Old 02-10-2015, 01:56 PM   #181
jamminjim's Avatar
Sure does, THANKS
Know racing, know life. No racing, no life.
jamminjim is offline   Reply With Quote
Old 02-17-2015, 08:47 PM   #182
jamminjim's Avatar
So would you recommend the wide or narrow front for carpet racing? (rubber tires)
Old 02-17-2015, 09:20 PM   #183
First time to leave any comment on this kit since I didn't even bother to check.
however after I saw pictures from the website it got my attention. Specially the adjustibility on the front end.
VBC f1 / MST 01 d pro /
I love this hobby!!
aackjw is offline   Reply With Quote
Old 02-17-2015, 10:07 PM   #184
EDWARD2003's Avatar
You should check with the rules at you're club. Usually rubber tires run a specific track width of XXX mm. I would look at using the narrow version and the kingpin upgrade. The kingpin upgrade is meant for rubber tires.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 02-18-2015, 11:05 AM   #185
jamminjim's Avatar
We dont have very specific rules yet. Its just getting going as a class here. As far as handling goes which is better? (no upgrades. they arent easily avail here anyway)
Old 02-18-2015, 01:49 PM   #186
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Silly question. Will the front wing work on any other chassis?
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 02-19-2015, 07:01 PM   #187
Do the new kits come with the standard side to side damper or the new dual side to side damper? I can't see a dual side damper part number on the yokomo website.
SERCCC - The world's best RC track ;)
SERCCC, www.serccc.com
Space for rent!
luda is offline   Reply With Quote
Old 02-19-2015, 07:04 PM   #188
ford_racing's Avatar
Send a message via MSN to ford_racing
I'd start with narrow as it gives more steering, but if you find you have too much, or the car is too nervous, change to the wide front
ford_racing is offline   Reply With Quote
Old 02-19-2015, 07:07 PM   #189
I currently run a F201 wrung on my car indoors as it gives more grip,
There are others which for as well, including the F104 and I think the 3racing. Beth may be able to help a bit more
Old 02-24-2015, 07:46 PM   #190
jamminjim's Avatar
Does anyone know of a tuning guide for this car? (or even F1 cars in general)
Old 02-24-2015, 07:59 PM   #191
EDWARD2003's Avatar
What's yo problem?
                 VBC 12M - D08 - FX
Old 02-24-2015, 08:20 PM   #192
evochick's Avatar
yep what he said
the older Tamiya wings don't fit without some hacking. I always used the 3racing or kit one.
No wings on my car at the moment, will make its Lemans debut this Friday
UnRetired
evochick is offline   Reply With Quote
Old 02-25-2015, 03:03 AM   #193
evochick's Avatar
mmm Lemans YRF
We run 17.5 motors and with lots of downforce they are good fun to drive...
Beth.
UnRetired
Old 02-25-2015, 05:43 AM   #194
jamminjim's Avatar
No problem Edward just want to know how to make adjustments. I will be running a box stock car on Fri and if it doesnt run quite how I want I need to know what to do.
Old 02-25-2015, 06:44 AM   #195
EDWARD2003's Avatar
How is it handling? What's it like when taking a corner? Does it oversteer? Understeer? How did you want it to handle?
Tell me everything you've done to the car and what the current setup it has. I'll speak with the actual designer of the car and get some input from him on what to do.
Cool?
                 VBC 12M - D08 - FX
