Old 10-03-2014, 09:31 PM   #871
Originally Posted by tobyzhang View Post
A - A block in the front seems very interesting for stock setup. Does that make the car feel twitchy on turn in? Debating between pro ii and ta06r right now. Does anyone have experience with both?
I have both. You can test drive at Tamiya track some time
(but not tomorrow because it's going to be hot as hell and I ain't going )
On my TB04 pro II it calls for 1A blocks in the manual, but with DCJs and 44mm shafts I *had* to go to 1C blocks. Maybe because I have Alum cups on it and that's not a normal thing to do when using DCJs...?
torg is offline   Reply With Quote
Old 10-03-2014, 09:51 PM   #872
TB03Racer09's Avatar
torq, I'm running 1A blocks in the front of my tb04 pro II as well as DCJ's. No need to change to 1C. I think its the alum cups
cplus, a racer at the track let me try those hudy pins but could't use it because there are no center holes in the chassis.
TB03Racer09 is offline   Reply With Quote
Old 10-03-2014, 10:31 PM   #873
Raman's Avatar
Trader Rating: 50 (100%+)
Depends on what class your running. In 17.5 and 13.5 TA06R suffers from some drive train power loss due to the twin belt, and additional counter gear drive line set up. On these classes the TB04 II is more efficient, (yes even though it's shaft driven). The TA06 however does very well in mod class.
Raman is offline   Reply With Quote
Old 10-04-2014, 08:24 AM   #874
IAmGreatDane's Avatar
Originally Posted by Raman View Post
If you are changing from A/A to C/C, you don't need to change to longer shafts. However if you changed from A/A to F/F which would be the widest, you may theoretically need to change to longer drive shafts
Thanks, Raman :-)
Best Regards,
I Am GreatDane c'',)
IAmGreatDane is offline   Reply With Quote
Old 10-05-2014, 10:51 AM   #875
tobyzhang's Avatar
Will do!
I'm currently seeking a replacement for my ta05v2 for next next season because part support will become harder and harder. I'll let you try my ta05 too. It's a pretty proven setup and just needs to be lightened as of this point.
tobyzhang is offline   Reply With Quote
Old 10-06-2014, 12:27 PM   #876
Raman's Avatar
I run DCJ with front spool that has the steel outdrives and still use the 1A blocks.
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Old 10-06-2014, 12:36 PM   #877
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
well
there was a guy in japan was running TA06 in GT1 and Gt2 and he won
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 10-06-2014, 12:51 PM   #878
CL
CL's Avatar
Trader Rating: 32 (100%+)
Originally Posted by OVA View Post
well
At the Tamiya World Championship in Japan, each chassis has a different FDR limit.
Believe in yourself!
CL is offline   Reply With Quote
Old 10-06-2014, 01:38 PM   #879
tobyzhang's Avatar
true, the gearing limit makes drive line efficiency secondary in terms of competitiveness. In those conditions I think the balance of ta06 shines through. I think I'll go with the TA06R
Old 10-09-2014, 09:20 PM   #880
Trader Rating: 8 (90%+)
Hey guys, I own a tbo4 pro 2 that I'm learning how to race at my local track. I was just wondering which parts you guys have broken and what I should order ahead of time. My lhs doesn't stock anything for my car.
Boostgod is offline   Reply With Quote
Old 10-09-2014, 10:09 PM   #881
vivo quevas's Avatar
Trader Rating: 18 (100%+)
C hubs and spindle carriers. Also when you break those part you lose the spindle carrier bushings. Typically what breaks on Tamiya cars!
Tamiya/Exotek EXO6 USGT, Tamiya TB03 GT3, Exotek FR1V2
Roche Rapid 1/12, XRay Speed Merchant WGT
http://localrcracing.freeforums.org/
HobbyTown Fresno, Ca. McAllister Racing, Visa/MasterCard's
"Take an early lead and extend it".(Fast Eddie Janis)
vivo quevas is offline   Reply With Quote
Old 10-09-2014, 11:04 PM   #882
9and3's Avatar
...which parts you guys have broken...
On my son's Pro II, the front shock's lower ball mount (the one that goes into the a-arms) loosens and has stripped the threads from the a-arm. The ball won't stay in place for more than half a lap. Since he's a bit rough on the car, I swapped to aluminum arms in hopes of avoiding this in the future. If this happened to me, I'd probably get an extra set of original a-arms and practice driving more.
Actually, the plastic tree-parts aren't that expensive--why not just get all the major ones?
9and3 is offline   Reply With Quote
Old 10-09-2014, 11:07 PM   #883
I haven't broken anything om this car, although I haven't crash much with it
Old 10-09-2014, 11:09 PM   #884
So just the C hubs? Should I get aluminum ones or just spare plastic? any other items?
Old 10-09-2014, 11:16 PM   #885
The stock tb04 hubs are made from regular, flexible plastic and won't break often. If your going to buy spares, get the trf418 c hubs, which is the same shape except molded from carbon reinforced plastic. They are more brittle but stiffer, giving more tuning options
