Old 07-10-2014, 02:30 PM   #691
Cadman1981's Avatar
Hey guys, to lower the FDR with the 39t bevel gears on the diff, all i need are 2 Tamiya 51255?
Can i use the Tamiya 54125 - front spool on a Tb04?
Arc R10 2015
Awesomatix A700L
Exotek F1R3
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-10-2014, 03:57 PM   #692
TB03Racer09's Avatar
Cadman, I think the tb03 spool works but there is also a tb04 specific spool
Raman, the shock caps and its threads are shorter than the old trf shocks
TB03Racer09 is offline   Reply With Quote
Old 07-10-2014, 03:57 PM   #693
Double post
Old 07-10-2014, 04:33 PM   #694
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Hi
I just pick up the Carbon reinforced lower deck...
Question: will it make difference if I change my stock lower chassis over to carbon reinforced chassis?
our out door track is med grip and medium size track...
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 07-10-2014, 05:39 PM   #695
Cadman1981's Avatar
What's the TB04 spool part#? or is it the one way?
Didn't answer how people are putting the 39t gears in the kit...
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 07-10-2014, 06:41 PM   #696
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by OVA View Post
Hi
Before you run it, can you put a straigh edge on it and see if it's straight? My kit one was impossibly warped.
And, it appears Tamiya is listening....new for august..
 54601  TB-04 Aluminum High-Geared Motor Adapter
CraigMBA is offline   Reply With Quote
Old 07-10-2014, 09:18 PM   #697
Trader Rating: 69 (100%+)
You can use the TB03 front spool with the TB04 ring gear. You have to add shims for the width.
The TB04 oneway set is actually both. it's a oneway that you can put pins with a rubber oring to lock into a spool. I have it and it is fairly heavy.
Go with the TB03 direct coupler (spool). I haven't needed a one way in a lot of years.
Markus is offline   Reply With Quote
Old 07-10-2014, 09:33 PM   #698
Cadman1981's Avatar
But what about lowering the car's IR? I'm going through the thread, i keep reading about putting 39t gears on the diffs, but i can't find part numbers
Update: http://www.rctech.net/forum/12737953-post340.html - Post 340 mentions the bevel gear from the TB03 one way, can that gear be purchased separably?
Update 2: Part #51255 (39t Evo5 one way gear) bolts right up to the gear diff - Post 351 - http://www.rctech.net/forum/12762006-post351.html
Arc R10 2015
Awesomatix A700L
Exotek F1R3
Old 07-10-2014, 09:58 PM   #699
#54592 is the number for the tb04 specific spool, that has 40t ring gear
If your going to change the gear to 39t, might as well get the tb03 spool diff and use shims to make up the space. You can purchase the tb03 gears seperately too #51255
You can achieve an fdr of 2.29 by using #51109 (17t/39t), you will have to remove the lip on the bevel gear so you can fit the e-clip
Old 07-11-2014, 02:08 AM   #700
97Clemow's Avatar
This help?
http://www.rctech.net/forum/members/...20-pinion1.jpg
Tam 51109 or TAM 51110 for 17 tooth pinion
TAM 51255 39 tooth for gdiff or TAM 51256 39 tooth for balldiff
97Clemow is offline   Reply With Quote
Old 07-11-2014, 02:15 AM   #701
Originally Posted by 97Clemow View Post
looks like you shaved back the actual teeth too, can it be avoided?
Old 07-11-2014, 02:44 AM   #702
97Clemow's Avatar
no it cant be avoided
the picture makes it look worse than it is. should have cleaned the dust off
before the picture
use quality 400 no-fill sandpaper on a piece of glass, like doing
a ball diff rings. takes 10 min or so of careful circular sanding and a jeweller's file, 3mm to open up the hole so the shaft fits just.
http://www.rctech.net/forum/members/...21-pinion2.jpg
Old 07-11-2014, 02:49 AM   #703
Looks much better than I originally thought
Old 07-11-2014, 02:54 AM   #704
97Clemow's Avatar
cheers mate,
had 17 tooth in my gears in my evo 5 almost a year no worries
Old 07-11-2014, 03:08 AM   #705
Simmi's Avatar
Originally Posted by e58105419 View Post
In DB-02 manual,the 20T alu bevel gear(19804570) use 2x9 shaft (19808017).
Real can use 2x9.8 shaft (51444) on this 20T alu bevel gear.
Very interesting, thank you
Tamiya Racing Factory: TRF 419X
Team Yokomo YZ2 CA
Simmi is offline   Reply With Quote
SEO by vBSEO 3.5.0
