Old 05-22-2014, 07:30 AM   #601
Hi all, can some one tell me what does tamiya front one way direct drive means. I just bought a tamiya front one way for my tb04 (non pro) and the instruction says insert 2 pins to make it direct drive. Please tell me what does it mean. Thanks
spyder_696 is offline   Reply With Quote
Old 05-22-2014, 07:32 AM   #602
Turns the oneway into a spool or locked diff
Juan Aveytia is offline   Reply With Quote
Old 05-22-2014, 07:36 AM   #603
Thanks for the quick reply. Sorry as I just new into this hobby. If I don't insert these 2 pins. It will work as front one way. Won't the cup drop out? Please be so kind to advise again. Just want to be sure as I cannot understand how it work. Before I install it into the front gear box.
Old 05-25-2014, 07:02 AM   #604
Originally Posted by e58105419 View Post
Used 6.5t&LRP80999(3-6)(boost+turbo) the 51547 20t gear is broken only 1-time battery. ,but the 16T/40T bevel gear is ok~
Now
I use alu 20T center miter gear.100% fit.
It is 9804570 for DB-02 .
Hi, can u pls share which website u get the DB-02 20t miter gear.
My stock plastic miter gear both broke today.
I tried a few website also cannot locate this DB-02 20T miter gear.
Old 05-26-2014, 09:52 AM   #605
hi....
on TQ RC RACING
tqrcracing.com/shop/product_view.asp?p_id=7051
e58105419 is offline   Reply With Quote
Old 05-26-2014, 03:59 PM   #606
http://flic.kr/p/ntwnNM
hi....
on TQ RC RACING
Hi, thanks for your reply. I ordered mine from my LHS already. Installed fresh plastic one until the DB-02 one arrives. Place 0.6mm shim per miter gear. Hope these plastics one last till my steel one arrives..
Old 05-31-2014, 09:30 PM   #607
Nice fix. Make sure the gears are shimmed with very little play. Or you will strip gears. Now that those gears are metal. It could cause other problems if shimmed incorrectly
Hi, I stripped already 2 sets of plastic miter gear. Ordered DB-02 gear is still a month away. I already shimmed my 2 sets of miter gear very little play. Why is still striped, any comments. The first set last at least 6 months. The second set last less than 3mins even with proper shimmed. Hope some one can help correct my problem. Thanks
Old 05-31-2014, 09:37 PM   #608
The spur gear holder shaft. You need to shim it so it's free spinning with no side to side movement. And repeat on the other areas with small gears. That will fix your gear problem
Can u post a pic about this side to side movement. I added 0.6 shim per side to ensure very little play. Still my new miter plastic gear stripped under 3mins. The previous set without shim lasted 6 months. The only new change was the front one way. But it's so far away will it affect the miter gears. Thanks
Old 06-03-2014, 12:47 AM   #609
TB03Racer09's Avatar
http://www.rcmart.com/tamiya-54584-t...t-p-55790.html
http://www.rcmart.com/tamiya-54585-t...r-p-55791.html
Any guess how much weight these can save?
TB03Racer09 is offline   Reply With Quote
Old 06-20-2014, 06:49 PM   #610
TB04 Pro II should be out in a week or two... I can't wait yo
Ben Had is offline   Reply With Quote
Old 06-20-2014, 09:21 PM   #611
Raman's Avatar
Trader Rating: 56 (100%+)
Tower says late July. I haven't seen it listed at Banzai, Stella, or RCmart
Raman is offline   Reply With Quote
Old 06-25-2014, 03:48 PM   #612
RCmart $209 w\o shipping
Stella $190 w/o shipping
DON'T BUY 'EM ALL
Old 06-25-2014, 04:33 PM   #613
Raman's Avatar
I emailed Banzai with Stella's price hoping that they will list it and beat their price
Old 06-26-2014, 04:13 AM   #614
Everytime I order from banzai they are out of stock, by the time they tell me and I get my refund they will be out of stock everywhere else too. It will cost $280AUD shipped from rcmart and $240AUD shipped from stella, so I think I will get one from the latter
Old 06-26-2014, 10:02 AM   #615
Raman's Avatar
Have placed multiple orders in the past 3 years and never had a problem with Banzai.
Pricing for the US is looking like this:
Stella $190 +$ 40 shipping = $230
Banzai $197 + $38 shipping = $235 (banzai's prices are in yen and fluctuate with exchange rate)
Towerhobbies $299 - $45 (tower club members) $254 (shipping is free but stock is estimated for late July)
