Old 03-09-2016, 07:54 AM   #271
I am just finishing mine, I hope that tonight will be able to do rear axle plus wings and maybe start to cut the body.
has anyone experienced issues with the o ring not keeping the plastic bits of the arms in place?
Best regards
Javier
jimjav is offline   Reply With Quote
Old 03-12-2016, 03:18 AM   #272
Giorgio's Avatar
News for Yokomo F1
Seen on the italian Yokomo distributor... www.framega.com
https://www.facebook.com/FenixRacing.it/
www.fenixracingshop.com
Giorgio is offline   Reply With Quote
Old 03-22-2016, 12:52 AM   #273
vadersing's Avatar
Default wheels
I am new to Yokomo F1, may I know if F104 wheels fit? Any modifications needed to fit?
vadersing is offline   Reply With Quote
Old 04-24-2016, 01:32 PM   #274
1/8 IC Fan's Avatar
Trader Rating: 44 (100%+)
I wanted to ask, as I am just getting back into F1, having raced last in the 90's Euro-Cup and Keil series. Who in the US carries the new chassis YR10F?
-if you can't get ahold of me I am probably working, and that's out in the ocean. So please have patience when trying to correspond. - Thank you.
--->When in doubt try the Search Tab, it can and actually will lead to an Answer!
1/8 IC Fan is offline   Reply With Quote
Old 05-04-2016, 09:22 PM   #275
The One They Call Dirty's Avatar
Trader Rating: 57 (100%+)
Default New build
Been slacking on getting this finished, but I had some free time this week to get the electronics layout and wiring done the way I wanted. Came out looking pretty clean I think, and actually balanced out well when the motor was installed (had to use a 17.5 for test purposes, don't have a 21.5 yet). Now all that's left is figuring out what body to use. I purchased a '14 PF body, but it didn't fit the way Id like it to, too high in the rear. Well, hope to have it done within a week or two, once I find a body here in the states I like. Enjoy!
92zero Designs -Diggity Designs
Fantom Racing - Lunsford
MIP - Windy City RC
The One They Call Dirty is offline   Reply With Quote
Old 05-04-2016, 09:38 PM   #276
EDWARD2003's Avatar
Looks nice!!!
When you're balancing the chassis the rear pod should not be included. Should only be the main chassis only.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 05-05-2016, 12:25 AM   #277
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Originally Posted by EDWARD2003 View Post
Looks nice!!!
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 05-05-2016, 01:01 AM   #278
After some racing on carpet and tarmac I am starting to feel really happy with car.
I have changed the steering crank, I am using the ones for the 12th car, R12-26CL the + 1.75 mm version. It makes steering more smoother and a bit more direct as it has a lot less ackerman.
The body I am using is the Montech F13.
The One They Call Dirty, you can remove the fan on the speedo, with blinky and a 21.5T motor speed will never get anything near hot.
Cheers
Javier
Old 05-05-2016, 06:12 AM   #279
Cheers
Javier
Does the f13 sit flush with the bottom of the chassis? And I plan on taking the fan off, it's a brand new esc, haven't gotten that far yet lol.
MIP - Windy City RC
Old 06-26-2016, 10:16 PM   #280
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
What other side springs fit the YR-10F? I've used the Associated 1/12 gold side springs but they are not stiff enough to get my car more responsive.
Dan is offline   Reply With Quote
Old 06-27-2016, 03:39 AM   #281
I am using the yokomo ones.
Ccooper or gold ones are great for outdoor racing. For indoor purple or black are good.
Cheers
Javier
Old 06-27-2016, 10:02 AM   #282
JayL's Avatar
Just run shims, no springs or dampers, that's the only way to be stiffer than you have it
MOD: A800 R1 Digital-2 MM Fleta ZX 5.0T|||VTA: A700 Orca VX3 R1 25.5V16 |||F1:
Roche 2016 R1 Digital-2 R1 21.5V16|||Sanwa M12S|||iCharger 406Duo
JayL is offline   Reply With Quote
Old 06-27-2016, 12:44 PM   #283
Dan
Dan's Avatar
Hah, those gold springs are still too soft. Gotta take out the holders tonight to see if I can fit wider X1 springs.
Old 07-02-2016, 01:46 PM   #284
porsche928gs's Avatar
Help needed. I can't seem to get the camber on the car the same lt to rt. I went thru
the manual several times and using the double arrows pointing inward I get 2.5deg on the right and 1deg on the left. I measured it with my gauges and a camber block against the tire, is the same. Any ideas? Anybody experience this?
AKA Gilberto Santos
MikesHobbyshop.com SuperiorHobbies.com
Xray T4 and Yokomo BD7 2014 -Airtronics M12 Sponsored by Amex :-) open to other sponsorships!
porsche928gs is offline   Reply With Quote
Old 07-02-2016, 03:53 PM   #285
Dan
Dan's Avatar
Did you check that the inserts for the upper and lower arms are all same width setting?
