Old 08-19-2014, 12:05 PM   #151
Originally Posted by Nuno Gancho View Post
Hi, would like to know what EPA settings do you have on the radio while doing the speedo settings for neutral forward and brake points, do you go for 100% both forward and brake or 140% forward and 160% brake
Thanks.
100% both ways.
Shock Tower is offline   Reply With Quote
Old 08-23-2014, 04:32 AM   #152
Reese Bobby's Avatar
Originally Posted by Reese Bobby View Post
Hi All. Could I please get an indication of a good starting point for gearing and timing for 17.5 and 13.5 boosted on a medium sized outdoor track in a TC. Also are these motors focused more on torque or rpm? How do they handle heat? Thanks.
Hi Guys, what kind of settings are you generally running?
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 08-23-2014, 06:12 AM   #153
chasingthepack's Avatar
ok so im stuck without a motor due to the hall sensors failing,no stock in the uk?
anyone know of any stockists in the uk that have any?
yokomo bd7 16_lrp works team-trinity d4 17.5_futaba 4pks_futaba bls
wet/damp car xray t4-14-r10 pro-team wave 17.5 savox 1251
chasingthepack is offline   Reply With Quote
Old 08-24-2014, 02:54 PM   #154
Have you tried mb models or looked at schumacher site as they are the importers?
Quietman is offline   Reply With Quote
Old 08-25-2014, 03:12 AM   #155
Hi,
http://www.racing-cars.com/pp/Manufa...850000043.html
adyb is offline   Reply With Quote
Old 08-25-2014, 02:12 PM   #156
Originally Posted by adyb View Post
out of stock,thats what i mean if the importers dont have them the retailers cant either
Old 08-25-2014, 02:13 PM   #157
both out of stock,ive found a company in germany but would prefer to spend my money locally
Old 08-27-2014, 02:14 PM   #158
Originally Posted by Shock Tower View Post
My gearing is 7.47 (112/30)64Pitch.
My complete esc setup is here below. Hope that helps.
****************************************Device Information*************************************** *
Device Type:CAR_ESC
Hardware Version:HOBBYWING_456_V2
Software Version:V3.1_121129_Beta
*********************************************Setti ngs**********************************************
[Mode:]
Profile7
[Name:]
Stock 17.5T
[Running Mode]
Forward Only with Brake(*)(+) Forward/Reverse with Brake Forward/Reverse Direct
[Reverse Speed]
25%(*)(+) 50% 75%
100%
[Voltage Cutoff]
Disable Auto(*) 3.0V
3.1V 3.2V(+) 3.3V
3.4V 3.5V 3.6V
3.7V 3.8V 3.9V
4.0V 4.1V 4.2V
4.3V 4.4V 4.5V
4.6V 4.7V 4.8V
4.9V 5.0V 5.1V
5.2V 5.3V 5.4V
5.5V 5.6V 5.7V
5.8V 5.9V 6.0V
6.1V 6.2V 6.3V
6.4V 6.5V 6.6V
6.7V 6.8V 6.9V
7.0V 7.1V 7.2V
7.3V 7.4V 7.5V
7.6V 7.7V 7.8V
7.9V 8.0V 8.1V
8.2V 8.3V 8.4V
8.5V 8.6V 8.7V
8.8V 8.9V 9.0V
9.0V 9.1V 9.2V
9.3V 9.4V 9.5V
9.6V 9.7V 9.8V
9.9V 10.0V 10.1V
10.2V 10.3V 10.4V
10.5V 10.6V 10.7V
10.8V 10.9V 11.0V
11.1V
[ESC Overheat Protection]
85 degree Celsius 105 degree Celsius(*)(+) 125 degree Celsius
Disable
[Motor Overheat Protection]
85 degree Celsius(+) 105 degree Celsius(*) 125 degree Celsius
Disable
[Punch Rate Switch Point]
1% 2% 3%
4% 5% 6%
7% 8% 9%
10% 11% 12%
13% 14% 15%
16% 17% 18%
19% 20% 21%
22% 23% 24%
25% 26% 27%
28% 29% 30%
31% 32% 33%
34% 35% 36%
37% 38% 39%
40% 41% 42%
43% 44% 45%
46% 47% 48%
49% 50%(+) 51%(*)
52% 53% 54%
55% 56% 57%
58% 59% 60%
61% 62% 63%
64% 65% 66%
67% 68% 69%
70% 71% 72%
73% 74% 75%
76% 77% 78%
79% 80% 81%
82% 83% 84%
85% 86% 87%
88% 89% 90%
91% 92% 93%
94% 95% 96%
97% 98% 99%
[1st Stage Punch Rate]
Min:1,0
Max:30,0
Val:30,0
[2nd Stage Punch Rate]
Min:1,0
Max:30,0
Val:30,0
[TH Input Curve]
Linear(*)(+) Custom
[Neutral Range]
4%(Narrow) 6%(Normal)(*) 8%(Wide)(+)
[Drag Brake]
0%(*)(+) 1% 2%
3% 4% 5%
6% 7% 8%
9% 10% 11%
12% 13% 14%
15% 16% 17%
18% 19% 20%
21% 22% 23%
24% 25% 26%
27% 28% 29%
30% 31% 32%
33% 34% 35%
36% 37% 38%
39% 40% 41%
42% 43% 44%
45% 46% 47%
48% 49% 50%
51% 52% 53%
54% 55% 56%
57% 58% 59%
60% 61% 62%
63% 64% 65%
66% 67% 68%
69% 70% 71%
72% 73% 74%
75% 76% 77%
78% 79% 80%
81% 82% 83%
84% 85% 86%
87% 88% 89%
90% 91% 92%
93% 94% 95%
96% 97% 98%
99% 100%
[Brake Strength]
0% 12.5% 25%
37.5% 50% 62.5%(*)(+)
75% 87.5% 100%
[Initial Brake]
=Drag Brake(*)(+) 0% 20%
30% 40%
[Brake Rate Switch Point]
1% 2% 3%
4% 5% 6%
7% 8% 9%
10% 11% 12%
13% 14% 15%
16% 17% 18%
19% 20% 21%
22% 23% 24%
25% 26% 27%
28% 29% 30%
31% 32% 33%
34% 35% 36%
37% 38% 39%
40% 41% 42%
43% 44% 45%
46% 47% 48%
49% 50%(+) 51%(*)
52% 53% 54%
55% 56% 57%
58% 59% 60%
61% 62% 63%
64% 65% 66%
67% 68% 69%
70% 71% 72%
73% 74% 75%
76% 77% 78%
79% 80% 81%
82% 83% 84%
85% 86% 87%
88% 89% 90%
91% 92% 93%
94% 95% 96%
97% 98% 99%
[1st Stage Brake Rate]
Min:1,0
Max:20,0
Val:20,0
[2nd Stage Brake Rate]
Min:1,0
Max:20,0
Val:10,0
[Brake Input Curve]
Linear(*)(+) Custom
[Boost Timing]
0deg 1deg 2deg
3deg 4deg 5deg
6deg 7deg 8deg
9deg 10deg 11deg
12deg 13deg 14deg
15deg 16deg 17deg
18deg 19deg 20deg
21deg 22deg 23deg
24deg 25deg 26deg
27deg 28deg 29deg
30deg 31deg 32deg
33deg 34deg 35deg
36deg(*) 37deg 38deg
39deg 40deg 41deg
42deg 43deg 44deg
45deg 46deg 47deg
48deg 49deg 50deg(+)
51deg 52deg 53deg
54deg 55deg 56deg
57deg 58deg 59deg
60deg 61deg 62deg
63deg 64deg
[Boost Start RPM]
1000rpm 1500rpm 2000rpm(*)
2500rpm 3000rpm 3500rpm(+)
4000rpm 4500rpm 5000rpm
5500rpm 6000rpm 6500rpm
7000rpm 7500rpm 8000rpm
8500rpm 9000rpm 9500rpm
10000rpm 10500rpm 11000rpm
11500rpm 12000rpm 12500rpm
13000rpm 13500rpm 14000rpm
14500rpm 15000rpm 15500rpm
16000rpm 16500rpm 17000rpm
17500rpm 18000rpm 18500rpm
19000rpm 19500rpm 20000rpm
20500rpm 21000rpm 21500rpm
22000rpm 22500rpm 23000rpm
23500rpm 24000rpm 24500rpm
25000rpm 25500rpm 26000rpm
26500rpm 27000rpm 27500rpm
28000rpm 28500rpm 29000rpm
29500rpm 30000rpm 30500rpm
31000rpm 31500rpm 32000rpm
32500rpm 33000rpm 33500rpm
34000rpm 34500rpm 35000rpm
[Boost End RPM]
3000rpm 3500rpm 4000rpm
4500rpm 5000rpm 5500rpm
6000rpm 6500rpm 7000rpm
7500rpm 8000rpm 8500rpm
9000rpm 9500rpm 10000rpm
10500rpm 11000rpm 11500rpm
12000rpm(*) 12500rpm 13000rpm
13500rpm(+) 14000rpm 14500rpm
15000rpm 15500rpm 16000rpm
16500rpm 17000rpm 17500rpm
18000rpm 18500rpm 19000rpm
19500rpm 20000rpm 20500rpm
21000rpm 21500rpm 22000rpm
22500rpm 23000rpm 23500rpm
24000rpm 24500rpm 25000rpm
25500rpm 26000rpm 26500rpm
27000rpm 27500rpm 28000rpm
28500rpm 29000rpm 29500rpm
30000rpm 30500rpm 31000rpm
31500rpm 32000rpm 32500rpm
33000rpm 33500rpm 34000rpm
34500rpm 35000rpm 35500rpm
36000rpm 36500rpm 37000rpm
37500rpm 38000rpm 38500rpm
39000rpm 39500rpm 40000rpm
40500rpm 41000rpm 41500rpm
42000rpm 42500rpm 43000rpm
43500rpm 44000rpm 44500rpm
45000rpm 45500rpm 46000rpm
46500rpm 47000rpm 47500rpm
48000rpm 48500rpm 49000rpm
49500rpm 50000rpm 50500rpm
51000rpm 51500rpm 52000rpm
52500rpm 53000rpm 53500rpm
54000rpm 54500rpm 55000rpm
55500rpm 56000rpm 56500rpm
57000rpm 57500rpm 58000rpm
58500rpm 59000rpm 59500rpm
60000rpm
[Boost Slope]
Linear(*)(+) Custom
[Boost Controlled by TH]
Yes(+) No(*)
[Turbo Timing]
0deg 1deg 2deg
3deg 4deg 5deg
6deg 7deg 8deg
9deg 10deg(+) 11deg
12deg 13deg 14deg
15deg 16deg 17deg
18deg 19deg 20deg
21deg 22deg 23deg
24deg 25deg 26deg
27deg 28deg(*) 29deg
30deg 31deg 32deg
33deg 34deg 35deg
36deg 37deg 38deg
39deg 40deg 41deg
42deg 43deg 44deg
45deg 46deg 47deg
48deg 49deg 50deg
51deg 52deg 53deg
54deg 55deg 56deg
57deg 58deg 59deg
60deg 61deg 62deg
63deg 64deg
[Turbo Activation Method]
Full TH(*) RPM Full TH+RPM(+)
[Turbo Full TH Delay]
Instant(+) 0.05S 0.1S
0.15S 0.2S(*) 0.25S
0.3S 0.35S 0.4S
0.45S 0.5S 0.6S
0.7S 0.8S 0.9S
1.0S
[Turbo Start RPM]
8000rpm 9000rpm 10000rpm
11000rpm 12000rpm 13000rpm(+)
14000rpm 15000rpm 16000rpm
17000rpm 18000rpm 19000rpm
20000rpm(*) 21000rpm 22000rpm
23000rpm 24000rpm 25000rpm
26000rpm 27000rpm 28000rpm
29000rpm 30000rpm 31000rpm
32000rpm 33000rpm 34000rpm
35000rpm 36000rpm 37000rpm
38000rpm 39000rpm 40000rpm
41000rpm 42000rpm 43000rpm
44000rpm 45000rpm 46000rpm
47000rpm 48000rpm 49000rpm
50000rpm
[Turbo Engage slope]
3deg/0.1S 6deg/0.1S 9deg/0.1S
12deg/0.1S 15deg/0.1S 18deg/0.1S(+)
21deg/0.1S 24deg/0.1S(*) 27deg/0.1S
30deg/0.1S Instant
[Turbo Disengage slope]
6deg/0.1S 12deg/0.1S 18deg/0.1S(*)(+)
24deg/0.1S 30deg/0.1S Instant
Is this in blinky or not
andrewd is offline   Reply With Quote
Old 08-27-2014, 04:06 PM   #159
17.5 boosted
Old 09-29-2014, 03:13 PM   #160
millbank's Avatar
Bought one of theses for 17.5 blinky but struggling to get any kind of raw power from it.
Tried gearing high with less timing and gearing low with massive timing. Just feels flat
Xray T2009 / hobbywing v3 120amp /LRP x12 6.5 / wet car
Xray t4'14 / Hobbywing v3 120amp / 13.5/ boost car
Xray t4'15 / Orca Vxx / Orca Rx3 17.5 / blinky car
TEAM DRIVER FOR MMR FLUX
millbank is offline   Reply With Quote
Old 09-29-2014, 04:51 PM   #161
Hi.
Ran my new V10 17.5T in my T4 14 on carpet today. It came off the track a little hotter than I would like to. 190F (87C) after 6 min. when read from the hobbywing V3.1 program box. When measured with a temp gun from outside, it read around 170F (77C).
The track is with a 65ft long straight, and then with many high speed turns, and a few tight corners. So you are on full throttle a lot of the time.
My basic settings on the esc is 50% boost, and 10%timing. My endball timing was around 32.5deg, but I turned it down to 30deg, to see if I could get the temp down. But it didn't do much. My final drive was 7.47.
I compared with my Novac Vulcano, with 100% same settings on the esc, and final drive, and this was about 30F lower temps.
Any surgestions where to look at first, to get a more acceptebel temp ?
Start by reducing can timing to 10-15 deg.
Increase the final boost rpm to around 17000rpm.
frozenpod is offline   Reply With Quote
Old 09-29-2014, 09:22 PM   #162
COBRARACING's Avatar
you need to run more turbo than boost timing
boost 26 turbo 32 end bell at 35 .
Email : teamcobraracing@gmail.com or ae@hobbywing.com
Repair service Address
Hobbywing Technology Co., Ltd.
4th Floor, 3rd Building, KeLunTe Industrial Park, ShangLiLang, BuLan Road, LongGang District, ShenZhen, China
COBRARACING is offline   Reply With Quote
Old 09-30-2014, 03:54 PM   #163
I thought if you ran boosted at 26 then turbo would be 38 to make up 64.... No?
Old 09-30-2014, 04:16 PM   #164
its a total of 64 steps but you dont have to run 64 steps ! Like running a 10.5T or a 4.5T your never going to run 64 steps or else it would run very very hot.
Old 09-30-2014, 06:00 PM   #165
Jorge T's Avatar
I run 3.92 , 1 tick mark less than 50 degrees. 100 x 40 ft carpet track. Just as fast/quick as the d4, actinium and R1 motors. Motor temp is 75-77c read w/ program card.
Also i asked hwna if 86c was safe, got a reply stating that the motors can take up to 126 C, reading with the program card.
RSD Speedway
Jorge T is offline   Reply With Quote
