Old 12-09-2014, 01:26 PM   #1006
Trader Rating: 8 (90%+)
Who here is running a mod motor in the tb04?
Boostgod is offline   Reply With Quote
Old 12-09-2014, 05:02 PM   #1007
Raman's Avatar
Trader Rating: 52 (100%+)
I also coat the mitre gears and ring and pinion with Finishline ceramic dry lube (cycling product) keeps the drive line in great condition
Raman is offline   Reply With Quote
Old 12-11-2014, 05:37 PM   #1008
I just measured the stock track width and its 180mm .... is that a good spot for a tub chassis or has anyone found a better width? My indoor cars are about 185mm width but just curious for asphalt.
Thanks.
Robbob is offline   Reply With Quote
Old 12-13-2014, 09:36 AM   #1009
Raman's Avatar
Thanks.
The width can be changed with the suspension blocks. The stock kit is using A/A block in front. If you go to C/C for instance, you'll be closer to 183mm
Old 12-14-2014, 01:37 PM   #1010
Default spur gear
does anybody know what's the biggest spur gear that can be fitted
Dark77Hawk is offline   Reply With Quote
Old 12-14-2014, 02:46 PM   #1011
Raman's Avatar
Do you mean biggest pinion? If you buy the new hop up gear adapter, the biggest spur is a 52t. In running that with a 72t spur.
Old 12-15-2014, 05:48 AM   #1012
For 48dp pinion, biggest I have fitted in is 38T. Using 65T spur
viktozzz is offline   Reply With Quote
Old 12-15-2014, 06:05 AM   #1013
Appreciate that. One more question if you know, whats the XC vs C difference on the blocks mean? Or better yet is there a chart some where explaing the differences? That would be even better.
Thanks again.
Old 12-15-2014, 08:09 AM   #1014
No I mean spur gear, I need a gear ratios of 7.6 for my small carpet track, I have got in 48dp 67t spur and 22t pinion which give me about 7.6,but can not get the pinion close to the spur gear so any help would be appreciated.
Old 12-15-2014, 11:43 AM   #1015
CraigMBA's Avatar
Trader Rating: 22 (100%+)
It will fit any sized spur you like.
The manual has some ratios listed in the back.
What on earth are you running that needs a 7.60 FDR?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 12-15-2014, 11:59 AM   #1016
13.5t motor, the lap time at the track are mid-low 7sec all the top runers are geared 7.7-7.4
Old 12-15-2014, 06:31 PM   #1017
CraigMBA's Avatar
The kit parts give you a FDR at like 6.81.
I'd get out the manual, and look at the gear chart, and use whatever sized spur comes in the kit.
Old 12-16-2014, 02:27 AM   #1018
Just got some tamiya pinions, funny how 67/22 48dp does not fit,but 66/22 0.6 does fit,suppose there just a little bit bigger.
Old 12-16-2014, 01:18 PM   #1019
Raman's Avatar
Thanks again.
The X marked blocks are narrower than ones that are marked just A, B. For example, XC is narrower than XB.
Have a look here
https://www.tamiyausa.com/articles/feature.php?article-id=412#.VJChoUa7nCQ
Old 12-16-2014, 01:25 PM   #1020
Have a look here
https://www.tamiyausa.com/articles/f...2#.VJChoUa7nCQ
Perfect, thanks for the link.
