Old 11-27-2015, 07:19 AM   #241
DirkW's Avatar
Originally Posted by Yorick View Post
That is new apparently all way different model - front suspension is totally different, battery and servo mounting is completely new (Déjà vu with Xray X1). Even nami is different YR-10 vs YRF 001
What I want to confirm is the YRF 001 compatibility with ETS spec wings
Anyway if shipments arrived I may do the check myself over weekend with my friends ETS wings.
Sorry, didn't realize you were talking about the old car, since most people lately were only talking about the new one here.
Dirk
Current cars: Yokomo BD7'16 | Yokomo BD7'15 | Yokomo YRX-12 | Yokomo YR-10F | Xray X10 '16 | Yokomo YZ-2 DT | Yokomo B-Max4 III Factory | Kyosho Ultima SC6 | Tekno SCT410.3
Future cars (soon): Xray T4'17| Yokomo YZ-2 CA(DTM?) | VIP-Performance Vorlon/VTE
DirkW is offline   Reply With Quote
Old 12-03-2015, 04:59 AM   #242
Default ride height
Does yokomo or anybody else for that matter make rear axle ride height spacers other then the 2mm and 0mm? i am having a hard time getting the car down to 3mm ride height with rubber tires.
thanks in advance
xps800doo is offline   Reply With Quote
Old 12-03-2015, 05:28 AM   #243
You can use R12 ride height adapters - they come in set and offer way more choices: look for part YOKR12-20H.
Yorick is online now   Reply With Quote
Old 12-03-2015, 07:05 PM   #244
Default adapter
I have those already(complete set came with my r12c3.1), they go the wrong direction, the largest offset is the 2mm i need like a 2.5... could put a shim between the motor pods and bottom pod but that still keeps all the weight up high doesn't make sense...
Old 12-03-2015, 07:13 PM   #245
EDWARD2003's Avatar
Ideally, you don't want to run your car down to 3.0 mm. You wan't to have a decent amount of ride height of say 4~5 mm front and rear. Too low will cause the chassis to scrub the carpet and cause the car to handle poorly. I run my F1 rubber height at 4.5 mm front and 5 mm rear.
A higher ride height will allow the car roll more and give more weight transfer to the tires.
Skim over various F1 setups on Petit RC and you'll see most, if not all guys are running 4 or 5 mm ride height.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 12-05-2015, 02:16 AM   #246
Could you recommend some good kingpin setup (top/down spacers) for use with Ride XR wheels? I got second handed YRF with 2mm on both top and bottom - any hints?
Additionally what springs could I use as replacement for original ones for kingpin - any recommendations? GOt 2 crashes with some loses and used whatever at hand but now would like to have it more optimal, without buying whole kingpin conversion.
Old 12-31-2015, 11:50 PM   #247
Tiny.24's Avatar
thanks in advance
At the end of January I should have pods that when the zero block is installed the ride hight is 4mm with pit tires. Keep an eye on our Facebook page options-rc.com.
Also have a couple kits leftover. PM for deep discount details.
Tiny.24 is offline   Reply With Quote
Old 01-05-2016, 03:46 PM   #248
Trader Rating: 22 (100%+)
If anyone is interested in buying one of these. Im going to be posting mine up for sale, tonight or this coming week.
RS_ZACH is offline   Reply With Quote
Old 01-09-2016, 08:37 AM   #249
BTW if you use Ride's wheels the new XRs are smaller diameter comparing to R1 - so maybe the way to reach lower ride height.
Old 01-09-2016, 04:08 PM   #250
Ph3nyx's Avatar
+ YouTube Video
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 01-14-2016, 02:45 PM   #251
Ph3nyx's Avatar
+ YouTube Video
Old 01-31-2016, 05:35 AM   #252
Recently picked up this car used with no wheels and tires, Tamiya body and wing set installed. Wondering where to start setup wise for rubber tire and new CRC carpet. I ordered some tires from Sweep, soft fronts, medium rears and also soft rears as a starting point. any help would be appreciated.
rcguy1958 is offline   Reply With Quote
Old 01-31-2016, 09:46 AM   #253
Well, still learning but seems old YRF is becoming bit outdated with totally new model, reading through this thread and looking at setups on http://site.petitrc.com/reglages/yok...okomoYRF1.html is the best way to start.
First things:
1. How much do you want to invest into it? Friction damper is really nice thing. Crank setup for steering seems to be recommended but is pretty expensive and not available on most shops.
2. Layout of electronics: ESC, RX and battery. If you keep the standard servo position and have shorty battery you have several options:
a) battery behind servo and ESC & RX under brace
b) battery all way back and ESC & RX in front
c) battery in the middle and splitting ESC & RX in front / back
Alternatively you can use "classic" placement of RX & ESC on "shelves" but for me this leaves them too exposed in case of serious crashes, and I prefer to have weight as close to middle line as possible.
3. Once you choose and install that and wheels proceed to set ride height to ~5mm.
4. Toe out 1,5-2 degrees, camber similar, caster max (4 shims to the front), and you have good starting setup.
Old 02-05-2016, 12:17 PM   #254
InZane's Avatar
Default Ready for first tests..
InZane is offline   Reply With Quote
Old 02-06-2016, 06:44 AM   #255
EDWARD2003's Avatar
The Yokomo looks great!
                 VBC 12M - D08 - FX
