New Novak Brusless System
#2446
Novak GTB 2.5?
Regarding the Novak GTB brushless motor series, does anyone know whether there are plans to produce a 2.5 BL GTB system (step-up in power compared with 3.5 BL)? Guess what I'm really asking is how much more (if any) RPM, torque (power) can be squeezed out of a these BL motors? At some point there's a ceiling (or floor) with respect to continually increasing power with a given motor design, right? Anyone know something about the engineering and science behind what actually makes these motors generate power? Is the 3.5 BL GTB system close to being "maxed out" as far as power goes, or can we expect additional power increases from these BL systems in the near future?
#2448
Doing some bench test on my new installed, Novak GTB with 10.5SS. When I hold full throttle position for 3 sec or so, the ESC would stutter to a slower speed then goes back to full throttle again, or when I hold to around 30-40% throttle the motor would stop and red led blinks. Trouble shooting says about the sensor cable, I did shorten the cable and made sure 6 pins has contact. What else can be wrong?
Any help is appreciated...
#2449
anyone else have problems with the switch wire coming off the esc while racing? if so what should i do to fix it? shoe goo?
#2451
yup, its double sided to the top deck and theres slack in the line.... it may have been operator error as well as it was the first time i ran the car since i built it.....i only ran once after i slid it back together the rest of the way and it seemed fine int hat run
#2453
I wish there is a search within a thread that has 100 of pages...LOL
Here is my question....need another GTB system for my 12th scale..however, not really interested JUST for the 12th scale only, there is another TC that I would like to swap speedo/motor onto.......does 6 cells regular GTB works with 4 cells without losing a lot of stuff?
Also, does regular GTB be able to remove the heatsink like the 4 cell version? I think I tried to remove my exisitng GTB but it does not seems like it can be remove after removing the 4 screws...is that heat sink doubleside taped onto the GTB?
Last...I know the latest verison of GTB has LIPO cutoff, how about Brushless/brushed motor switch...do they have the update that the owner no longer need to press button to switch to brushed mode..? Just like the other brand brushless speedo does...? Or it still required the owner to switch to BRUSHED mode or we will see the GTB on flame....thanks
#2454
Super Moderator
with the gtb you still have to go through the set up to run brushed motor unless you get the newer esc from novak the XBR but it has a motor limit of 8.5 brushless but no motor limit on brushed and it has lipo cut off built it
#2455
the regular GTB will work on your 12th scale with 4 cells , i ran mine just fine i just removed the fan.I wouldn remove the heatsink myself.
Also...when you run your GTB on your 12th scale, you still need to use the CAP right..? Thanks..
#2457
#2458
Hi guys,
Im about to buy a GTB Brushless System 10.5 to race 19T class.
Im not new on onroad racing but totally new to electrics, so hi have some questions :
1.- Batteries. I want a budget oriented solution, would be a good idea to go for a couple of lipo packs (7.4v 3.xxxmah lipo packs x 2) or a couple of 4.200mah NiMh packs ?.
2.- I have two chargers, one ICE and one Multiplex MULTICharger LN-5014, its enough for electric touring racing ?.
3.- I see you sometimes use a capacitor connected to the ESC, what it is for ?, when you have to use it ?, do i have to ?
4.- Almost sure i will be racing a XRAY T2 '007, on medium size technical track, any idea of the pinion size i have to use on the GTB Brushless system ?
5.- I see that you can buy differente GAUGE wires to mount the batt packs, when you have to use higher or lower numbers (12, 14, 18, etc ?).
6.- Any sugestion on connectors ?, im not on the idea of 100% soldered installation.
7.- If i go for lipo batts, i DO have to buy a balancer ?
thanks a lot guys !!
#2459
Hi guys,
2. Yes ICE and LN5104 works fine
3. Yes you SHOULD use the capacitor.
4.
5. Use only 14 or 12 Guage. Less resistance then 16
6. Connectors newbies usually use deans. I use bullet connectors
7. Yes if you run lipo you need to balance. The orion Lipo, you can just charge each cell individually every 10 charges. i.e you can balance but u dont need a balancer
p.s it sound like the Orion Carbon Fibre 3200 would suit your needs best
#2460
Hi guys,
1. depends on where you race, if they alow Lipo. but i've heard you give up quite a bit of punch at the start. i'll find out this weekend (running 10.5) as i'll try to swap between NiMH and a lipo pack.
2.
3. MUST use the capacitor that comes with the GTB
4. 10.5 FDR is around 5.5 to 5, depending on the flow and size of your track, if you're using a sintered rotor. so pinion gear would depend on what size of spur you're using.
5. i use 12. but 14 should be fine.
6. euro-style plugs for me. i'm not so hot on direct soldering as well.
here's a pic of my T2 if you want an idea on how to mount a GTB on a T2 (Running an Orion motor though)
hths.
