Old 05-11-2014, 12:47 PM   #586
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Not to be snarky, but they haven't released it yet, the parts aren't widely available if at all, so nobody really knows for at least a couple of weeks.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 05-11-2014, 03:31 PM   #587
I'm speculating based on the detailed description, images plus the hop up parts list that has been released.
If in wrong, it won't be by much.
cplus is offline   Reply With Quote
Old 05-11-2014, 06:11 PM   #588
TB-04 PRO II CHASSIS KIT
Item No:84382
2014年 6月28日(土)ごろ発売 31,104円(本体価格28,800円)
2014/06/28 Release in Japan / Yen : 28800
www(dot)tamiya.com/japan/products/84382/index.htm
TB EVO.6 CHASSIS KIT
Item No:84379
2014年 6月28日(土)ごろ発売 60,264円(本体価格55,800円)
2014/06/28 Release in Japan / Yen : 55800
www(dot)tamiya.com/japan/products/84379/index.htm
e58105419 is offline   Reply With Quote
Old 05-13-2014, 05:15 PM   #589
I love you guys Thanks...
Ben Had is offline   Reply With Quote
Old 05-14-2014, 04:35 AM   #590
HI, I had the same problem of yours. Please let me know if after you fit the DB-02 bevel gears you had any kind of issue. I am thinking of buying the same DB-02 bevel gears to put in mine. Thanks
Luizhoc is offline   Reply With Quote
Old 05-14-2014, 07:17 AM   #591
The spur gear holder shaft. You need to shim it so it's free spinning with no side to side movement. And repeat on the other areas with small gears. That will fix your gear problem
Juan Aveytia is offline   Reply With Quote
Old 05-14-2014, 12:35 PM   #592
Chaz955i's Avatar
Will this car take standard sized packs like used in the belt drive touring cars or does it require a special pack due to the tub chassis? Thinking of getting this car for USGT but don't want to be stuck with packs that can't be used in my other cars.
Chaz955i is offline   Reply With Quote
Old 05-14-2014, 04:38 PM   #593
Std hard case lipo batterie are fine.
Old 05-14-2014, 05:12 PM   #594
Chaz955i's Avatar
Thanks, appreciate the quick response.
Old 05-16-2014, 08:04 PM   #595
Thank you for the hint. I will try this. Yesterday i went to a local hobbyshop and bought a bevel gears set. Actually i am using a too powerfull motor ( yokomo 3.5t ) on 3s lipo, this is the other reason i was looking for metal gears.
Old 05-16-2014, 08:59 PM   #596
TB03Racer09's Avatar
I think 3.5t on 3s is too much for this car but let us know how it goes
TB03Racer09 is offline   Reply With Quote
Old 05-16-2014, 10:29 PM   #597
3.5t!!
Way too much motor on 2s let alone 3s I expect!
Be interested to hear how you go and how airborne it gets
Old 05-17-2014, 08:44 AM   #598
Raman's Avatar
Trader Rating: 49 (100%+)
A 3.5 at 2S is rated at 10k rpm. Can a 3.5 even take 3S?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 05-17-2014, 11:14 AM   #599
10000kv motor at 11.1v = 11100rpm YIKES
Old 05-19-2014, 05:13 AM   #600
I've tested it last weekend after the adjustments, the speed is insane!!! I didn't reach the top speed, I was concerned about the narrow street, but once again the plastic bevel gears were smashed lol... by the way, the TB04 is a great car for handling. I've ordered a DB-02 aluminium bevel gears set in order to fix the problem. Later I will post a video.
