Old 10-31-2014, 07:07 AM   #916
SteveM's Avatar
Trader Rating: 133 (100%+)
Originally Posted by Chaz955i View Post
I have one of these on order and have no experience with the TB series or shaft cars in general. I am planning on running this car in USGT and will have to go to a different spur. I'd like to stick with 64p. Any suggestions on what brand spur will fit? I normally use Kimbrough or Xray but not sure if the bolt pattern is different for Tamiya.
Thanks.
I ran a Robinson Racing 64P spur on my TB-04 pro and it fit perfectly. I am sure almost any brand will fit. I like the RW Racing spurs as well as the 3Racing, Robinson and Kimbrough.
SteveM is offline   Reply With Quote
Old 10-31-2014, 07:18 AM   #917
Chaz955i's Avatar
Thanks Steve!
At The Gate Bizzos
Chaz955i is offline   Reply With Quote
Old 10-31-2014, 08:30 AM   #918
Originally Posted by Raman View Post
Juan,
Take a look at post 895 on previous page. My set up is attached as PDF file. I'm presently on phone, so I can't re-attach to this post.
The only changes to set up since last race are (which are reflected in set up sheet): damper oil to 45wt and rear inner block from XA to XB.
When I open your PDF. It shows a blank set up sheet. Honestly, just find wilcks or Reinhards carpet set up and copy it to your car. It will get you in the ball park. And if you only have Tamiya springs. Use whites up front and blues in the rear. Usually 40wt oil. Check for binding, slop and tweak. No matter how good your set up is, if you have major slop, binding or the car is tweaked. Your car will handle like crap
Juan Aveytia is offline   Reply With Quote
Old 10-31-2014, 08:34 AM   #919
Trader Rating: 8 (90%+)
Where do you find their setups?
Boostgod is offline   Reply With Quote
Old 10-31-2014, 03:39 PM   #920
Raman's Avatar
Trader Rating: 51 (100%+)
I don't know why PDF does that. Probably have to save it different way. I prese you have the whites on front and blues on rear.
Slop has been taken out and no binding. Tweak.. Do plastic chassis' tweak?
You mean to copy their set up for 418 to TB04? Also I run on asphalt, so im assuming you mean copy asphalt set up?
Raman is offline   Reply With Quote
Old 11-01-2014, 09:58 AM   #921
Wade....'s Avatar
I am in the hunt for a fast consistent setup for my TB04ProV2. I race on indoor carpet Med grip usually. I have three race days on the car and I feel the car has too much steering and is inconsistent. My fast laps are on par but for my driving style the car is too loose. Also my high speed rear end stability is low, I think due to the molded rear wing on my Audi R8 body.
I need to do a few things to sort out the slop in my steering that I think is adding to the inconsistency. New servo gears being one.
I will update as I progress with this car and get closer to a good setup.
For now I am focusing on getting a proper rear wing and eliminating steering slop.
Anyone else notice all of the ball studs on this car are ~4.7mm not 5mm? Things are free but a bit sloppy right after a build.
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 11-01-2014, 10:15 AM   #922
vivo quevas's Avatar
Trader Rating: 18 (100%+)
You didn't mention it is your car over steering on corner entry or mid corner or exit. If it is on entry go with less rear droop. Is it too much steering or the car spins out? You need to expain what you need or what end of the car you need to fix First!
Awesomatix A800 USGT, Awesomatix 800 VTA, , Tamiya Euro Truck, CRC WTF1
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
vivo quevas is offline   Reply With Quote
Old 11-01-2014, 10:31 AM   #923
Raman's Avatar
On Petitrc there are a couple of setups for the TB Evo6. Probably a good baseline for us to use, since it uses the same suspension and diffs
Old 11-01-2014, 04:41 PM   #924
For asphalt. I use hpi silvers all around. 40 weight oil. B-B blocks up front and XA-D or E blocks in the rear. LTC-r light weight body. 6-5 droop. 1 1/2-2 degrees camber. 3k rear diff oil and spool up front. Long camber links all around fairly level. Run hard suspension parts. Get rid of the soft plastic stuff.
Hope this helps
Old 11-01-2014, 04:57 PM   #925
Wade....'s Avatar
Any suggestions on springs for carpet?
Old 11-01-2014, 05:34 PM   #926
Hpi or hotbodies silver or pinks. Yokomo silver and pinks are good too.
Old 11-01-2014, 08:51 PM   #927
Wade....'s Avatar
Yea I guess to clarify the car had too much steering for my tastes on entry and mid corner. Car had only a slight push on exit.
I think I was getting inconsistency and possibly some snatchy inputs from slop in my steering and worn servo gears. I want to fix this issue before addressing anything else.
Old 11-01-2014, 08:51 PM   #928
Wade....'s Avatar
So HPI silvers work every where?
I will have to grab a set.
Old 11-01-2014, 10:39 PM   #929
If the car is rotate to well on corner entry I would take some reason droop out of the car. The car could be transferring weight to the frontend when you let off or apply brake on entry.
Old 11-02-2014, 07:36 AM   #930
Wade....'s Avatar
DP
