Old 09-22-2014, 01:08 PM   #91
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Quick questions-
What parts (if any) are replaceable / compatible with Xray?
Do the stock shocks go together and work smoothly out of the box.
I have heard different things regarding both, figured I would ask here to see what kind of feedback I get, thanks.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 09-22-2014, 01:31 PM   #92
A-arms, spool, gear diff, belts....
Not steering blocks, cvd, c-hub...
Stock dampers are good, but the plastic bottom cap needs a few reaming process, you need to replace the huge silicone tube inside the cap and fit the delrin shim and 1 oring attached with the pro kit.
Regards
Psycho_ is offline   Reply With Quote
Old 09-22-2014, 01:44 PM   #93
nf_ekt's Avatar
Regards
Thanks. I have lots of Xray arms, so that is good to know they are compatible.
Not %100 about the process you are describing with the shock build. I understand the bottom cap part, not sure about the "huge silicone tube" inside the cap. I'm looking to possibly buy this kit, thanks for the help thus far.
Up the Irons \m/
Old 09-22-2014, 02:01 PM   #94
I'm spanish and it's difficult to explain this process... sorry...
Shock dampers comes prebuilts, you need to dissasemble the plastic bottom cap, replace the silicone seal, it is really big, and replace it by a delrin shim and a O-Ring (comes in a plastic bag inside the kit).
After this, if the shaft don't moves so smooth, maybe you have to ream a little the plastic cap.
The driver Chung Ka Keung posted that pictures on his blog.
Take a look please:
standard shock
dissassemble
left, coming silicone seal, center and right the correct way
first delrin shim
after silicone oring
Better explained?
ARC R11 - LRP Powered
Find RC news on: http://www.rcelectrico.es
Old 09-22-2014, 06:03 PM   #95
nf_ekt's Avatar
Take a look please:
standard shock
dissassemble
first delrin shim
Better explained?
Yeah I think that helps for sure. Appreciate it.
Up the Irons \m/
Old 09-29-2014, 01:56 PM   #96
On the parts list there are 3 different silicone orings. Which ones are the correct one's for this?
R060615
R060902
R127003
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 10-07-2014, 07:15 AM   #97
R060615
R060902
R127003
Don't worry about this, they are supplied with the kit.
Regards
Old 10-07-2014, 08:55 AM   #98
nf_ekt's Avatar
Regards
I think he is asking which of these is the "right" one to use.
Up the Irons \m/
Old 10-07-2014, 10:23 AM   #99
I'm almost sure R060615
Regards
Old 10-07-2014, 12:44 PM   #100
That's what I was asking. but my kit had 4 orings and I was told I needed 2 per shock. I asked the shop to aske the importer and they sent me the correct one yesterday. Have not had the time to look at the package as I'm racing oval this weekend and getting ready.
Old 12-02-2014, 12:57 AM   #101
Hi,
May I know how's your people measure the droop? I saw some setup sheet explained that it's measure under arm and select middle camber length hole for the front. I don't really get it. Is this refer to the damper mount?
Thanks!
NEW RGT-R2 1/10 TC-rgt-droop-questions.jpg
jourdan is offline   Reply With Quote
Old 01-24-2015, 08:41 AM   #102
Does anyone know where to source parts for this car?
Camel23 is offline   Reply With Quote
Old 01-24-2015, 01:40 PM   #103
What country are you from? Team powers UK have all parts in stock.
team-powers.co.uk
kevinkirk is offline   Reply With Quote
Old 01-24-2015, 03:49 PM   #104
team-powers.co.uk
I am in the US. I have sent them an email about some parts but I haven't heard back. I noticed that they didn't have the floating servo mount and the complete gear diffs were out of stock.
I found a place out of Spain as well but still waiting to here from them as well.
Old 01-25-2015, 10:55 AM   #105
hi you need to email sales@team-powers.co.uk
I'll check our Current Stock as I am pretty sure we got the floating Servo mount but not sure we have gear diffs in stock at the moment. Should be able though to help you on the rest.. If you are struggling to get one and XRAY one will fit but you need to use the thinner xray bearings for it to rotate freely.
Andy Bird
Race Opt MST T^2 , RGT PRO G2 , Xray T4, Xray X10 2015, XB4
Team Driver (Team Powers HK), RaceOpt , RCHalt
Team Driver (Team Powers UK)
RcDisco Team Driver
AndyBird is offline   Reply With Quote
