Old 06-18-2013, 08:45 PM   #1
Default Traxxas rustler VXL
hi there,
is this suitable for the Traxxas rustler VXL ?
HOBBYWING XERUN 4274SL 2000KV Brushless Motor & 150A ESC +LCD Program Card
if not, then please recommend another combo.
thanks in advance!
topplayer123 is offline   Reply With Quote
Old 06-19-2013, 02:49 AM   #2
H0LESH0T's Avatar
Any reason why you are wanting to change the VXL system?
May have a hard time fitting a 42mm can into the Rustler. That setup is for a 1/8. For $199 you can get some pretty good setups. Are you planning on running it on 2s or 3s? If 2s you could go around a 4000 - 5500kv setup. Can get a Castle Creations sidewinder combo with 4600kv motor for $111 or the Mamba pro setup for $195
Amain Hobbies - 4000kv Combos
H0LESH0T is offline   Reply With Quote
SEO by vBSEO 3.5.0
