Intellect Battery 3800
#1037
Originally Posted by Danny/SMC
Just prior to charging your pack when you put in a tray do the lights all shutoff at about the same time ?
#1039
If the lights shut down earlier on the 3 cells that are getting hotter they most likely have lower runtime thus making them peak earlier and getting hotter.
Now what do I do to get them to charge? (besides smashing them with a hammer)!!LOL
#1040
Contact Pro-match they will get you straightened out.
#1041
Thanks for the help!!
#1042
lrp comp 2
I just purchased comp 2 charger what are recomended settings for the 1b3800 thanks for the help
#1043
Hi Danny
I have been playing with my APS Charger and was curious when you reccomend a specific temp cutoff like 130F, is this still during the charge cycle that the best performance can be reached at between 130-140F or what I measured was a continued rate of temp increase after charging has been completed. If you want to maintain a max 130F temp, then cutoff should be set lower.
Do you agree or can you provide more information?
#1045
Hi Danny
Thanks for all the advice. I Currently use a 20A discharger to 5.4V or 3.6V and then before recharging, I use a Rayspeed equalizer. It has a 5A equalize then a 1A condition mode to 0.9V per cell. Based on your website, it seems you reccomend the Integy 030 which takes the cells down to 5.4V per pack but indivually to 0 V but you reccomend to remove when lights go out which is probably around 0.9 to 0.5V per cell.
I agree the best way to discharge is individually. Do you have any other reeccomendations for dischargers such as ?
#1047
Originally Posted by wannabee
I have an email in to them, I'm waiting for tech to call me.
not only make them vent but can do damage to the cell.
#1048
Stock only racing
I just starting using the IB3800 this weekend. Also I have read most of the posts on how to care and maintain them. But it seems the recommendations were for maintaining or increasing run time. Since I am only racing stock is there any difference in the care and maintainance to maintain or increase voltage instead of runtime?
#1049
What do you normally set the cut-off at on a Integy 19X9v6 for IB3800's? Right now I have it at 3mV/C 18 mv/P. What does each one mean and how does it affect charging by decreasing or increasing it? thanks!
-Eric
-Eric
#1050
