Old 11-04-2014, 10:40 AM   #946
Chaz955i's Avatar
Originally Posted by Raman View Post
5mm width
Perfect, thank you!
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 11-05-2014, 09:47 PM   #947
bornox's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Wade.... View Post
So HPI silvers work every where?
I will have to grab a set.
ride red works too! i have to try HPI silver.
bornox is offline   Reply With Quote
Old 11-05-2014, 09:58 PM   #948
bornox's Avatar
i'm impress with my tb04. Easy to drive
Old 11-08-2014, 07:09 PM   #949
Raman's Avatar
Trader Rating: 51 (100%+)
Raced last night with new baseline set up and HPI silver springs. Car greatly improved.. I even posted one lap at 14.5 which was as quick as the amain winner.. I just need to become as consistent as him.
Set up attached.. this time I figured out how to flatten the pdf file..
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 11-09-2014, 12:40 AM   #950
Trader Rating: 8 (90%+)
Thanks for sharing your setup.
Boostgod is offline   Reply With Quote
Old 11-10-2014, 06:19 AM   #951
Default TB04 Pro Pics
Enjoy the pics of my TB04 pro. I'm using this car to compete in the Belgian Tamiyacup. In the TW class, we use bathtub chassis and Carson/Tamiya 16T motor.
Honda NSX Lighweight body has already served 1 season:
1420g ready to run:
Shorty setup with ESC on battery side. The ESC runs without fan:
Basic setup for easy to drive car on carpet:
- yellow spring allround with 35wt
- Tamiya A-type with medium insert (green)
- geardiff: front (100.000), rear (std from kit)
- 5mm ride height
- 2 camber
- droop: front 6, rear 5
alwin is offline   Reply With Quote
Old 11-10-2014, 08:25 AM   #952
Raman's Avatar
I updated the attachment.. I forgot to change the ride height, it is now correct..
Old 11-10-2014, 11:10 PM   #953
RC Passion's Avatar
Has anyone tried to treat all the tranny gears in any special way to reduce drag or is zero treatment preferred? Please share you thoughts. thx!
VBC
RC Passion is offline   Reply With Quote
Old 11-10-2014, 11:14 PM   #954
gijoe64's Avatar
Trader Rating: 30 (100%+)
There is no drag in my drivetrain, you have to shim the drivetrain properly.
Also I use the TB03 main front spool and rear gear diff ring gear.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 11-11-2014, 08:45 AM   #955
Raman's Avatar
Hey there my friend.. how goes it in SD?
I consider my drive line very free with zero drag. I built the car with the shims suggested in manual. I have now raced the car in more than 10 races and the original plastic gears are still in amazing shape.
I believe it partly has to do with the lube I use. I use a cycling product by Finishline called Ceramic Wax Lube. It forms a thin layer bond on the gears and keeps dirt off the gears. I use this on the ring and pinion gears, as well as mitre gears.
http://www.finishlineusa.com/product...ramic-wax-lube
Old 11-11-2014, 07:11 PM   #956
RC Passion's Avatar
Life is good in SD! I was up in Vegas last month for our wedding anni. It was just a 2 day thing, I'll hit you up next time when I'm out there! Maybe I'll acquire some IT clients there to get some more work and R&R (Racing & Relaxation)
I think i use the same lube for my MTB lol! Thanks! I'll look into it!
BTW Calraceway's T4T Dec 14th!
VBC
Old 11-11-2014, 07:14 PM   #957
RC Passion's Avatar
What's the reason for using those TB03 goodies?
VBC
Old 11-11-2014, 07:19 PM   #958
Let's keep the setups coming.
Is anyone beating the high end belt cars at their track, X-rays etc?
Old 11-11-2014, 09:21 PM   #959
Raman's Avatar
That's where I got the idea. I use it on my road bike as well.
We have one more race weekend here and then they will stop until next year... Probably when it warms back up. (March / April) not looking forward to the down time lol.
I wish someone would come up with an indoor carpet track. Otherwise I will have to invade the off-road track with my rallye chassis
Old 11-11-2014, 09:49 PM   #960
Raman's Avatar
Lower fdr... The tb03 ring gear is one tooth small and pinion one tooth larger.
