Tamiya TB04 Pro
#1037
I also recently built one of these to use in USGT. In many ways it exceeded expectations based on the low price I paid though I have found that as traction comes up the car starts to suffer from very inconsistent handling. I have a feeling this is made worse by a very soft chassis at the front end. I've picked up some optional springs and have gone heavier on damping so interested to see if this helps. Either way it was a fun build and a pretty neat car. Expecting somewhat equal performance against purpose built race chassis is a tall order.
#1039
I think my past issues with my TB04 are tied to the chassis being so warped out of the package it was (for my purposes anyway) unusable. The front end was tipped up like .75mm and the rear was almost 1mm, plus it had a twist in it so it had an insane amount of tweek. I spent hours fixing mine with a heat gun and a bunch of C clamps. The carbon rein one was worse than the kit chassis. You might consider putting a straight edge on the bottom of yours and see if the parts where the suspension blocks mount are parallel with the rest of the chassis, and more importantly, each other. Then I'd work out fixing that. Plus it's free.
My advice is if you really want to be competitive against carbon cars, you need to buy one. Of course, that depends on how competitive your class is. I was right there locally in the ROAR 17.5 class with my TB03 last year, 60 grams overweight and everything.
#1040
Through long sweepers the car will be smooth and unexpectedly dig like almost like it is suddenly getting a large weight transfer to the outside front tire. Seems to get worse as traction comes up. The car seems a bit soft stock so one idea was the car was just reaching the end of travel and once locked up was getting a spike in weight to the outside tire. I may be completely wrong in what I'm thinking. So far I'm going up one step on the front spring and also going to 40 wt in the shocks from the 35 I was using to possibly change the rate the suspension dumps over in a corner. Car seems to have plenty of steering so going up on the front springs shouldn't hurt that and maybe calm it down. Should be able to try out the changes tomorrow.
#1041
Most of my experience on carpet is from running a foam tire oval car. If you showed up at the track before the groove came in and the grip came up and the car was just money, you knew it was going to be a LONG weekend because once the grip came up it was going to do exactly what you describe and your life was going to be miserable. The car needs to be too tight when you unload and conditions are green.
In USGT I'd be inclined to run Yokomo pink and blue springs. They are class legal and softer than the HPI/Tamiya springs. If the car cases (bottoms out) before the tire develops enough grip to hook an edge and tip it, it almost saves you. Don't let it get too soft though!
I'd also consider gluing up the sidewall of the outside front tire from the wheel to halfway into the letters on the sidewall. Only that tire for now. When I ran on the Gravity carpet tires at IIC I had to glue both sides of the fronts for the same reason.
I'd also consider raising the roll center in the front by removing all the spacers under the suspension blocks, if you haven't done that already. If that is successful, and you need more, I'd add a half a mm under the front inner camber link.
In any case, post back what you learn. I'm interested to hear.
#1042
Describe inconsistent please?
My Tamiya TCS baseline setup is (or, was) the big bore yellow in the front and black in the rear, and 35wt Associated. If the car needs more overall grip (asphalt) OR you want to soften it up to avoid traction roll (carpet), run the reds in the rear and the blacks in the front. Tamiya yellows are super close to HPI black coated silver. When I measure them my way, they are so close as to call them identical.
I'm so tempted to spring for a TRF419, but then the pragmatic side kicks in and I say to myself that it's a waste of $ to spend on a car that you're racing in a parking lot. So I continue to hold off...for now lol
#1043
Back in March I sold my TRF416WE to fund a 418. I had decided to skip the 417 altogether. Then arrived the mix reviews so I held off and held and used my XV01 Pro to race until the TB04 Pro II became available. During this time I also moved out to Las Vegas, where the only onroad action is a bi-monthly hobby town parking lot race.
#1044
I see.
#1045
Yea the twisted chassis thing is annoying. Once built you can put the car on a flat surface, loosen all the top braces, push down on the shock towers, then tighten the top braces up and everything will be straight.
#1046
Car keeps getting better and better. Rear end is nicely locked in now thru fast corners. More to try still, but here is my setup so far.
Oh and I am running all hard carbon suspension parts.
#1048
Common I would guess, mine did the same, once broken in it will disappear.
#1050
Trader Rating: 38 (100%+)
Good day to all.
New to RC. New to RCTech.
Maybe I missed it in this thread but does anyone have the "formula" for shimming the gears on the TB04 Pro 2?
It would be appreciated if somebody can help.
