Old 06-26-2014, 01:27 PM   #616
CL
CL's Avatar
Trader Rating: 32 (100%+)
FYI: Rcmarket has it for $167 + shipping.
More racing and less typing!
CL is offline   Reply With Quote
Old 06-26-2014, 01:38 PM   #617
Raman's Avatar
Trader Rating: 56 (100%+)
Great price.. Anyone have experience with RcMarket?
Raman is offline   Reply With Quote
Old 06-26-2014, 03:44 PM   #618
Yep, ordered many things over the years. I have no problem buying cars from them.
Qatmix is offline   Reply With Quote
Old 06-26-2014, 07:59 PM   #619
TB03Racer09's Avatar
Just ordered my tb04 pro v2 from stella, $226USD/$250AUD
TB03Racer09 is offline   Reply With Quote
Old 06-28-2014, 02:05 PM   #620
OVA
OVA's Avatar
Trader Rating: 77 (100%+)
how free is the drivetrain compare to Tamiya ta05?
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 06-28-2014, 04:03 PM   #621
It takes some serious shimming. And change to 39t gear to free the drivetrain up. But it's very free once shimmed properly.
Juan Aveytia is offline   Reply With Quote
Old 06-28-2014, 05:38 PM   #622
OVA
OVA's Avatar
Hey Bud
how are you?
question TB04 PRO VER2 is on the way...
I still to pick up the 39 gear set?...It there any good set up any where here ?
what is a good bodies for TCS? Thanks
Old 06-28-2014, 05:59 PM   #623
Going to order 3, 5, 6 and 10mm shim sets, thickness from 0.1 to 0.3mm. Going to cost $17, but considering its a total of 160 shims and that they can be used for any car, should be worth it.
Can I use the big ring 39t gear with the stock small tb04 one?
Old 06-28-2014, 06:23 PM   #624
Everyone is using the 39t gear. I think it frees up the drive train some
Old 06-28-2014, 06:24 PM   #625
Hey Bud
how are you?
As heavy as the car is. I would try to stay with a kight weight body. Try a 417/418 set up that works at the track. That should get you real close
Old 06-28-2014, 06:30 PM   #626
OVA
OVA's Avatar
what is the stock gear diff out drive is steel or plastic?
Old 06-28-2014, 09:10 PM   #627
Trader Rating: 71 (100%+)
they are steel.
Markus is offline   Reply With Quote
Old 06-28-2014, 09:11 PM   #628
Plastic. That's all I have. I want the Evo6 parts to put in it. (Lighten up some). Haven't had any problems with it. 2k or 3k to start
Old 06-29-2014, 08:23 PM   #629
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Will the TB03 ball diff work on the TB04? I see that there is a TB04 specific ball diff. If I'm not mistaken, both cars share the same gearbox parts no? I'm thinking the only difference is a 40T gear packaged with the TB04 diff?
Racing4Evo is offline   Reply With Quote
Old 06-29-2014, 08:32 PM   #630
Why do you want to run a ball diff?
cplus is offline   Reply With Quote
