Old 06-07-2005, 12:07 PM   #1
Default speed controller
I have a question.
I have GM V12 ESC speed controller and I want to set it up with the best performance of its work.
(Break,Current etc.) I`m using the 12x1 Orion V2 motor.
P.S. I`m racing the HPI Pro 4. I have an idea to add some weights along the drive shaft. Probably aobut 55 grams.
Could you tell me will it better modify the driving or is it a wrong idea?
tudeski is offline   Reply With Quote
Old 06-07-2005, 12:10 PM   #2
ChadCapece's Avatar
Do you mean under the driveshaft? Added weight TO the driveshaft will slow acceleration and make the car slower in general.
ChadCapece is offline   Reply With Quote
Old 06-07-2005, 12:23 PM   #3
Of course I mean under the driveshaft, on the Chassis. Will it drive better,what would it change in this situation?
Old 06-07-2005, 07:10 PM   #4
Jack2's Avatar
Hi, look not sure what you actually mean, so I donít understand what problem you are facing, but if you want to add lead does this mean you want to slow acceleration down or what?? I am not familiar with the GM Speedoís but maybe you could try a higher drive frequency, that should back the punch off a bit and you would get higher top speed as well, and probably better run time from less weight (by not using lead) and better motor life from the higher drive frequency.
If you want to take away momentum to bring the car to a stop quicker instead of decreasing acceleration, you could try increasing drag brakes and reduce dead band, and maybe even try a lighter armature design, such as a DC motor sports UL arm, or maybe a flat wire design or if you use a 5mm web(Arm), you could try a 4mm version.
Schumacher Mi4CX
Mugen MTX & MRX
"He who dies with the most toys wins" - Phil Harris
Jack2 is offline   Reply With Quote
Old 06-08-2005, 05:17 AM   #5
I`m going to buy Hara Twister 2 ESC controller. What do you think about this speedo? Is it good or bad? Do I have to program it external? I mean do I need to have any other devices to program it or is it fully programable by using one button like in GM`s speedos?-
Old 06-08-2005, 06:44 AM   #6
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
dude, you need to figure out exactly what you want to do...dropping big bucks on a new speedo will not necessarily solve whatever problem you are experiencing...
Since you sound like a newbie, you might want to stick with one speedo and go from there...there is nothing wrong with the GM V12 speedo - its a top of the line speedo, and even a world champ speedo...
your first post had 2 completely different and unrelated questions...I'm sure you had more than one of us "experienced" guys scratching their heads trying to figure out exactly what you are trying to accomplish....
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Speed Controller nickclark30171 Georgia Racing 10 03-23-2008 11:19 AM
Novak GTB Brushless 4 cell speed spectrum speed controller. jland R/C Items: For Sale/Trade 2 10-21-2007 01:37 PM
speed controller wallstreet Rookie Zone 1 03-06-2005 06:26 PM
Gt7 Speed Controller IBARACER R/C Items: For Sale/Trade 9 02-16-2005 05:07 AM
GM SX9 Speed controller racingdc9 Electric On-Road 7 02-02-2003 09:39 PM
SEO by vBSEO 3.5.0
