Old 01-10-2014, 03:32 PM   #391
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Originally Posted by NItrox416 View Post
Hi guys,
I would like to know how long are your new short dampers?
Can they reach approx 54/55 mm
Thank you for the help
The built length of the set I have here is 56.18mm. And your welcome!
Originally Posted by maxepower View Post
I have a TB-03 and it is noiser than my TA-05.
Interestingly enough, I built a TB car so I could get that "shaft drive sound". Alas, mine is quieter than the belt drive cars in the class. The driver was disappointed (because he thought the gear sound is intimidating when you come up on other cars), but the crew chief was elated (he has set up a couple of ring and pinions on 1:1 cars before, and didn't think it was any big deal).
I guess it depends on how you shim them.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 01-10-2014, 06:41 PM   #392
Has anybody tried the 4 deg c-hubs compared to the 6?
Atechbh is offline   Reply With Quote
Old 01-10-2014, 09:01 PM   #393
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
can someone tell me what the length of the shocks are on this car?
jeff jenkins is online now   Reply With Quote
Old 01-11-2014, 12:41 AM   #394
mac853's Avatar
Could somebody tell me if can use tb03 solid axle on tb04, please?
Best regards
mac853 is offline   Reply With Quote
Old 01-11-2014, 02:11 AM   #395
Best regards
Yes
Juan Aveytia is offline   Reply With Quote
Old 01-11-2014, 02:15 AM   #396
Look at the first post on this page. Is that what your asking?
Old 01-11-2014, 02:31 AM   #397
mac853's Avatar
Originally Posted by Juan Aveytia View Post
Yes
Without shim?
Anyway, thanks!
Old 01-11-2014, 08:38 AM   #398
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
Best regards
Yes. But you have to use the 39t gear that came with it plus replace the big gear on your rear gear diff with a 39t as well...
The stock tb04 40t gear is too big and the mesh is too tight.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 01-11-2014, 12:39 PM   #399
NItrox416's Avatar
Thank you very much
NItrox416 is offline   Reply With Quote
Old 01-11-2014, 01:25 PM   #400
Rod C at the Speedtech race installed the TB03 spool with TB04 gears
Old 01-11-2014, 04:42 PM   #401
mac853's Avatar
But without any extra work?
Old 01-11-2014, 07:39 PM   #402
rtypec's Avatar
I ended up running a TB03 ball diff and spool using TB03 gears. In order to get the small gear to fit on the shaft, I used a dremel to remove enough material to get the eclip on.
Also, if you can read chicken scratches, attached is a setup sheet from the Speedtech race.
rtypec is offline   Reply With Quote
Old 01-12-2014, 07:14 AM   #403
I see you are using the 4 degree front c hubs. Did you try the 6 ?
Old 01-12-2014, 08:14 AM   #404
VooDooPH's Avatar
not sure how he did it... mesh was too tight on mine if and when i used the TB04 gears on the TB03 spool... maybe he modified something?
Old 01-12-2014, 09:26 AM   #405
No it is not . what I am asking for is a physical dimension from center to center because I have a project in mind to run lowered towers on my tc for lower cg and need to know if these could work so I don't have to waste time machining my own.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
