Old 07-04-2014, 11:14 AM   #676
Pics like that make me happy I bought the kit, thanks!
Hugo
HugoW is offline   Reply With Quote
Old 07-04-2014, 07:58 PM   #677
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by TB03Racer09 View Post
I've thrown away the sprues already and can't find anything on my chassis, but from this picture I think you will all agree that it is cfrp chassis. However the suspension parts are all normal plastic
Didn't run into any problems in the build, the hex head screws are awesome. Now its time to find a battery
Spec sheet does say FRP, so I would hope it was included
http://www.tamiyausa.com/items/radio...ssis-kit-84382
Are they oil gear diffs front AND rear or just rear?
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 07-04-2014, 08:50 PM   #678
TB03Racer09's Avatar
Both front and rear have oil-filled gear diffs. The rear I'm using the oil Tamiya included in the kit, the front I'm using 100k oil for a semi spool effect.
TB03Racer09 is offline   Reply With Quote
Old 07-04-2014, 09:03 PM   #679
RAL
RAL's Avatar
Trader Rating: 59 (100%+)
I would heavily suggest using this stuff for the front diff.
http://www.teamgravityrc.com/store1/...29&id=26632441
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 07-04-2014, 10:18 PM   #680
I used 100k because that's what I had on hand (I use it on my rc8.2e). It makes me wonder why anyone will use a spool diff when there are these super thick oil available
Old 07-04-2014, 10:25 PM   #681
Originally Posted by Sith Lord View Post
Spec sheet does say FRP...
Yes, it does. But that doesn't clear CARBON fibre or GLASS fibre. The original is glass, the new one is carbon. The part in the Pro II manual is the glass part number.
Hugo
Old 07-04-2014, 10:28 PM   #682
Thought I might share some pictures. Car is ready to race, needs body, battery and tires
Old 07-04-2014, 10:39 PM   #683
Nice. What is the purpose of the black sleeves on the wiring?
Cheers,
Hugo
Old 07-04-2014, 10:47 PM   #684
Sith Lord's Avatar
Hugo
Ahhh, gotcha
Old 07-04-2014, 11:28 PM   #685
Cheers,
Hugo
They have no real purpose other than looks. The esc I'm using (hobbywing justock) has presoldered wires and the solder the factory use cannot be removed with a soldering iron. I decided that its easier for me to just put this black sleeve than drill out the old solder and solder black wires on.
I took the car for a quick drive outside. Although it's noiser than the ta06, the sound is actually nice (not screechy) and it seemed to get quieter as everything started to settle in.
Old 07-05-2014, 09:01 AM   #686
Raman's Avatar
Trader Rating: 56 (100%+)
Did they update the motor mount or is the exotek one still necessary to get the fdr down?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 07-05-2014, 09:16 PM   #687
You still need the exotek mount
Old 07-10-2014, 08:57 AM   #688
I'm sure this has been asked before but i'm new to this car and i see in the instructions, it has two gears. I wanted to know if there was a spool for this car?
DOTMAN is offline   Reply With Quote
Old 07-10-2014, 09:27 AM   #689
sosidge's Avatar
Looks like Tamiya will be releasing their own motor mount soon.
Old 07-10-2014, 01:10 PM   #690
Raman's Avatar
Regarding the dampers:
Are they touring dampers with lower profile threaded section and shock cap? Or are they the M chassis damper bodies?
