Old 05-04-2014, 03:50 AM   #571
TB03Racer09's Avatar
Originally Posted by Qatmix View Post
Will the exotek mount be available in the UK?
I have a wide range of Tamiyas, the TB04 is a great car but its soooooooooooooooooooooo heavy. Its 100g over the minimum weight. This does make it handle well with the lower turn motors, but you have to gear it a little different to make up for the extra weight. I mainly race my 418 and use the tb04 as a back-up or just race it when I fancy a change.
Lap times are slower but the extra weight makes it slower on direction change, and there are no roll bars for it yet, that will help as the set-up range is limited without that for better corner speed.
If it was my main ride I would spend a bit more on the car to make it skinny (Carbon plastic chassis, titanium screws etc) but I cant justify it yet. I have fitted the 418 arms on the car and it didn't feel any different (although it was only a couple of races) if anything I was a little slower (although It might need heavier oil as it seemed to be too soft with those arms).
The only places I know that sell the exotek motor adaptor are exotek themselves and tqrcracing. I purchased it from the latter as shipping to Australia was cheaper with them.
Whats the minimum weight your referring too? If I can get it to 1450g without much hassle then I'm happy
TB03Racer09 is offline   Reply With Quote
Old 05-04-2014, 03:58 AM   #572
1350g is the uk min weight 8-0
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 05-04-2014, 04:11 AM   #573
Thumbs up
Getting a tb04 to that weight will be a challenge but probable doable if one wants to put the money into it.
I've been surfing your site for a while, I have to say that your reviews are very good! Keep up the good work!
Old 05-04-2014, 06:13 AM   #574
The TB04 has a new Pro II Chassis. Previous one discontinued.
Prince Nuada is offline   Reply With Quote
Old 05-05-2014, 01:26 AM   #575
Cheers for that, there are a few guys and we all contribute towards it. Always looking for new guys who want to help. The goal is to make a great free online site for racers.
Old 05-05-2014, 01:56 AM   #576
Got my Hobbywing justock esc today, I decided to put wire braid on it for that stealth look
Heres a link to the wire braid stuff, For 14AWG wires this size is perfect. You can get it in other sizes too.
http://www.ebay.com.au/itm/281084513...84.m1497.l2649
Old 05-05-2014, 02:46 AM   #577
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Looks good. Probably a bit easier than actually replacing the wires too.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 05-05-2014, 03:49 AM   #578
If you can't solder that well, yeah it is easier. But it is a skill you should really learn.
Having said that, always a nervous moment pulling factory fresh wires off a new ESC!
I've done it a few times now as most recently as this week with an LRP flow works. Was one of the easier styles to do as we'll with u shape tabs.
cplus is offline   Reply With Quote
Old 05-05-2014, 05:18 AM   #579
I bought the black wire braid sleeve cause it looks cool and high performance like.
I can solder pretty decently in rc applications. Pre-soldered wires on hobbywing esc have proven to be unmeltable in past experiences. I have a quality 48 watt iron that has soldered 10awg wires yet doesn't even affect the hobbywing solder at all. They must be using something else but others have had similar experiences.
Old 05-05-2014, 05:29 AM   #580
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Not possible to get car any lighter without putting the battery on a diet wth current parts. Aluminum driveline shafts will help, but I don't think it will ever be at "legal weight".
I'll take a picture later, but I think I pinched every gram possible.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 05-05-2014, 06:25 AM   #581
How much weight saving is there going to be by going to the aluminum drive parts?
Juan Aveytia is offline   Reply With Quote
Old 05-05-2014, 09:00 AM   #582
CraigMBA's Avatar
Let you know when I get some!
Old 05-09-2014, 05:36 PM   #583
From Tamiyablog.com
54593 OP.1593 TB-04 reinforced gear set
○ It is the OP parts was reinforced resin (40T Diff gear, bevel gear 16T, 20T Maitagiya) the TB-04G parts.
○ It becomes the gear motor high power also withstand improve the durability of the gear and using reinforced resin.
(We recommend the use of ITEM 42128 VG joint and grease cup.)
Applicable Products ::: TB-04 chassis only
54594 OP.1594 TB-04 K carbon reinforced parts
54595 OP.1595 TB-04 carbon reinforced T parts
54596 OP.1596 TB-04 carbon reinforced lower deck
○ TB-04 for various parts that employs a carbon reinforced resin appeared as an option.
○ It is also ideal for carpet road surface you want to use high-grip road surface and driving, the C tire in the summer outdoors.
○ Please use “54232 3mm screw hole tap (M3 0.5)” for when you drive a screw in the carbon-reinforced resin.
I like the reinforced gear set, great idea!
Old 05-10-2014, 11:22 PM   #584
Can any of you veterans point me in the right direction? I have made a new thread called "Makeshift Tamiya TB-04 Pro II"
I am trying to figure out which parts I would need to make my TB04 Pro into a TB04 Pro II...
Thank you gentlemen
Ben Had is offline   Reply With Quote
Old 05-11-2014, 12:57 AM   #585
Thank you gentlemen
418 suspension parts plus screws and driveshafts is all isn't it?
Screws would be hard to get the actual tamiya steel ones, but either Ti or Al you could get it another brand.
Drive shafts are a readily available part too.
418 arms and hubs are easy to get. Sway bars not so easy yet.
Oh, and wheels if you want to be a pedant.
