Can u use 3 2s lipo to make a 6s lipo
But 1 of the 3 2s lipo is a different
Tech Legend
It is recommended they all be the same, but don't have to be. Even the same labeled 2S could have different characteristics. The biggest part is monitoring cut off if one is a smaller mah. If they are all the same mah but diff C ratings you just have to worry about balancing. If you are just doing speed runs then you should be fine. You will have to balance charge each 2S or build a balance plug if you want to charge/balance as a 6s.
