Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 05-24-2005, 10:48 AM   #1
rayhuang's Avatar
Default Intellect Battery 3800
Hey all,
The IB3800's are through there first cycles and like the IB3600's-the numbers are excellent. Power PUsh just e-mailed me and said at 35 amps he is seeing 400 sec and 1.17+ numbers. Danny says hes happy with what hes seen off of his TM's too.
Anyone put them on the track yet? Anyone run them heads up against a GP3700? None of this unmatched BS this time. Matched GP3700 vs matched IB3800.
I wont have any till end of next week-but I'll be sure to post what I find. At least vs the IB3600 and GP3300's. I dont own any GP3700's.
Ray
Old 05-24-2005, 11:29 AM   #2
Tempest2000's Avatar
Ray,
I'm matching IB3800's as we speak and they look IMPRESSIVE.
I'm matching at 30 amps.
1.175-1.19's 450-500 run time and low 2's for AIR.
A LOT of 1.18's. On the second cycle right now.
Should be done next week sometime.
Later,
Michael Skeen
Thunder RC
Tempest2000 is offline   Reply With Quote
Old 05-24-2005, 11:55 AM   #3
rayhuang's Avatar
Tempest-Danny did say this cell would blow people away on its performance. Considering how good the IB was for a brand new cell (in the high discharge RC racing application) it only stands to reason they have the knowledge and ability to improve rapidly. I hope it rips in stock-the I only need to have one set of packs for stock and mod racing-where as before I had packs for each.
Old 05-24-2005, 12:28 PM   #4
Ray,
Yeah I'm hoping for that too LOL.
I hate having packs for stock/19 and then packs for mod.
I also hate fooling with dead shorting...
I'll check back in with my own input after I've had a chance to run them.
Later
Michael
Old 05-24-2005, 12:29 PM   #5
We were sent some of the new packs to try, from Danny. I like them so far. I have been running them in mod oval, just local club racing, but the runtime is good. They cycle out better then the 3700's that I have but on the track they have a little less runtime, but more rip. I have been running 6x1's, and even though the new motors are really effecient the cell's last 4min, little to no fade and anywere from 30-60 sec left. Time to try some 5 turns. Its got better up front rip then a 3700 and equal to that of the IB 3600 without the nromal 3600 fade at about the 3 min mark.
It has equal rip of a really good 3300 pack, but the rip lasts longer. I would attribute that to the good voltage 1.17+ at 35 and the low 2.0 cell AIR. We have not seen the sticks on our shelfs yet so I dont know what the norm in numbers are but I like what I see. And if they are cheaper then the 3700's then I am all for it.
I have been charging at 6a with a 0.04 dropback in the morning and 0.03 later in the day and normal discharge at 35a. Nothing special.
DW
JPHRacer is offline   Reply With Quote
Old 05-24-2005, 12:39 PM   #6
rayhuang's Avatar
Dw-any chance you can have a stock racer run them as well? I know Oval and On-road are very different beasts-but when it comes to repeatability for laptimes-nothing beats a dialed driver in oval. You watch the peak then the voltage drop off by the laptimes.
Old 05-25-2005, 10:35 AM   #7
koabich's Avatar
Send a message via Yahoo to koabich
I was happy with their 3600 cells. I thought they were very top notch! I just bought three packs of the SMC 3800's at my LHS and the numbers were crazy...1.176 (@35 amps) on all packs with run time averaging about 415 seconds. Very low IR. All were 2.0.
Cannot wait to run them!!
koabich is offline   Reply With Quote
Old 05-25-2005, 09:43 PM   #8
Wouldnt do much good. No fast stock oval guys locally. I have yet to see more then a 3/10 drop in lap's from start to finish of my own runs with the cells, this weekend its was start on 3.9's finish on 4.2's.
The one thing that we found with the 3600's is that they were very sensitive to amp spikes. In mod they would allways go flat, nothing you could do about it. In 19t they would go flat with 36 degree's of timing and a smaller gear. With 24 degree's of timing and a bigger gear they would not have the problem. Less amp draw from the motor.
The 3800's dont go flat in mod, so I doubt they would do it in stock.
The only reason why the cells wouldnt work in stock would be if you cant get the voltage. We were sent 1.175 @35 amps which is good if you ask me especially with 415+ runtime. Never seen 3700's that stout.
DW
Old 05-26-2005, 01:50 AM   #9
highwayman's Avatar
DW
we also noticed that about the IB3600... during the course of a five min heat, in every minute, the pack would feel rather flat, forcing you to somehow change you lines a bit...
That's good news about the 3800... maybe that's why they came up with the 3800...
highwayman is offline   Reply With Quote
Old 05-26-2005, 02:52 AM   #10
GKC
GKC's Avatar
Send a message via ICQ to GKC
Just wondering at what Amps are you guys charging the IB3800s during matching and usage?
GKC is offline   Reply With Quote
Old 05-26-2005, 04:22 AM   #11
DW
Just wondering about this "flat" in the 3600's. I have just purchased 7 matched packs and I am planning to use it mainly for stock with an intention to move up into modified shortly. Is this flatness a major issue with this battery? Also, what are people doing as far as battery maintainence is concerned? (eg. charge rates, types-linear, flex or step, discharging rates and storage methods -do you dead short them or store them on zero racks?)
Sorry about all of the noobie questions. I have been out of the loop for a few years.
Rockape is offline   Reply With Quote
Old 05-26-2005, 08:58 AM   #12
6 amp charge is usually the norm now days...
Old 05-26-2005, 09:06 AM   #13
rayhuang's Avatar
I will answer only the questions I am 100% sure I know are right
Do NOT deadshort the 3600's. They do not respond well to this as tested by Jsh Cyrul and others.
I charge mine at 6 for mod and 7 for stock. I was doing a 0.052 peak detect on my CE X3, but I am going to try 0.032 next practice.
The best method I have found for the IB for day and week maintenance is this:
Run 5 to 6 minutes tops-dont run till pack dumps. Leave residual charge in battery till you want to run the battery again. Just before recharging-dump them at 30 or 35 amps then into a tray (like Indi Octane-2) for 5-minutes. if its a Novak tray then maybe 10 minutes-then charge them back up as close to race time as possible.
At end of race day-leave residual charge in them till next week. Discharge and tray before running.
Old 05-26-2005, 10:40 AM   #14
Have there been any size issues with the 3800s? Are they bigger than the 3600s?
Fuzzy is offline   Reply With Quote
Old 05-26-2005, 10:46 AM   #15
They are the same size as the 3700 GP's they are bigger than the 3300 and 3600 batteries. They are bigger in diameter, but the length is the same.
They will fit offroad fine. Most onroad cars unless they are new or you have a new chassis you will have to file the battery slots to make them fit properly. Most kits are already being made for the new cells.
Michael
Forum Jump
Intellect 3800 LIPO vazzo Australian Racing 5 06-17-2008 11:59 PM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 11:05 AM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 09:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 04:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 04:05 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
