Yokomo F1 YRF
#166
Uuuuggghhhhh! The nose is still on the ground!
#168
v2 front end. Pictures would be AWESOME!
#171
Here is my front end from the last time I drove the car at our Nationals last year, I think I had ride height at about 4mm,
Looks like I was using 4.25mm shims under the arm, and on the kingpin 0.25 below and 2.25 above the arm.
I usually just play around with spacers to get the ride height I needed.
#172
Can you run rubber tires on the "W" car or does have to be the "N"?
#173
you can use rubber tires for f103 (pit 541 545 for exemple) on the W
#175
For anyone else that might be curious, the new PROTOform bodies do not fit properly on the YRF. These bodies have side pods that get really low at the rear of the car, and that just doesn't mix with the Yokomo's high body mount location. This means the body sits really high in the rear, and looks just plain wrong.
Is there anyone who makes a replacement shock mount and rear brace that would allow the body post to be mounted at the lower rear brace height, but still at the stock position? Basically something similar to how the body post are situated on the VBC Lightning F1.
#177
