Old 01-27-2014, 12:40 AM   #61
evochick's Avatar
Originally Posted by EDWARD2003 View Post
Sorry, I know it's the grub screw length. So, how much total up travel do you have?
In the month of February, I'll be meeting one of Yokomo's factory drivers. If you like I can pick his brain for any rubber tire setups.
I'm currently running on foams and this car is on rails. Ridiculously fast and easy to drive. Love this car.
its about 1mm in total up travel, so not a lot. I find its just more stable out of corners if its pushing a little on exit.
UnRetired
evochick is offline   Reply With Quote
Old 01-27-2014, 09:57 AM   #62
speed_cheech's Avatar
I found the ceramic bearings and the Team Associated ball bearings flanged on ebay. Do you have any sites where I can order up some parts? Our group here in Montreal Canada is slowly getting into the rc F1 craze and I really want to build a competitive F1. Thanks for the help!
-hpi nitro firestorm
-kyosho inferno gt1
-tamiya f103rm
speed_cheech is offline   Reply With Quote
Old 01-27-2014, 01:45 PM   #63
evochick's Avatar
I usually just order from AMain or rcmarket
http://www.amainhobbies.com/index.ph...mo-Formula-001
AMain carry most of the F1 spares, and stock ceramic bearings
http://www.amainhobbies.com/product_...d-Ball-Bearing
http://www.amainhobbies.com/product_...ntial-Balls-12
also pick up some TQ 16 gauge wire while your at it
http://www.amainhobbies.com/product_...e-Wire-Black-3
(I should get commission for this)
Beth..
UnRetired
Old 01-27-2014, 04:17 PM   #64
Much Appreciated!
-kyosho inferno gt1
-tamiya f103rm
Old 02-03-2014, 11:37 PM   #65
Default YRF001N assembly help - front end
After receiving the updated front bulkhead and installing it, I'm scratching my head about the grub screws that adjust ride height (shown in attached photo.) Are the revised instructions (also shown) correct to have 5.5mm of the screw coming out on top of the bulkhead? When this is done, front ride height is lowered a lot, and the front suspension is really stiffened; it is then hard to compress the front suspension. The car is being setup with narrow configuration for rubber tires.
Also, when the grub screws are backed out as photographed, which seems about correct to me, they hang down and will be scraping the track. Are the M3x8 grub screws supposed to be used instead of M3x10?
Any thoughts?
By the way, I'm enjoying the sharing of photos, setups, and inforation in this thread, it's great to see other Yokomos. Here are a couple body on and off shots of mine. The driver is being painted.
Yokomo F1 YRF-img_2382.jpg   Yokomo F1 YRF-img_2383.jpg   Yokomo F1 YRF-img_2380.jpg   Yokomo F1 YRF-img_2379.jpg
dctrfrz is offline   Reply With Quote
Old 02-03-2014, 11:57 PM   #66
evochick's Avatar
looking at the photo's you dont have any where enough spacers to run F104 tyres (narrow front end)
how much ride height are you running ?????
UnRetired
Old 02-04-2014, 12:04 AM   #67
EDWARD2003's Avatar
First of all, those grub screws are meant to adjust the suspension arms up and down travel. The grub screws limit the movement of the carbon arms. Not for ride height.
Ride height can be adjusted by adding or removing spacers from the main bulkhead screws, or flipping the spacers around on the kingpin.
If you're running narrow then it should be 5.5 mm measured from the top.
Not sure why the screws are sticking out from the bottom. Maybe check the manual again, there might be something you missed.
That spacer setup is meant for foam tires. I remember Hara running rubber tires and he had a stack of 4 spacers!
http://teamyokomo.blogspot.jp/2013/0...o-yrf-001.html
EDWARD2003 is offline   Reply With Quote
Old 02-04-2014, 02:48 AM   #68
evochick's Avatar
I just checked the kit setup and they are using 5mm worth of shims in total for the narrow front end, I am using close to that at 4.5mm, but I need the little extra ride height on our bumpy tracks.
That photo of hara's car he is using the kingpin front arms, not the flexi front arm, so you need to use more spacers with that front end.
I just remeasured mine as well, and looks like I made a mistake on my setup sheet, mine are only at 5.5mm out, not 6 mm.
Beth.
UnRetired
Old 02-06-2014, 10:54 PM   #69
Sorry for late reply. Thanks a lot for the help earlier, yes it was a matter of incomplete instructions on bleeding the shock. After fooling around with it for a while, everything went together smoothly. Ran it for the first time half an hour ago, the handling is pretty good but car is lacking in top speed for the big asphalt track I ran on. Might need to go lower turn motor as I'm on 21.5t at 3.0 FDR atm and I already hit top speed first quarter of the track. Thanks again
Tastetickles is offline   Reply With Quote
Old 02-06-2014, 11:56 PM   #70
EDWARD2003's Avatar
Glad everything is working out, what is your final rollout? Are you running rubber or foam tires?
Old 02-09-2014, 11:42 PM   #71
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
anyone using the steel rear shaft ?
what the different compare with the graphite shaft that come with the kit?
thanks
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-10-2014, 12:09 AM   #72
Hugh Jazz's Avatar
I have been using the steel shaft since November. I am only using it as I was sick of the carbon ones stripping where the steel shaft screws into it.
Haven't backed to back it.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 02-10-2014, 12:11 AM   #73
evochick's Avatar
thanks
I tried it, but was a little slower with it due to the extra rotating mass (it does weigh lots)
It is a direct replacement for the carbon shaft, the only advantage is its stronger.
UnRetired
Old 02-10-2014, 12:12 AM   #74
evochick's Avatar
stop hitting things
UnRetired
Old 02-10-2014, 02:14 AM   #75
Hugh Jazz's Avatar
Originally Posted by evochick View Post
stop hitting things
One of them was from a hit. The other two just stripped tightening the diff.
I ran 12th scale for two years and had some big hits but never broke an axel.
Dan Maher
