Old 07-29-2014, 10:54 AM   #811
Raman's Avatar
Trader Rating: 51 (100%+)
I was hoping to have this in hand by today (Thursday), build it and race it tomorrow night. However it's been sitting in the LA sort facility since yesterday. Doesn't seem likely, will most likely have to use the BD7 RS which I planned on selling. Hopefully I won't break any parts that I don't already have lol.
Raman is offline   Reply With Quote
Old 07-31-2014, 01:07 PM   #812
Trader Rating: 69 (100%+)
Markus is offline   Reply With Quote
Old 08-08-2014, 10:40 AM   #813
Raman's Avatar
I'm 90% done with Pro II build. Did a search on here for set ups.. Nothing comes up. Nor on petitrc.
Does anyone have an asphalt medium grip set up they can post?
Old 08-08-2014, 11:01 AM   #814
PutAwayWet's Avatar
Having built and raced many a Tamiya, I'd say the kit setup would be a stellar start for medium grip asphalt. Seriously. Start there
Todd Mason
Seattle RC Racers
The world ends when you're dead. Until then, you got more punishment in store.
Stand it like a man, and give some back. --Al Swearengen
PutAwayWet is offline   Reply With Quote
Old 08-08-2014, 11:37 AM   #815
Raman's Avatar
The kit set up has set screw out by 2 mm on arms. When I put the car on set up blocks, that was a droop setting of 5+.
I reduced it to 2 in back and 3 in front.
What's everyone else running for droop?
Old 08-09-2014, 03:11 AM   #816
TB03Racer09's Avatar
I'm running stock droop settings on mine.
I purchased #42216 Tamiya Double Cardan Joint Shafts Set for the front of my TB04V2 to free up the front and reduce the sounds when turning. I also bought a pack of 3mm shims of .1, .2 and .3 thickness to remove any slop that the car may develop over time.
I think I have officially given up on touring car bodies, I just don't enjoy running body shells I don't like the look of. So I have been running a Tamiya HSV-010 body, which brings race ready weight to 1540g. Despite this, I have no plans to buy any lightweight parts because it seems to handle just fine.
Has anyone else been running their tb04?
TB03Racer09 is offline   Reply With Quote
Old 08-09-2014, 08:07 AM   #817
Raman's Avatar
I never run / race TC bodies. The day run those is the day I sell everything and leave this hobby. I race these cars because I can't afford to race the real thing. So a generic looking body is worthless to me.
Do you have a way of measuring your droop using droop blocks or from axle spindle down.
The kit set up says 2mm of the screw showing. Maybe I'm measuring wrong or my calliper is off, but it's too much droop
Old 08-09-2014, 09:25 AM   #818
metalnut's Avatar
Trader Rating: 36 (100%+)
Hey Raman,
I hear you on the scale bodies, that is why I'm not keen on running TC myself, I stick with VTA and other more realistic classes. As for droop, I can't remember if you said you already have droop blocks and a gauge? If not, they're a great investment. I can't remember if you're still overseas or not, but I can recommend Eds Tools. They make the Hudy tools (and others), so it's high quality but for half the price.
I recommend these blocks: http://www.absolutehobbyz.com/produc...oducts_id=6607
And one of these two gauges, depending on how fine you want to get and what range you'll be in (I have both): http://www.absolutehobbyz.com/produc...oducts_id=6608 and http://www.absolutehobbyz.com/produc...oducts_id=6611
I just wish someone told me about these before I bought the Hudy branded ones
Team Nervous | Team Scruffy | Team Orange
"If you ain't first, you're last!"
- Ricky Bobby
metalnut is offline   Reply With Quote
Old 08-09-2014, 10:05 AM   #819
cementsurfer86's Avatar
A quick and easy way is to use a ride height gauge. Set your car in a setup board in race trim. Tires, batt, everything. Measure your ride height. Then pick up the front or rear of your car (whichever end you're measuring) until the tires just touch the board. Now measure with the gauge again. There's your droop. Simple and easy.
Jesse Anderson / JROY386 / R_
ThreeEightSix / Sticky Kicks RC
theRACERunderground - "Budget Champions"
www.theracerunderground.blogspot.com
cementsurfer86 is offline   Reply With Quote
Old 08-09-2014, 10:44 AM   #820
Raman's Avatar
Originally Posted by metalnut View Post
Hey Raman,
I have droop blocks / gauge set by dynamite
http://www.amain.com/Dynamite-Precision-Droop-Gauge-w-Blocks/p58986
That's what I used to measure the droop after following instructions. The arms were +5 or higher. So I adjusted then to 2 in rear and 3 in front like my other cars as a staring point.
I was just finishing and attaching dampers and noticed the that arms need to go up a bit to connect to dampers.. So my droop settings off the blocks of 3 and 2 are not sufficient. So I'm totally confused now lol.
Last.. I like the transponder idea but where is the stay? Is it not included in the kit?
Old 08-09-2014, 01:26 PM   #821
heretic's Avatar
I doubt it very, very much.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 08-09-2014, 01:38 PM   #822
metalnut's Avatar
That's what I read, but maybe not, who cares? They are the same design (compare them, and Arrowmax as well), same spring steel (that's a fact), for half the price? I've had my Eds wrenches and tools for a long while, use them daily, love them all.
- Ricky Bobby
Old 08-09-2014, 07:40 PM   #823
http://www.amain.com/Dynamite-Precis...-Blocks/p58986
I would go back to the stock droop settings and then go from there.
The transponder mount is designed to accommodate the AMB handout transponders, which have a cylinder structure that goes through the hole in the chassis and is held on by a body clip. If you check the manual, you will see exactly what I mean.
I'm using the rc4 hybrid personal transponder so I just double side tape it to the top wall of the box. Since this transponder is so small, it leaves alot of space for lead weights if you need any.
Old 08-09-2014, 08:05 PM   #824
Raman's Avatar
I'm happy I was cheap and kept my double cardan cvds from my 416. Now they're sitting pretty in my TB04 Pro II
Old 08-11-2014, 08:41 PM   #825
I have since installed a tornado cooling fan from yeah racing. it kept the motor temp to around 55 degree C monitor by Sanwa RX461 with temp sensor. it is this way no matter how it run the car now under all weather. the fan is not blowing directly at the sensor (maybe around 150 degree angle away). before the fan, the motor may get heated to 75 degree C under bashing runs of maybe 20-25 min.
I also checked the mesh again due to some sound from gear box. the ring gear broken 1 single tooth. I will bashed all up before changing to carbon reinforced version. As I have 2 more normal sets of non carbon gears.
spyder_696 is offline   Reply With Quote
