Old 07-02-2016, 04:14 PM   #286
porsche928gs's Avatar
Originally Posted by Dan View Post
Did you check that the inserts for the upper and lower arms are all same width setting?
yes I did.
porsche928gs is offline   Reply With Quote
Old 07-02-2016, 04:27 PM   #287
I guess, I'm going to remove all inserts and check their widths. I know they are pointing to the right direction as the manual.
Old 07-08-2016, 05:32 AM   #288
Trader Rating: 288 (100%+)
Where do you guys get your parts for the YR10F1?
rcdoktor2 is offline   Reply With Quote
Old 07-08-2016, 02:44 PM   #289
pro-shop futaba and banzai rc
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
Old 07-08-2016, 03:02 PM   #290
DirkW's Avatar
Or if you're in Europe like me, Mibosport or Tonisport.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17(8) | Xray X1'17(8) | Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 07-18-2016, 05:32 AM   #291
One small question, has anyone photos about who to set up the car with inline battery? I have tried but my speedo, justock xr, does not fit below the shock and boody post plate.
Best regards
Javier
jimjav is offline   Reply With Quote
Old 08-01-2016, 10:07 PM   #292
Hi guys i have a small issue and was hoping one of you could help me out. i have a YRF 001 and just done a rear side tube conversion. the issues is with the small piece that the two tubes bolt to under the shock mounting point. This part now hits my battery. Is there a fix for this or have i done something wrong.
thanks
ANGRYEVO8 is offline   Reply With Quote
Old 08-02-2016, 05:50 AM   #293
thanks
Yes... What you can do is either run a thin lipo, or if your setup allows it, push the battery forward as much as possible. I got tired of this and went back to the original part, but replaced the damper by an associated friction damper. Works just as good.
Martin Paradis
rhodopsine is offline   Reply With Quote
Old 08-03-2016, 05:58 AM   #294
Thanks Martin, i will try a shorty lipo. If i dont like the way it handles i will go back to a damper.
Old 08-10-2016, 06:20 PM   #295
Unhappy Question about using motor Tamiya brushed silver in YR10F
Hi everybody, I need your help,
I have just build the YR10F, without any problem, but when I try to install the motor, I notice that there is space only for a brushless motor. Here in our club the F1 category uses only Tamiya silver motor. My problem is that the holes for attached the motor has different position, so I can't install the motor. So my question: Is there some adaptador that help tu use the brushed Tamiya 540 motor in this car? Or I have to change something?
I will really appreciate some help.
I have the car but I can't use it.
Thanks a lot.
nick1 is offline   Reply With Quote
Old 08-13-2016, 11:47 AM   #296
Where is the best place to order one ?
sgtlt is offline   Reply With Quote
Old 08-15-2016, 09:29 AM   #297
JayL's Avatar
HK
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 10-29-2016, 10:31 AM   #298
InZane's Avatar
Pre season testing - very promising!
Yokomo F1 YRF-_20161029_192410.jpg   Yokomo F1 YRF-_20161029_192309.jpg   Yokomo F1 YRF-fb_img_1477814041721.jpg
InZane is offline   Reply With Quote
Old 10-29-2016, 12:33 PM   #299
Hi,
what is that front shock for?
thanks
Old 11-01-2016, 08:18 AM   #300
InZane's Avatar
I'm using a floating servo mount but it's attached to the rear of the servo instead of the more traditional way onto the front suspension unit. By connecting the servo directly to the front end you will affect the flex more than if you have the mount as far back on the chassis as possible - there's a "twisting" force on the servo when turning.
When you have a floating servo - front or rear mounted - the chassis will sag in the middle (if its not super stiff) and the ride height will be lower in the middle and a bit higher by the front wing. By attaching the front shock you can adjust the spring tension and have a flat chassis - you can also adjust the stiffnes of the chassis lengthwise by changing the shock spring. The shock is dampening bouncing and vibrations in the front end as well.
