Old 12-27-2013, 01:11 PM   #31
Trader Rating: 22 (100%+)
Default Springs
Do the CRC Encore shock springs work with Yokomo X Shock?
RS_ZACH is offline   Reply With Quote
Old 12-27-2013, 01:57 PM   #32
Don't think so... The X Shock is significantly larger than the CRC
Martin
rhodopsine is offline   Reply With Quote
Old 12-27-2013, 02:19 PM   #33
haura415's Avatar
Crc spring won't fit yokomo shocks I have try
haura415 is offline   Reply With Quote
Old 12-27-2013, 04:18 PM   #34
II was looking on setup guides. And I did see that on Herbert Webber setup for the Mibosportcup. He used a CRC blue spring.....
Seen here....
http://www.petitrc.com/reglages/yoko...sport20131020/
Old 12-29-2013, 01:24 AM   #35
Heri W.'s Avatar
hy boy´s
i drive also the CRC 1/12 damper and the CRC springs......
greets herbert
Heri W. is offline   Reply With Quote
Old 12-29-2013, 01:48 AM   #36
Heri W.'s Avatar
Originally Posted by Heri W. View Post
hy boy´s
greets herbert
here my car - front and rear
i hope this helps - greets herbert
Old 01-02-2014, 07:23 PM   #37
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Attachment 1148735
Attachment 1148736
you change the servo mounting ???
how it make the car feel ?
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-03-2014, 11:44 PM   #38
Heri W.'s Avatar
yes, i changed to the option steering mount - this is very easy to dirve - the ackermann is easy to change - and the 1/12 servo have less weight in the front and this make moore steering - i think this change make the car faster....
greets herbert
Old 01-06-2014, 05:12 PM   #39
kschu's Avatar
greets herbert
thanks heri,
how do we adjust droop in this yrf?? which screw should we use?
Old 01-07-2014, 11:10 AM   #40
Heri W.'s Avatar
????? in the rear - or in the front?????
Old 01-07-2014, 05:21 PM   #41
kschu's Avatar
for front and rear?
wat droop that suitable for med traction and high traction track for front and rear ?
sorry, i'm new in f1.
Old 01-07-2014, 07:10 PM   #42
Hugh Jazz's Avatar
Originally Posted by kschu View Post
for front and rear?
KS
To adjust droop in the rear of an F1 is the same as a 12th scale. The length of the centre shock will determine the amount of pod droop. To get less pod droop you might need to cut 1-2mm off the ball cup on the shock.to get more you just lengthen the shock.
I think mine at the moment is at 1.5mm of pod drop. The front I think depends on the spacers that are on the front king pin.
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-07-2014, 10:56 PM   #43
kschu's Avatar
Originally Posted by Hugh Jazz View Post
KS
how do we measure the droop for rear?
the front arm below have 2 set screw, and 1 in the middle bulkhead.. these is for what usage ?
Old 01-08-2014, 09:15 AM   #44
Heri W.'s Avatar
hy boy´s
in the rear droop ca.1,5mm - moore rear droop makes the car more turn in - but little onpower steering
in the rear - minimal droop make the care easy turn in - and more onpower steering
front droop ca.1mm - moore droop make the car less onpower steering - more weight in the rear...
i drive the kingpins in the front - and there are the shims under the steering arm for the droop - more shims make less droop - less shims make more droop
i can not say - witch droop by low gripp - and witch droop by much gripp - you must take the balance of the car this is very important
hope this helps
greets herbert
Old 01-14-2014, 08:28 PM   #45
evochick's Avatar
Hi Everyone,
I think its time for some more YRF knowledge sharing
Down here in Australia we are allowed to use both narrow and wide F1 cars,
So for the last 7 months i had been running my YRF in wide mode with F103 tyres with ok results, but recently i changed the car to narrow setup to use F104 tyres and the car is so much quicker and still very stable on rubber tyres,
Last week's first run on a medium/high grip hot track the car was unstoppable, and was only 1 sec from lapping the field in the final..
It was the first time i have driven an F1 where you had total confidence when you mashed the throttle you knew it wasn’t going to be a handful coming out of the corner yet had so much steering you were not just pushing all over the place.
So the tyres to use
Morning with a coolish track
Pit PS-0573 medium fronts,
Pit PS-0572 hard rears
Afternoon hot track setup
Ride R1 Rears
I will post a full setup tonight when i can scan it,
I ran the Pit 572's on a hot track for curiosity but they went off after a few minutes, it was still drivable but you had to really square the car up before accelerating.
Thanks to Dan (Hugh Jazz) who just happened to save the day with some 12th scale ride height adapters (R12-20H) these are a must with Pit tyres on the rear to get some decent ride height as they are slightly smaller diameter the the Ride's
I will report back after our first round of our 2014 F1 series this weekend.
Beth.
UnRetired
evochick is offline   Reply With Quote
