Old 09-19-2013, 07:37 PM   #151
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
What about slightly elongating the motor mount holes to allow a smaller spur to be used? Maybe tamiya will release different gears to lower the internal to around 2.0??
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
Old 09-19-2013, 09:17 PM   #152
Originally Posted by CraigMBA View Post
Except you can't fit a 52 pinion in there.
Except the car is out of adjustment with a 76 spur.
Just saying.
I expect some update parts, but till then....I'm running my M03.
I'm missing something here. If a 76 tooth spur fits. Why wouldn't a 68 tooth? And instead of that stupid motor adaptor. Try using some tamiya spacers instead. It should hold the motor in place just fine. That should/ might give the proper clearance needed for the larger pinions.
Juan Aveytia is offline   Reply With Quote
Old 09-19-2013, 09:28 PM   #153
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Because you are out of adjustment to make the gear mesh tighter already. When you go to a smaller spur, it will open it up even more.
Further slotting of the adjustment holes would help.
Who makes a 68 tooth 64 pitch spur? Just curious.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 09-19-2013, 09:44 PM   #154
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Smallest 64p spur gear I've seen is 71T. I'd like to know if there are smaller spurs too.
Dan is offline   Reply With Quote
Old 09-19-2013, 10:10 PM   #155
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
I will stick to my TB03R. I'm no longer impressed. What happen to the short shocks? I think I'll just try to put 418 arms on my TB03 and call it a day.
Racing4Evo is offline   Reply With Quote
Old 09-19-2013, 10:17 PM   #156
Airflow's Avatar
I don't have a TB03R and it's been 2 years living with direct drives and belt drive kits, so the TB04pro is a welcome addition to my garage. Always wanted a modern shaft drive kit but not the TT01/02 series or the TC4.
Airflow is offline   Reply With Quote
Old 09-20-2013, 02:19 AM   #157
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Originally Posted by daktulos View Post
OK to excited here the quick way of doing it !
When I measure for the sleeve to sleeve it was with just the screws not with the spacer in place...
So the real measurement is 20.90mm and the max pinion size without tempering with the sleeve is 49T...for a 3.88 FDR
I will correct my first post.
You can see in the middle pic that the motor/pinion is already as far over to the left as it can possible go (see the screws in the motor mount?). If you go a smaller spur, the pinion won't reach and they won't mesh.
Oh, the pics didn't come across. Check out the pics just one page back.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 09-20-2013, 03:55 AM   #158
daktulos's Avatar
Sorry if I was not clear enough English is not my first language
I only use 64P for my calculation and as you can see in the picture the motor at the maximum position is almost touching the chassis and gearbox...
You may be able to go a teeth or two on both ways with more dremeling but not really more. So 3.5 or 3.6 may be doable but I think the effort is not worth it...better concentrate the effort to make a conversion with a new motor mount.
daktulos is offline   Reply With Quote
Old 09-20-2013, 04:41 AM   #159
I have a 68 tooth spur on my evo5. I don't remember the brand. If it helps I purchased it at NorCal hobbies. And going up in pinion sieze, it should mesh. I would definetly open the motor holes up anyways. Won't hurt anything, but will make your life a little easier meshing gears
Old 09-20-2013, 07:42 AM   #160
mac853's Avatar
Questions??
Could somebody tell me the biggest 48p spur gear could put in there?
Best regards
mac853 is offline   Reply With Quote
Old 09-20-2013, 09:30 AM   #161
Hebiki's Avatar
Trader Rating: 26 (100%+)
LOL...tamiya totally f#cked this one up didnt they?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-20-2013, 10:00 AM   #162
Airflow's Avatar
It's too early judge this kit. Lap times will tell if the overall package is crap or brilliant or just typical tamiya tub chassis performance.
Old 09-20-2013, 10:07 AM   #163
Trader Rating: 53 (100%+)
im starting to agree .....only way to make it up to us is a MS version with new motor spacer and new motor mount .....im holding my breath .....not
Rick Hess
Sworkz USA
R&C Hobby shop Clarksville TN
RCP Customs
rkhess is offline   Reply With Quote
Old 09-20-2013, 10:19 AM   #164
Hebiki's Avatar
too early? timing is just right. If you cant hit the correct FDR.. i dont care if Masami is driving the car, your lap times will suffer.
yah but that still doesnt leave it as a viable option for GT2 class participants here in the U.S.
Hebiki Design Works
Old 09-20-2013, 10:24 AM   #165
It probably was only designed to be run in TGP. People still compete with brushed motors there.
redbones is offline   Reply With Quote
