Old 11-08-2013, 11:02 PM   #331
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Originally Posted by vivo quevas View Post
Sorry don't play with toys that don't play back.
What do yo mean "Scaled it yet" What body are you going to use?
Im sure he's saying he hasn't weighed the fully assembled car...
Racing4Evo is offline   Reply With Quote
Old 11-11-2013, 11:46 AM   #332
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Close. I set tweek with four small scales. Left over technique from racing carpet oval, and that's how they do 1:1 race cars. Also, If you know what the wheel weights were before you ran and you wack something, it's a quick way to identify if you really put a hurt on the car.
But yes, if you add all four weights together you get the total chassis weight.
See what the corner weights have to say, f/r and l/r weight %. Just Looking at it, I think the tb04 will have less rear axle weight than the other car, but how much different, I can't say.
Protoform Mazda six. Is there any other body?
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 11-14-2013, 10:08 AM   #333
CraigMBA's Avatar
Weight came in at 1394 grams w/ gear diffs!
But, WITHOUT a transponder.
OR a body.
Old 11-14-2013, 11:35 AM   #334
Core Creations's Avatar
Trader Rating: 93 (100%+)
Send a message via AIM to Core Creations
Wow...my TB03 comes in at under 1400g rtr with body and transponder....what electrics are you running?
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 11-14-2013, 06:30 PM   #335
Racing4Evo's Avatar
What do you guys think the carbon reinforced plastic parts will do for weight reduction when they come out?
Old 11-14-2013, 06:50 PM   #336
Smile
So it weighs 1394grams +body(100grams)+transponder(10grams) = 1504grams......... BIG BONED !!!!
OR a body.
bertrandsv87 is offline   Reply With Quote
Old 11-14-2013, 07:41 PM   #337
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
my kit comes weights in at 1438 race ready ... but we're using LiFe batteries which are a lot lighter compared to LiPOs... i'm also using a LW NSX body (car is set up for local TAC GT races) + 30 grams of weights on the battery side.
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 11-14-2013, 07:47 PM   #338
CraigMBA's Avatar
Minimal. I've weighed them in the past, ICIRC they weigh the same.
The gear diffs alone are worth 22+/- grams.
Old 11-14-2013, 07:51 PM   #339
CraigMBA's Avatar
The same ones I have in my TB03. It's 1415 TCS legal, w/ a LW NSX.
How you got yours under 1400, wow.
Old 11-19-2013, 12:45 AM   #340
VooDooPH's Avatar
The spool will fit side to side, but it will require a different gear. Tb04 is 40 teeth, tb03 is 39.
Originally Posted by rtypec View Post
Nice work Craig. My dremel has already seen action with this chassis I installed a TB03 ball diff and spool into the car to help with FDR as well as reduce rotational weight. It drops in but the top of the TB03's small bevel gear had to be dremeled a bit to get the e-clip to snap on.
Just an update... was able to drop in a spool from the TB03... used the same 39T main gear. For the rear, retained the stock TB04 gear diff but bolted on the 39T bevel gear from the TB03/Evo5 One Way set..
Found i didn't need to change the small bevel gear to the TB03 one... the stock one from the TB04 fits (they're both 16T and the mesh is fine, and i was too lazy to do some dremel work just to retrofit the TB03 gear :P). just needed to adjust side to side shimming for the spool/geardiff.
Now, I wonder if I can retrofit the small gear from the Evo4 since its 17T and would drop the IDR to 2.29 (using 39T) or 2.35 (using 40T)
Old 11-19-2013, 12:56 AM   #341
Trader Rating: 26 (100%+)
I am sure it can be done. I don't have a TB04 but I have an EVO5 with EVO4 gearing in it along with a TB04 gear diff and a TB03 spool. Sounds confusing.
JoeyE is offline   Reply With Quote
Old 11-19-2013, 12:32 PM   #342
Hebiki's Avatar
wow...a whole lot of retrofitting going on.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-19-2013, 02:50 PM   #343
Airwave's Avatar
I would say: "I'm not fat, I'm just carrying a lot of useless transmission components" ^^
Airwave is online now   Reply With Quote
Old 11-19-2013, 06:36 PM   #344
CraigMBA's Avatar
I think the gear diffs totally have a place. For example, in front on carpet, so if you wack something, you don't snap a c hub as often.
But they aren't light.
Old 11-23-2013, 03:30 PM   #345
Does anybody have results with racing this chassis yet? Should I go with this tb03 ta05 or ta06?
Atechbh is offline   Reply With Quote
