Yokomo F1 YRF
#301
Does the YR10 take a silver can 540 Tamiya motor? I believe the question was asked above.
Anyone know?
Anyone know?
#302
Set up
Hi guys,
I bought the new Yokomo YR 10 and looking for some setup tipps.
Maybe someone knows some essential tipps for me?
And how can I change the front height?
I´m driving on a small carpet track with medium grip and use the Hobbywing 21.5 Stock combo.
Thx in advance!
Thx in advance!
#303
No ideas?
#305
Hi,
yes, you will need to play with shims on the lower arm. Other option is removing the 3mm shim on the kingpin and replace with a 2mm over the steering hub ans a 1mm shim below the hub.
cheers
cheers
#306
Am i doing something wrong or is it extremely hard to mount the motor and get the sensor wire inbetween the braces?
#308
#309
Anyone have a decent setup for small grey carpet medium grip track? Running 25.5 on foams.
#310
After several guys have asked I have made a aluminum chassis and pod plate. It is 2mm thick 7075T6, the weight is 16 grams heavier than factory carbon. 12 grams heavier on chassis plate and 4 grams on the pod plate. if interested you can message me on here or racermac73@gmail
#311
#312
I have recently acquired a YRF 001W. The front suspension flex plate is broken and I am having trouble finding any parts as it quite an old car now.
Does anyone have the parts required to make it a narrow front end, king pin suspension or flex plate would be fine.
Or, can you point me to a store which may still have some of these bits?
I have checked with the Australian distributor and they couldn't help me.
Does the yr10 front end fit straight on?
#313
https://banzaihobby.com/radio-control/f1-formula-1-rc-car/yokomo-yrf-formula
#314
Thanks for checking Wascheck.
Banzai have the wide independent arms YF-10LK which goes with the king pin suspension, but are out of stock of YF-10L, (the flex plate arms which I have broken, (non king pin suspension)).
They are also out of stock of the king pin conversion kits YF-KPSC and YF-KPSNC.
#315
YF-10L
