Old 07-31-2013, 05:38 PM   #46
A family member in states
Durango DETC410 - HobbywingV3.1 - Futaba - Orca
www.maritimeracing.org
kosmic is offline   Reply With Quote
Old 07-31-2013, 05:57 PM   #47
COBRARACING's Avatar
Can you please give me the warranty code on the side of the box and the date please as this motor should have never been sold the distributor was warned.
Email : [email protected] or [email protected]
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 08-03-2013, 12:17 PM   #48
My home made repair seems to fix the timing altering
Old 08-03-2013, 12:19 PM   #49
So far, can't get it as quick as my current combo
Old 08-09-2013, 11:22 AM   #50
aloksatoor's Avatar
Trader Rating: 42 (100%+)
Where do you guys buy the tuning rotors with fans?
MP9 TKI3 | ZX6 | RB6 | MBX7r Eco
aloksatoor is offline   Reply With Quote
Old 09-08-2013, 05:53 PM   #51
When this motor will be available??? Estimate date of ship Early September but its almost half of month
Tekno SCT410
TLR 22SCT
TLR 22T
Yaxx is offline   Reply With Quote
Old 09-15-2013, 11:31 PM   #52
Nuno Gancho's Avatar
Hi, where can I by xerun v10 motor 13.5 turn, thanks
Nuno Gancho is offline   Reply With Quote
Old 09-16-2013, 10:57 AM   #53
Hi. Will the V10 motors be available anytime soon in the UK or do I have to order from the US??? Thanks
Schumacher Mi5evo-HW V3.1 - HW V10 13.5 dry car
Schumacher Mi5evo-HW Extreme stock-HW 13.5 wet car
Schumacher SSGT - HW V3.1 stock spec - HW V10 13.5
Racing-cars.com
MWarren is offline   Reply With Quote
Old 11-10-2013, 03:44 PM   #54
Fredp1's Avatar
I suspect that you will be able to get them in early December
Dean(14 years old)- Awesomatix A800X, Fantom FR-1 5.0 Motor, Fantom batteries, KO Propo
Dean(14 years old)- Roche P12-2017, Fantom FR-1 4.5 Motor, Fantom batteries, Team Powers Radon Pro 1s
Evan(8 years old)- VBC Wildfire D06 Dynamics, Hobbywing Extreme Stock, XERUN V10 21.5, Fantom batteries, KO Propo
Fredp1 is offline   Reply With Quote
Old 12-02-2013, 08:03 PM   #55
So anyone have try this new motor?
thanks
Tamiya M05 Pro, Spec-R R1, F104 Pro V2 and AE FT SC10 4x4
Hobbywing V3, Just Stock and SCRT Pro Sanwa MT4
k4mp4q is offline   Reply With Quote
Old 12-02-2013, 10:51 PM   #56
Fredp1's Avatar
Here is a quick update on the 21.5t V10 motor from some testing over the weekend.
Ran 2 V10s at the Riverstone indoor track Sydney, Australia.
Track temps approx 20c
Both cars had no fans on the motor, rubber tyres and running blinky.
Both motors had factory timing, 30 deg.
Motor 1 had a fdr of 3.5, with max temps of about 58c.
Motor 2 had a fdr of 3.8, with temps of about 48c.
Initial feeling is these will perform quite well, given more timing and a fan on the motor.
Yesterday, I turned up the timing and it has some real get up and go.
I'll wait until I get some fans before trying to push it or run a club race, but it left me with a nice smile
Old 12-24-2013, 08:35 PM   #57
Fredp1's Avatar
Had some spare time and read the motor manual... It mentions this motor has a fdr range if 3.0 to 3.5
Driving on a cool day, 20 deg c, on a outdoor ashphelt track using rubber tyres on a touring car with the 21.5 turn motor zero(30) end bell timing with 2 motor fans running blinky.
One car had a fdr of 3.4 and the other was set to 3.2.
Temps were around 45 deg c, +/- 5 deg.
The car with the fdr of 3.2 felt really good with plenty of go, as expected it had more top end speed with still plenty of low end grunt.
Next year I'll push it a bit more when some new pinions turn up.
Old 12-30-2013, 08:58 AM   #58
Default V10
Are the above motors available in the uk yet just can't seem to find them also are they or will they be BRCA approved
andrewd is offline   Reply With Quote
Old 02-04-2014, 08:30 AM   #59
cyba888's Avatar
Just installed a 4.5T on my TC and its no where as fast as the LRP X20. Same ESC settings on my hobbywing V3.1 just swapped motors and LRP has so much more punch and top speed. My esc settings for the LRP motor is 20 boost and 20 turbo timing.
For the V10 motor in order to achieve the same speed as the LRP I had to increase boost to 30 and turbo timing to 30. Even after adjusting the ESC the punch was still weak compared to the LRP.
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 02-04-2014, 09:47 AM   #60
CristianTabush's Avatar
The LRP motors have a lot of timing built into the end bell. Crank up the timing on the V10 and you should see increase in power output.
It is quite normal to need different boost and turbo settings to achieve similar top speed results. For example, REEDY motors need a lot of boost and timing to run fast. The old XERUN blue can motors with fixed timing had to be run at 18-20 deg of boost and 15-18 (MAX) degree of turbo or it would melt the wires off of the battery teminals from the high current draw. The XERUN was still much faster than the Reedy motors even with the less aggressive speedo settings.
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
