Old 04-11-2014, 04:03 PM   #526
Originally Posted by MikeR View Post
Juan,
You know me, my entire fleet are shaft drive cars. This is not a shimming problem we were discussing. We mentioned an alignment issue. On some cars the transmission shaft does not perfectly line up with the pilot shaft. Mine is only skewed probably about .1mm but that is enough to bind every single rotation.
You can try and shift your gearboxes left and right to help but my misalignment goes to the 2 o clock position so I would have to lift the tranny box slightly too. The easiest fix I found is just to loosen the tolerance of the drive pin into the pilot shaft. You can see in the pic I've flattened the pin ends so that it has some play in the cup. Now the alignment doesnt have to be dead on perfect.
Molded parts can be very tricky from batch to batch. Maybe Tamiya has added more fibers or slowed the cooling to better hold the tolerance of the molded parts. I had one of the early release cars.
I could've missed the alignment problem on my car. It's probably got the same problem. I gave some room by adding a .1 spacer inside all the screw holes for that cover. Helped a lot
Juan Aveytia is offline   Reply With Quote
Old 04-11-2014, 04:07 PM   #527
MikeR- are planning any carbon fiber parts for this chassis?
Old 04-12-2014, 05:53 AM   #528
Juan,
I'll have to try that on my car because it will bind in the same place. If I'm not careful during assembly the drive pin will catch every time the shaft rotates and cause a ticking sound. the fact that my chassis is twisted doesn't help at all.
flapper is offline   Reply With Quote
Old 04-12-2014, 04:54 PM   #529
I don't have the problem your having. But I would dremel some plastic away in that area. It shouldn't take much to fix that
Side note: that pin slid out on me once and I broke a gear because of it. I made a flat spot on the pin and lock tite the set screw. No more problems for me
Old 04-13-2014, 02:03 AM   #530
TB03Racer09's Avatar
I just purchased a Exotek motor adaptor just incase if they go out of stock when the new tb04 comes in.
Setup
Tamiya TB04 Pro II Chassis
Tamiya HSV-010 Body
Hobbywing Xerun V10 21.5t Motor
Hobbywing Justock 45A ESC
Futaba 3pl Radio System
Futaba S9551 Servo
Nanotech 4200mah Shorty LiPo
I know this chassis is not ideal for 21.5t motors but the exotek adaptor can get me to 3.50fdr and I have 45 degrees of mechanical timing to play with so I reckon I'll be alright.
TB03Racer09 is offline   Reply With Quote
Old 04-13-2014, 12:50 PM   #531
Trader Rating: 30 (97%+)
hi I have some pinion and spur gears left if anyone is interested, these are brandnew in 64p
spur gear presion racing 73t 75t, kawada 88t
pinion gears presion racing 29t, Tamiya 45t, trinity 46t, 50t, 52t
again everything is brand new, selling for $29 usd shipped for everything
zaraz is offline   Reply With Quote
Old 04-14-2014, 01:33 PM   #532
First cad pic of the TB04 pro V2 here
http://www.thercracer.com/2014/04/84...t-picture.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 04-14-2014, 06:46 PM   #533
hahaha they hid the motor mount from us
Old 04-17-2014, 06:24 PM   #534
Default Really nice TB04 never ran
Tamiya TB04 RED
Atechbh is offline   Reply With Quote
Old 04-17-2014, 06:26 PM   #535
Default Tb04 red
Pic
Old 04-18-2014, 07:41 AM   #536
Originally Posted by Atechbh View Post
Pic
Why did you want your servo so far back?
Old 04-19-2014, 12:51 AM   #537
I want to get some shims for my tb04 build, to remove slop from the suspension arms, knuckles, c hubs ect.
http://www.rcmart.com/tamiya-53585-s...?cPath=421_520
Does this have what I need?
Also, would it be a good idea to get extra shims for the drivetrain, or does Tamiya include enough in the kit?
Old 04-19-2014, 07:59 AM   #538
Get shims for everything
Old 04-19-2014, 12:55 PM   #539
Raman's Avatar
Trader Rating: 51 (100%+)
I've decided to hold off ok dropping $$$ on the 418 and pick up the Ver II for stock 17.5/ RCGT when it comes out. I try my best not to buy too much blue bling unless it's a useful upgrade. From what I can see.. The pro or pro II do not come with alu steering. How's the stock plastic one? Can you shim the play out or is it a necessary upgrade?
TRF419X / Pulse 17.5, T.O.P Racing Sabre Mini AWD / Impact 21.5, M06 Pro / Impact 21.5, XV-01 Pro Rallye / Kinetic 17.5
Raman is offline   Reply With Quote
Old 04-19-2014, 01:26 PM   #540
Plastic is plastic. It works fine. But some people will never be happy unless its perfect. I run a box stock car except the spool and ball diff. Car is very easy to drive and put where you want it
