Tamiya TB04 Pro
#886
here is mine after the build. I have literally one day of track practice on it. Hoping to get tonnes of run time in, but would hate to have to wait 2 weeks for parts if I broke something. Im not the best driver, but Im 30 years old, so Im not gunning it into walls at WOT.
#887
Does anyone happen to know what parts are required to convert a tb04 pro into a tb03? Not that there is anything wrong with the tb04 but I think I would like to try the tb03 just for the heck of it.
I know I need a chassis, motor mount, propeller shafts, k parts tree, and a drive shaft
#888
Pretty much a whole Kit
Would be better off finding a used kit
#889
I thought about buying a plain tb03 from tower but I figured that I would end up buying a lot of the same parts I need to convert my tb04 as upgrades to the stock parts
#891
I raced last night in RCGT. Usually I have difficulty with the rear end coming loose mid turn. Last night was quite different. Car was really twitchy and sensitive. Front seemed to turn in much faster than rear, but rear was still fairly planted. I ended up going to C/C in front to make the steering lazy, and laying down the shocks. Car improved but still was not to my liking.
I wish there were more asphalt set ups for this car
#892
Does anyone have a goos carpet setup for this car that isn't too tail happy?
#895
Im working on an editable set up sheet. In the mean time here is my current set up so we can compare notes.
Something odd I noticed with this car.. Im using the TRF 84325 springs. The maximum I can lower the car is to 6.5 mm in the rear and 6 mm in the front. I measured my white Kit springs and they are the same length. Needless to say, I am a bit confused..
#896
#897
I also measured the springs that came with the kit and the TRF springs. They are the same height.
#899
It appears I need to change to shorter springs.. which begs the question, why the heck did they supply the kit with the standard TC springs and not shorter springs?
