team associated tc3
team associated tc3
I just pocked up a tc3 for 25 bucks and i was wonderig if i lock both diffs in it willbthay creat a problem or would that help cuz i got 2 locked diffs from the guy i bougjt it off u
If ur gonna drift it then lock em, not sure if ur using it as a tc
Im turning it into a rally car
So i locked the diffs on my tc3 my next question is a motor for it i plan on using my hobbywing ezrun-s10 esc. Idk what kv motor to use and or pinion gear any help would be great
I would use something in the 3000ish kvs, and pinion size somthing between 19 - 23 just see wnt the temps are between them!!
I have a brushless motor thats unmarked that came with my esc and i put a 22t pinion on it and its got alot of power on the low end but on a straight run it seems kinda slow
Well if it's a high kv motor or a lower one might have something to do with it...or u could just gear up higher, keep an eye on the temps tho
