. Maybe I'll just shelve it for now until I find a decent track.
Are you right where you're supposed to be?
Think. Learn. Play. Plan. For soon you'll become.
SagadSetup is offline   Reply With Quote
Old 06-05-2015, 07:04 PM   #1165
Thanks, yes it is indeed a LaFerrari and my post was slightly unclear, I ordered a tt-01 458 body to be fitted to the TB-04 and wasn't sure if the post locations were the same so I left the body posts long to mark the new body when it arrives.
Old 06-05-2015, 07:28 PM   #1166
SagadSetup's Avatar
I never had a Ferrari body. Maybe when my budget allows I will get one. I like the color red.
What I have now is the Sumo Power. Sorry for the quality of the pic.
Old 06-05-2015, 07:38 PM   #1167
That's a nice looking R35!
Old 06-05-2015, 07:46 PM   #1168
SagadSetup's Avatar
Thanks. It took me several days just to put the stickers on, It had to be exact no bubbles. Stickers were not pre-cut. I guess that's the OCD in me.
Old 06-26-2015, 01:33 PM   #1169
academygaz's Avatar
Box stock TB04 kit coming my way, what do I need to look out for? Build tips? Problem areas? Must-have upgrades?
Quote, Leodis, 2007: ''I've been shopping online for 9 years and the only charge I've ever had to dispute with my credit card company was from TiR. Congratulations TiR. Even porn sites are more ethical than your company!''
RC cars - I haz sum.
academygaz is offline   Reply With Quote
Old 06-26-2015, 01:49 PM   #1170
SagadSetup's Avatar
Hello.
Have you seen this good article?
http://www.thercracer.com/2013/11/ta...nd-review.html
It has given me a lot of info and build tips on my TB04 Pro.
