Old 11-11-2014, 10:01 PM   #961
gijoe64's Avatar
Trader Rating: 30 (100%+)
Originally Posted by RC Passion View Post
What's the reason for using those TB03 goodies?
Using the tb03 main gears gives you a smoother drive train and also gets you fdr to 2.24.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 11-11-2014, 10:34 PM   #962
Raman's Avatar
Trader Rating: 51 (100%+)
TB03 has an fdr of 2.44
TB04 has an fdr of 2.5
Raman is offline   Reply With Quote
Old 11-11-2014, 11:01 PM   #963
gijoe64's Avatar
He's right sorry about that, my tb04 has a 2.44 fdr with the tb03 gears.
At tamiya my fast lap times are 14.6 that's on par with 418.
Raymon Robinson
ARC, LRP Go Blue!!
Old 11-12-2014, 02:57 PM   #964
Raman's Avatar
Not bad. Post your set up
Old 11-12-2014, 03:26 PM   #965
Anyone experienced abit of excessive tightness for the steering rack? Mine is having issues centering back to neutral, be it with servo saver or direct servo horn. Have loosen the top deck stiffener, and same issue too.
viktozzz is offline   Reply With Quote
Old 11-12-2014, 03:51 PM   #966
Disconnect the servo and check for binding. If the steering rack is binding. Go thu it and find the problem. You may have built it wrong. If its not binding, it's your servo or servo saver
Juan Aveytia is offline   Reply With Quote
Old 11-12-2014, 08:06 PM   #967
Raman's Avatar
If anything you should have slop in your steering that needs to be shimmed out!
Old 11-12-2014, 08:21 PM   #968
Dyingslow's Avatar
I am pretty sure I know the answer but just in case...
I am currently running the TB03 ring gear and Evo4 drive gear in the gearbox of my TB04. My car was noticable quieter and of course it makes spur and pinion optons easier for 17.5 motors. Now the question: Is it TCS legal to run the Evo4 small gear in the TB04 gearbox? I suspect the answer is no since the face of the Evo4 gear needs to be shaved down a bit to get the e-clip on but I am still hoping...
Dyingslow is offline   Reply With Quote
Old 11-12-2014, 08:24 PM   #969
I'd be pretty surprised if they even check it. Fred's the only one who can answer that question.
Old 11-12-2014, 08:31 PM   #970
Raman's Avatar
I purchased the 51255 TB Evo 5 Ring and pinion gears but have not installed it. Does the ring gear need modding or shimming to fit?
Old 11-12-2014, 09:15 PM   #971
Have tried 2 different servo. Same issue. Removed servo and try by hand. Seems that it would be tight only near full lock. Have loosen the top stiffener abit, and seems to be still tight. If remove the top stiffener, then is ok. Now servos are on direct horn, no servo saver.
Both steering block is ok. Can have full movement though
Old 11-12-2014, 09:15 PM   #972
Not sure. I used evo4 gears
Old 11-12-2014, 09:37 PM   #973
Raman's Avatar
Wait now I'm confused. Do the Evo 4 or Evo 5 gears fit? Or both?
Old 11-13-2014, 01:22 AM   #974
They all can be made to fit. The only gear that won't fit is the small bevel gear from the Evo3
Old 11-13-2014, 06:49 AM   #975
Wade....'s Avatar
Check:
Wheels rubbing on a-arm.
Steering rods hitting rear sus block.
Wade.... is offline   Reply With Quote
