Old 03-26-2015, 08:28 AM   #211
ziggy1013's Avatar
Hi guys I just purchase this car and I need help on initial setup for mid to high grip carpet track. What tires to run, oil to use... Etc. any input would help Ty.
ziggy1013 is offline   Reply With Quote
Old 03-28-2015, 11:15 AM   #212
I race mine at TQ RC Raceway in Chino, CA which is a very high grip carpet track and here is what i have found to work.
Tires:
Pit PS-574 fronts (stock insert)
Pit PS-575 rears (stock insert)
Wheels:
I like the exotec with the 3mm offset.
Dampers:
Side: Convert to a single damper tube and start with 30K diff oil.
front to rear: I used the team associated main shock, but for the yokomo shock start with stock.
Springs:
Side: Yokomo purple (the softest spring you can buy)
Front (King pin spring front end): Mid (.018 wire dia)
Front Axle:
Trailing (behind the kingpin)
Ride Height:
as low as you can make it: I'm running the 2mm spacer upside down and my car is still above 5mm in the back. i'm running of about 4.6mm in the front.
Front Wing:
replace the Yokomo one when it starts to sag. Tamiya F104 wings are a direct replacement.
Tire Sauce:
1/4 sauce to no sauce on the front
full sauce the rear
you biggest problem will be moderating between push and traction rolling. you can do this with the tire sauce application on the front tires. I am not the fastest guy on the track but i have gone from a undriveable car when i first tried to race it to a pretty quick car. Now it's only my driving holding me back.
good luck
nissan man is offline   Reply With Quote
Old 04-03-2015, 10:11 PM   #213
ziggy1013's Avatar
Ty so much Nissan man
Old 04-03-2015, 10:19 PM   #214
Default protoform body fitting
Made some prototype parts to help with fitting the protoform bodies. I'll see if I can upload some pictures.
Old 08-11-2015, 08:40 PM   #215
My Yokomo YRF
Yokomo BD7 2016/Lrp 4.5T/Ko Propo
Yokomo BD7 2015/Lrp 10.5T/Ko Propo
Wascheck is offline   Reply With Quote
Old 08-11-2015, 09:20 PM   #216
EDWARD2003's Avatar
Originally Posted by Wascheck View Post
My Yokomo YRF
Nice ride! Welcome to the YRF camp
One thing to look at is your front steering links. Your servo is too far back. Move the servo forward so the steering links are parallel or slightly v'd.
Also, run your ESC flat.
However, the manual illustrates it exactly the way you have it. Give it a try and see how it goes
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 08-12-2015, 06:44 AM   #217
Thanks for the advice, I had to move foward 1mm to be with 14,5 mm as suggested in the Manual.
If I lay down the esc, the body don't fix perfectly.
Old 08-12-2015, 08:08 AM   #218
EDWARD2003's Avatar
http://www.petitrc.com/reglages/yoko...see2015050103/
Even though he is running the direct crank system. The links should be orientated like that.
                 VBC 12M - D08 - FX
Old 08-29-2015, 10:07 AM   #219
No news about a new chassis or a new car to have the lipo in "cross" position like the Xray like see on Martin Hofer car at the ETS ?
Vintage Trans-Am FRENCH Series !
Jerem is offline   Reply With Quote
Old 08-31-2015, 10:40 PM   #220
EDWARD2003's Avatar
Nothing as of late. I'll keep you posted.
The Yokomo chassis as it stands does really well in the rubber and foam tire classes. The YRF-001 is consistently on the podium.
Martin Hofer's chassis is his own thing. Maybe Yokomo will look into releasing a chassis upgrade/update. It really all depends on what direction Yokomo wants to take with this chassis.
                 VBC 12M - D08 - FX
Old 08-31-2015, 11:21 PM   #221
The Yokomo chassis as it stands, does really well in the rubber and foam tire classes. The YRF-001 is consistently on the podium.
Martin Hofer's chassis is his own thing. Maybe Yokomo will release a chassis upgrade. It all depends on what direction Yokomo wants to take with this chassis.
Old 09-23-2015, 06:55 AM   #222
EDWARD2003's Avatar
Default Transveres YRF-001 Project
After checking out Martin Hoffers setup I decided to do the same.
Though a little differently. I had an old R12 C3 main chassis plate and cut it up in order to extend the links outward. Then I took a C3 rear pod and mounted it up. The Yokomo C3, YRF, Team Bomber motor bulkheads all are interchangeable.
Enough talking. I'll do a quick video on what I did.
For the meantime, here are some pictures for you to fire up your motivation to do the same.
                 VBC 12M - D08 - FX
Old 09-23-2015, 06:56 AM   #223
EDWARD2003's Avatar
Full chassis layout
                 VBC 12M - D08 - FX
Old 09-23-2015, 06:57 AM   #224
EDWARD2003's Avatar
Another
                 VBC 12M - D08 - FX
Old 09-23-2015, 06:58 AM   #225
EDWARD2003's Avatar
Underneath
                 VBC 12M - D08 - FX
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
