Old 11-13-2014, 11:29 AM   #976
MikeR's Avatar
Trader Rating: 14 (100%+)
Originally Posted by viktozzz View Post
Have tried 2 different servo. Same issue. Removed servo and try by hand. Seems that it would be tight only near full lock. Have loosen the top stiffener abit, and seems to be still tight. If remove the top stiffener, then is ok. Now servos are on direct horn, no servo saver.
Both steering block is ok. Can have full movement though
Post a pic, might save 1000 words
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 11-13-2014, 11:51 AM   #977
Raman's Avatar
Trader Rating: 47 (100%+)
Mike, you still run your tb04?
Raman is offline   Reply With Quote
Old 11-13-2014, 12:22 PM   #978
MikeR's Avatar
It was too bound up so it's more like a TB03 now
Old 11-13-2014, 12:29 PM   #979
Raman's Avatar
Lol.. Won't ask you to share all your secrets..
Just glad to have you pro drivers back in this thread... Some set up help would be awesome
Old 11-13-2014, 01:12 PM   #980
gijoe64's Avatar
Trader Rating: 26 (100%+)
Not bad. Post your set up
I will post it on here this weekend.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is online now   Reply With Quote
Old 11-13-2014, 01:39 PM   #981
MikeR's Avatar
Yes, mad scientist shenanigans, hide the women and children lol.
Old 11-14-2014, 12:03 AM   #982
Trader Rating: 8 (90%+)
Is anyone else blowing through steering knuckles like crazy?
If I'm steering at full lock and knick the apex of the turn even slightly the bottoms of my knuckled break off or strip. I've literally gone through tons of them. I'm not even talking big hits here. I think I'm going to get aluminum knuckles and c hubs.
Boostgod is offline   Reply With Quote
Old 11-16-2014, 08:35 PM   #983
Ttt
Old 11-16-2014, 08:40 PM   #984
Raman's Avatar
Ttt
Switch to the Carbon reinforced version Tamiya part number 54568.
Never get Aluminium on suspension parts. They bend im crashes and also place stress somewhere; where there is plastic. Plastic atleast flexes and gives
Old 11-16-2014, 09:57 PM   #985
Ok. Issue solved. I had the shims of the arms done wrongly. Built it front to back, thus causing the steering linkage to have some binds.
viktozzz is offline   Reply With Quote
Old 11-18-2014, 01:25 AM   #986
I'm going through the carbon ones too. I have xray steering blocks in there now. They seem to be stronger.
Old 11-19-2014, 01:54 PM   #987
curious on some opinions/setups for this car ..... planning on asphalt, GT2 class for a TCS race
Carbon reinforced chassis or stock plastic one for flex characteristics ??
Shock oils ... 30 -35 - 40 - 45 .... whats the general opinion soft or med/stiff ??
Front Spool or Diff with 300,000 ... 500,000 ... putty ??
Appreciate any and all ideas on this - want to run a TCS race this summer in the GT2 class and some occasional summer runs. Looking for some good general setup ideas for running on the TCS tire and just overall.
Thanks for any input.
Robbob is offline   Reply With Quote
Old 11-20-2014, 09:34 AM   #988
gijoe64's Avatar
I'm running at Tamiya USA my fast lap time 14.7 with the TB04
TB03 Front Spool comes with 39T main gear
Rear gear diff with EVO 5 main Gear 39T
Shock oil I use TLR 40wt and 37.5 rear
Yellow springs on all 4 corners
getting the weight out of the drivetrain is very important for this car get all of the light weight parts for the rear diff and drivetrain.
Raymon Robinson
ARC, LRP Go Blue!!
Old 11-20-2014, 10:33 AM   #989
Raman's Avatar
Here is my set up for medium grip asphalt. I ran the car in two classes, RCGT (HPI X patterns) and Intermediate stock (Sorex 36 shores)
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 11-20-2014, 01:35 PM   #990
Thanks guys. Light weight driveline is on order plus the gears after reading earlier posts.
Appreciate the oil and spring info GIJoe64 and apprecaite the setup sheet Raman. Snows gonna be falling on the east coast soon so this is my winter project.
SEO by vBSEO 3.5.0
